.SIG Change
Discussion in 'UK Motorcycles' started by Nigel Eaton, Aug 29, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    It has arrived. Mucho cheers to Lozzo for the lift down to Brizzle.
    By **** missus, it's a big 'un. I used to think the 'Wing was a heavy
    fucker, but this one takes the biscuit.
    It has a centre stand. Purely decoration I assume, because there is *no*
    way I'm going to be able to get it on it without a jack.
    It dunnarf go, too. Which, given the somewhat iffy handling, could prove
    interesting. Mined ewe, the tyres definitely need some air, which may
    improve things from "murderous", to "wounding with intent".
  2. Nigel Eaton
    Gyp Guest
    After the late '80's tourer fest that was Saturday afternoon, I think
    you definitely need to try the Sportster next time you're in town. More
    go than the Goldwing and the BMW put together, with worse handling than
    either and brakes like the Z200. Oh and feels like a Rabbit connected
    direct to the national grid rather than to a couple of AAs.
    But that's only because I really want to try the Z13
    Gyp, Aug 29, 2004
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    Hmm... Sounds irresistible. Do I *have* to wear the leather chaps
    though?
    It's a date, big boy. EOSM?
  4. Nigel Eaton
    Gyp Guest
    I thought that might work ;-)
    No, simply the leatherique thong. I'm probably going to play with the
    ergonomics to make it significantly less comfortable but slightly more
    manoeuvrable tomorrow (replacing the forwards with mids)
    Hmm... *If* I make it to EOSM, it will only be because we have left
    Horse at the POL [1]. But due to the logistics that would leave you
    driving the Citroen Saxo 954 RR SP EXUP.
    [1] Parents Out Law
    Gyp, Aug 29, 2004
  5. Nigel Eaton
    Fr Jack Guest
    Battlestar Galactica, innit?!?!
    Need some air??
    FFS they were about 2psi off flat!
    Did it look like a moped when I sat on it?
    Fr Jack, Aug 29, 2004
  6. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Fr Jack
    You're not far wrong, 25 in the front, 28 in the rear. =8^O
    Not even you could do that. I'll try to figure out a way to get the
    piccie off of my phone, and onto a website.
    Nigel Eaton, Aug 30, 2004
  7. Nigel Eaton
    Nigel Eaton Guest
    Oh well, we'll treat it like a 68.
    You know, you can owe me one...
  8. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Nigel Eaton
    Bad form and all that, but a better idea just occurred.
    You can HAGM on the Z13, and I'll HAGM on Tracey. How's that?
  9. Nigel Eaton
    Gyp Guest
    OK, if you can persuade her then you're a better man than I, Gunga din
    Gyp, Aug 30, 2004
  10. Nigel Eaton
    Nigel Eaton Guest
    That's your job, I'm crap at chatting up other people's wives.
    I really need someone who could give me lessons.
  11. Nigel Eaton
    SteveH Guest
    Paging Bear....
    SteveH, Aug 30, 2004
  12. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, SteveH
    Thank you Murray...
  13. Nigel Eaton
    JackH Guest
    "Dave? Hello Dave..."
    JackH, Aug 30, 2004
  14. Nigel Eaton
    SteveH Guest
    "You're my wife now"
  15. Nigel Eaton
    Gyp Guest
    Well, SWMBO advises that Bear crashed & burned :)
    Gyp, Aug 30, 2004
  16. Nigel Eaton
    Nigel Eaton Guest
    Well, that's what she told *you*.
  17. Nigel Eaton
    JackH Guest
    Probably their own little set of code words, I reckon.
    JackH, Aug 30, 2004
  18. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, JackH
    "Safe" words, ITYM.
  19. Nigel Eaton
    JackH Guest
    Aha... you saw Brasseye, too...
    JackH, Aug 30, 2004
  20. Nigel Eaton
    mups Guest
    Nigel Eaton says...
    It is a thing of rare beauty. The dashboard is one of the finest
    examples and early 80s bling that I've ever seen, and as for the trip
    computer...
    Now does anybody know Arto Nyquist's phone number?
    mups, Aug 30, 2004
