Shortening front forks.
Discussion in 'Motorbike Technical Discussion' started by Greg.Procter, Oct 11, 2009.
  1. Greg.Procter
    Greg.Procter Guest
    It strikes me that you are concerned with how to get the best performance
    from existing suspension systems, rather than how to build the best/ most
    practical suspension. (practical vs theory) That's fair enough.
    One's theoretical motorcycle and rider must cope with both raised bumps
    and dips in the surface. My theory says the suspension needs to be set
    mid-point in it's travel with the bike normally laden at rest.
    The standard of the road surface will dictate whether one wants that rest
    point to be above or below the half way point. The length of movement,
    vehicle speed and spring rate determines the spring design.
    Preload is something to be considered when attempting to improve
    an existing suspension. With zero unsprung weight (unachievable)
    one would need (almost) no spring preload.
    One needs the wheel to remain in direct, weighted contact with the
    road surface, but the unsprung to sprung weight ratio in conjunction with
    the change in spring pressure with the extension due to that movement
    affects the rate at which the suspension will move. (also of course the
    rate at which the bike and rider move vertically)
    Coil springs are effectively torsion springs which have (almost) no
    rebounce. (naturally damped) Of course, the total suspension design etc
    means that dampers are required.
    I remember riding on an old concrete slab road where each slab was slightly
    tilted. I watched the front wheel rise and fall over each slab and settle
    a tiny fraction higher each time (somewhat higher speed than legally
    acceptable)
    Eventually the suspension hit the top stop and I was forced to back off.
    Watching the suspension rebound was also interesting!
    Greg.Procter, Oct 25, 2009
    #41
  2. Back in the late 1960's, most of the motorcycles known as
    "scramblers" and "enduros" which were available to the off-road
    enthusiasts in America had 19-inch front wheels.
    We were amazed by the improvement in ride and precise steering offered
    by the
    21-inch front wheels that European motocrossers favored.
    The outside diameter of the tire on the 21-inch wheel really wasn't
    larger than the
    outside diameter of the 19-inch wheel, but Honda caught on to the
    possibility of larger diameter wheels and equipped one model with 23-
    inch wheels.
    That only lasted one or two model years on their XR models in the
    1970's...
    Don't parents give their kids rocking horse down in NZ?
    When your front wheel hits a bump, it compresses the spring and
    compression damping and the ratio of sprung to unsprung weight play a
    role in limiting the upward movement of the handlebars.
    But the handlebars are connected to the chassis and a certain moment
    is transferred through the springs and rear dampers to the rear wheel
    *before it hits the same bump that deflected the front wheel.
    Then the rear wheel hit the same bump a fraction of a second later and
    the process is reversed as the bump is transmitted back through the
    chassis to the front wheel and this chassis rocking is called "hobby-
    horsing".
    Hydraulic dampers cannot work if there is very little motion of the
    fork or shock.
    In order to eliminate hobby-horsing on California freeways, one has to
    carefully adjust front spring sag so it's about twice what you'd use
    on the rear springs.
    little man upon the stair, Oct 25, 2009
    #42
  3. No, it's not magic, the optimum tire size and weight distributions of
    modern sport bikes have been arrived at by trial and error and the
    perceptions by experienced riders as to what feels right to them.
    We saw sportbike manufacturers adopt 16-inch front wheels in the early
    1980's to speed up steering response. But motorcycles equipped with 16-
    inch front wheels would not recover from a front tire washout, the
    riders could expect to crash.
    The 17-inch front wheel has been universally adopted as the standard
    for sportbikes.
    But some professional GP riders like 16.5-inch wheels for the quicker
    steering.
    #43
  4. Most sportriders have no interest in designing a motorcycle, they just
    want to get their machine's suspension system adjusted so they can
    ride with their friends.
    When they read the recommendations of the motorcycle magazines, which
    are made by expert riders after riding around a race track that they
    know very well, the recommendations will be for a race track set up
    which will not be very comfortable on California's rough freeways,
    where each pavement section is set at
    a slightly different angle than the next.
    Even in cases where the freeway was paved in one continuous pour of
    concrete, which is brushed to enhance traction before it dries, the
    pavement will have height irregularities.
    When attempting to ride on freeways so paved with a race track
    suspension set up, I encountered eyeball jiggling so bad that I
    couldn't focus on distant objects.
    When I backed off spring preload to the point where half the travel
    was used up in sag, suddenly turning into a tight corner resulted in
    severe out tracking as weight transferred to the front tire.
    Race track set ups usually recommend that front spring sag be
    somewhere between 25% and 33% of the total travel. I wound up with
    about 40% sag as the best compromise.
    Also, the Bridgestone BT-020 sport touring tire that I was using was
    about one inch larger in diameter due to a taller sidewall.
    I changed to a tire which more closely resembled the favored sporty
    sport tire
    profile and diameter to eliminate the out tracking, which was always
    noticeable at
    any speed.
    Your front suspension was packing down because the fork oil was too
    thick.
    Damper rod type forks are very sensitive to fork oil weight, that's
    why cartridge forks with their stacks of flexible washers to act as a
    variable orifice were invented.
