Sidecar Musings Part 2 - Diversion vs Kawasaki
Discussion in 'Australian Motorcycles' started by G-S, Mar 29, 2006.
  1. G-S
    G-S Guest
    It was mentioned in passing "had I thought about putting a chair on the
    Diversion instead" and I went hmmmm.
    *thoughts (or what I choose to call thoughts at least) so far*
    The Diversion could be fitted with a chair too, although it would (of
    course) be less grunty than the Kwaka.
    92ps at the rear wheel is similar to what Alan Pennykids K100RS had
    (they are rated at 94ps from memory) and similar to my mates old CB900
    outfit (90ps) and current GTR1000 outfit (94ps) so it would do the job
    (particuarly given that if I'm riding the outfit I'll have at least Jodz
    and probably Jodz and Molly so I'm unlikely to be hooning).
    Not sure how the Diversion would go if I put a trailer on the back
    though (which Jodz mentioned as a possibility for later), the Kawa OTOH
    shouldn't have a problem even with the trailer.
    The Divvy OTOH has shaft drive (no chains to replace), can run _much_
    cheaper tyres, has a more protective fairing, is fitted with panniers
    and has a long distance better riding position. The Divvy is already
    short geared compared to the earlier XJ900's so probably the shaft drive
    gearing would be ok (probably). Also the Divvy has a larger 24 litre
    fuel tank and uses less fuel so I'd probably get away without a long
    range tank, which would save several hundred dollars minimum. The
    longevity of the XJ series of motors is not in question, yah can't kill
    the buggers with a stick.
    What do you think people... Diversion or ZRX for the chair hauler?
    G-S
    G-S, Mar 29, 2006
  2. G-S
    JL Guest
    ZRX.
    The divvy does the job of a tourer much better than the Z so why lose
    the bike you're more likely to go away on ? While I'm sure the side car
    solution gives you a good family option, there will be times you'll want
    to go to a rally by yourself or two up
    JL
    (but I wouldn't listen to me 'cos I couldn't ever see myself doing the
    sidecar thing - if I wanted a 3 wheeler I'd trike a Rocket 3)
    JL, Mar 29, 2006
  3. G-S
    G-S Guest
    Hmmm there is that isn't there... if I toured solo it'd be on the Z if I
    chaired the Divvy. You know... sometimes I miss the most obvious things :)
    G-S
    I wouldn't knock back a ride on that if you ever get around to it ;-)
    G-S
    G-S, Mar 29, 2006
  4. G-S
    sharkey Guest
    That's what weber kettle BBQs are for, to weigh down the sidecar.
    -----sharks
    sharkey, Mar 29, 2006
  5. G-S
    Boxer Guest
    My preference would be for a water cooled bike, a tug gets a hard life.
    Boxer
    Boxer, Mar 29, 2006
  6. G-S
    JL Guest
    <shakes head in bemusement> You and I live in very different worlds Mr
    Sharkey !
    JL
    (but then the last rally I went to was in the eighties, never really
    "got them" to be honest)
    JL, Mar 29, 2006
  7. G-S
    Mad-Biker Guest
    Why not buy another bike and sidecar it?
    Mad-Biker, Mar 29, 2006
  8. G-S
    sharkey Guest
    McArgle turned up to Dargo a couple of years ago sans Sally, who'd
    decided to take her own bike somewhere else ... unfortunately, he'd
    already packed everything assuming he was coming so he filled the car
    with weber BBQ, coal, collapsible table, etc. just to weigh it down ...
    Well, I'm more of a minimalist traveller myself (pretty much everything
    fits in my Andy Strapz panniers) but sidecar freaks are mighty handy to
    know when you discover you need a cast iron work / chainsaw / side of beef.
    -----sharks (and trikes carry firewood just fine!)
  9. G-S
    G-S Guest
    Heh... I don't have enought money to do that without selling one of the ones
    I've got now and still pay for the chair :)
    G-S
    G-S, Mar 29, 2006
  10. G-S
    G-S Guest
    Yeah... there's that too... looking more like the original idea of the ZRX
    is the go :)
    G-S
    G-S, Mar 29, 2006
  11. G-S
    Johno Guest
    Bloody hell Geoff, you are wearing her down ;)
    Def the zrx mate - mere fact it has more grunt overall, easier to
    lower the gearing for the chair.
    johno
    Beer?
    Johno, Mar 29, 2006
  12. G-S
    Knobdoodle, Mar 29, 2006
  13. G-S
    G-S Guest
    Hmmm it may have been 92ps at the crank come to think of it in the test I
    read. That'd be more like 75 to 80 at the rear wheel. It is fairly common
    for power outputs to go down as noise and or pollution regs get stricter
    (same thing happened to the GTR1000's). Possibly the test I read (of the
    first divvy 900S) quoted the power then and the other one you mentioned
    being of a 2002 model is accurate for that one.
