Shot Blasting....
Discussion in 'UK Motorcycles' started by Brownz, Nov 9, 2009.
  1. Brownz
    Brownz Guest
    Anyone have access to a shot blasting cabinet who could tidy up my
    hugger/chainguard bracket from the VFR before I get it powder coated ?
    (Got a local man who has powder coating facilities, but I don't appear
    to know anyone with a shot blast cabinet !)
    Beer tokens/vino etc available....
    Brownz, Nov 9, 2009
  2. If your local bod doesn't have a shot blaster, then by the time the
    part gets to them, it could be contaminated with grease / oil / dirt
    etc, which will comprimise the final finish.
    How big is the part / where are you located / how quickly do you need
    it done? My dad has a blaster and small PC'ing set up (bakes in a
    domestic oven...) so if all works out might be able to help out. He
    could probably run it though the next tim ehe doess a batch of
    blasting.
    cheers
    SS
    Spinning Spanners, Nov 9, 2009
  3. Brownz
    Simon Wilson Guest
    <waves>
    I have a cabinet, but only got some glass beads at the moment which
    wouldn't be coarse enough for what you need. If you can get some sand[1]
    you're welcome to come and use it.
    [1] There's a place in Reading that supplies it IIRC but I can't find
    them now.
    Simon Wilson, Nov 9, 2009
  4. Brownz
    Beav Guest
    Paint stripper and then go at them an A/G sporting a curly wire brush wheel.
    Done by the time you've found someone who's got a cabinet.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 9, 2009
  5. Found somewhere in Stanford In The Vale, chap did it while I waited, charged
    me the change in my pocket which was around £3.50, dropped it off with the
    powder coating man who is doing some garden gates tomorrow - said he'll
    stick em in with them, and then leave it in to do a hot coat which gives a
    better finish - all for a fiver. Result.
    Brownz \(Mobile\), Nov 9, 2009
  6. Brownz
    geoff Guest
    In message
    Yes you do
    Pop over any time
    www.cetltd.com
    geoff, Nov 9, 2009
  7. Brownz
    JackH Guest
    I've got access to both sand and glass blasting gear.
    Funnily enough, I've been using it today to clean up a set of VFR
    downpipes / collector box, and both engine casings.
    Much as I like VFRs, they do have a tendency to fur up quite badly in
    some respects.
    JackH, Nov 9, 2009
  8. Brownz
    Brownz Guest
    Don't forget the top of the fork stanchions.....
    Brownz, Nov 10, 2009
  9. Brownz
    Beav Guest
    I'd say so!
    Well done that man.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 10, 2009