    Honestly the only real problem with the divvy is they should have put the
    shaft drive on the XJR1300 motor.
    Instead they built a new liquid cooled motor... and can charge more $ for
    the bike...
    G-S
    G-S, Mar 29, 2006
  14. G-S
    But really; if you move back from GS-2006 mode to Clem-living-in-the-70s
    mode the Divvy has HEAPs of power to tug a boat.
    Shit; XS650s and 750/4s used to be the tugs-of-choice and a Divvy has at
    least 15 horses more than a Z1 (no matter which test you read).
    Sure you'd have quicker quarter-mile times on the Kwak and you'd had a
    top-speed of 220 instead of 195 [make sure you post Jodie's opinion tof
    this] but the Divvy will handle the chair without any problems at all!
    I really doubt that cooling would ever be a problem either.
  15. G-S
    G-S Guest
    Yes it does. But you have to consider that living in the 70's chairs *like
    the ratty 650 twin outfit I was most used to* had a single width car and a
    light bike to pull around with no heavy accessories.
    Ummm no way is the Divvy faster than my Z1 was... seriously. I know they
    quote about 80ps for the Z1, but my Z1 would have blasted the Divvy into
    the weeds without trying. I know lots of guys with Z's and honestly _none_
    of them were stock, regrettably those sorts of hot up bits aren't an option
    for the Divvy :)
    I'd suspect that the top speed would be more like 195 for the kwak and maybe
    170 for the Divvy. Having said that, I agree the Divvy has 'enough' power
    to haul a 1.5 chair around fine.
    I sat down and worked out some power to weight ratios.
    With me, Jodz, molly and me the Kawa outfit would have about the same power
    to weight ratio as an SV650 (solo with me on it, full fuel). With a loaded
    trailer on the back and camping gear the Kawa outfit would drop to power to
    the power to weight ratio of a BMW 650 single (like Jo's scarver). Still
    plenty for general riding around :)
    Whereas the Divvy outfit with Jodz, Me and Molly would have about the same
    power to weight ratio as a BMW 650 single (again solo with me on it, full
    fuel). Add a trailer and the power to weight ratio is about the same as a
    GPX250 (solo, full fuel, me again). That's getting a tad marginal (BTH may
    enjoy riding 250's around OZ but I wouldn't ;-)
    The power to weight ratios aren't perfect indicators but they give an idea
    at least.
    For a comparison the 650 twin outfit I used to trundle around in rally mode
    normally had one 80kg guy and 1 70kg guy, 2 slabs of beer, 2 sleeping bags
    and 2 2 man A frame tents. It made about 50ps. The power to weight ratio
    of this outfit loaded would be about the same as my estimated loaded weight
    for a Divvy outfit (without trailer), and off the mark I suspect if would
    perform the same (less top end I suspect). It was fine for cruising along
    at 60 to 70mph (hills slowed it down a bit though, and it didn't like
    summer days). I wouldn't have wanted to hang a loaded trailer behind this
    outfit either.
    I suspect thought that I'd actually prefer the riding position of the Divvy
    in outfit mode to the Kawa, which is more what's holding me off deciding.
    I'm getting soft in my middle age, and the _much_ better fairing and seat of
    the Divvy are more appealing than the ZRX seat and no fairing is most time.
    I still love doing distances, but I prefer to do it in a modicum of comfort
    theses days :)
    The Divvy does have some advantages Clem, it really does.
    G-S
    G-S, Mar 29, 2006
  16. G-S
    JL Guest
    snip factual analysis
    G-S you're answering an emotional argument with facts. Knobdoodle wants
    to argue for the Divvy based on a deepseated emotional attachment (which
    he will undoubtably deny now).
    Seat comfort is a good point though - I suspect with a pillion and a
    chair you'll move around less on the bike too, so in either case you
    might want to budget a grand or whatever the going rate is for a plush
    seat. Jodz will like that too :)
    JL
    JL, Mar 29, 2006
  17. G-S
    JL Guest
    I'm probably not minimalist myself but I can't envisage taking a weber
    with me to improve the weight distribution !
    JL
    JL, Mar 29, 2006
  18. G-S
    sharkey Guest
    Why bother with a trailer? There's a vast amount of room in and around
    an outfit already ... just work out how to lash gear to the boat. Ditto
    the extra fuel ... just plumb the thing up so you can tuck a marine fuel
    tank[1] in the nose of the car when you need it (eg: to refuel Clem's bike)
    -----sharks
    [1] http://www.biasboating.com.au/fueltanks.html
    sharkey, Mar 30, 2006
  19. G-S
    sharkey Guest
    I agree. A spit roast would have been tres-elegant.
    -----sharks
  20. G-S
    Hamish Ben Guest
    Geez...
    You have your first kid and group sex suddenly becomes an important topic!
    Hammo
    Hamish Ben, Mar 30, 2006