    And the Gold Valve Emulators offered by Race Tech are a much cheaper
    alternative to buying a whole new cartridge fork to replace a damper
    rod fork.
    Of couse the ultimate fork would be an Ohlins, with damping that's
    adjustable at
    both high stroking speeds and low stroking speeds.
    Nevertheless, a hydraulic damping system cannot damp motion very well
    if the
    suspension units aren't moving quite a bit.
    Then traction reverts back to the tire contact patch and the damping
    caused molecular friction (aka "hysteresis") in the rubber has to do
    all the work of absorbing those tiny bumps that may only be 1/4 of an
    inch high.
    And larger diameter tires will do a much better job than a small
    diameter tire in such cases.
    But, consider a go kart chassis which has no suspension at all. The go
    kart driver expects to be turning constantly and he *wants* his rear
    tires to be "loose" so he can turn rapidly.
    Mini-bikes often have tires that are about the size of go-kart tires
    and some of the smaller scooters have tires that aren't much bigger,
    so they will feel "loose" at rather low speeds, compared to the speeds
    that I ride my sportbike at on the highway.
    #44
  5. I thought that was your 'thing'. No, come on, this being a tech forum,
    we really need to know what 'moderate sized wheels' are. What diameter?
    Because obviously we don't want to be unsafe, do we?
    The Older Gentleman, Oct 25, 2009
    #45
  6. Utter, utter nonsense.
    #46
  7. Actually, the 16" wheel problem was only a problem on bikes that had not
    been designed for such a front wheel. Manufacturers just shoved them
    onto bikes with little or no other chassis changes - Suzuki did, Guzzi
    did... I'll bet you never rode a Guzzi T5 or Mark Four Le Mans.
    On bikes designed for such wheels, they worked. GPZ900R, anyone?
    And your ignorance means you don't appear to know about the
    all-conquering 1990s sports bike, that came with a 16" front wheel: the
    original Fireblade.
    #47
  8. Ah, so we're talking about six-inch diameter wheels, now?
    Rather a different kettle of fish. Not 'moderate' sized wheels, which is
    what you first banged on about. So you're moving the goalposts. It
    happened quicker than I expected.
    #48
  9. Greg.Procter
    Greg.Procter Guest
    Of course, but one needs to understand how the system of wheels,suspension
    and geometry work if one wants to make real improvements.
    I'm in the situation of a near blank drawing board with only rake and
    wheel size fixed. Admittedly, the original suspension worked exceptionally
    well, but I'm uncomfortable with it's strength. (or apparent lack of
    strength for the use I intend for it)
    I'm not really sure what you mean by "out-tracking"?
    (perhaps the infamous separation of two cultures by language :)
    Yes, that sounds about right.
    Bear in mind that that stretch of road is the only concrete slab road
    I know of in New Zealand. I never felt the need to change damping rates
    elsewhere in NZ.
    I'm stuck with the original wheel diameter of 12" plus 3.50 - 19"
    overall diameter. That factor is fixed for authenticity.
    The cart has two driven tyres on a rigid axle the ground and generally
    a much smoother surface than I drive on.
    As I say, my wheel diameter is fixed - I need the suspension to do the
    work.
    #49
  10. Greg.Procter
    Greg.Procter Guest
    We went with the Europeans, but I always thought the US market was
    poking itself in the eye demanding the smaller front wheels.
    I certainly fell on my head from one of those - nowdays I think they
    are becoming PC incorrect ;-)
    It's just the different terminology - plus of course you yanks have tended
    to have heavier and softer sprung m/cs which would be more prone to such
    antics.
    Different road conditions here :)
    #50
  11. Greg.Procter
    Greg.Procter Guest
    Of course. But what you perceive may be different to my perception
    thereof. Also, I'm aiming at a much lighter bike that that which you
    might consider a "normal" sports bike.
    (With only one leg, I can't pick up a dropped 700lb bike. 300-400lb
    would be my absolute maximum)
    #51
  12. You Kiwis still keep left on the roads, don't you?
    Imagine you're riding on a curvy road in the hills and you're trying
    to see around a
    hill that blocks your view of oncoming traffic, so you're riding near
    the center dividing line to see whatever is coming at you sooner.
    So you see the lorry coming around the bend and he's taking up more
    than his share of the road and you countersteer by pushing the left
    hand bar forward.
    If the scooter initially out-tracks, the chassis follows the direction
    of the front wheel, which is pointed towards the lorry for a
    terrifying split second, before the
    scooter begins to turn left.
    Initial out-tracking is the scary part, and initial weight transfer
    makes the out-tracking worse.
    There can also be a persistant tendancy to out-track if the front and
    rear tires are of different widths and profiles or if the front ride
    heigth is too high or the rear ride height is too low.
    In the case of persistent out-tracking you'll need to maintain
    pressure on the handle bar to keep the scooter from widening it's line
    in a curve.
    An equally annoying condition is when the motorcycle doesn't out-track
    in the least, but tends to fall into the inside of the curve.
    Sport riders have to learn to time their countersteering input exactly
    so they don't have to countersteer oppositely to keep the motorcycle
    from falling into the corner, with a resulting widening of the arc,
    followed by yet another input to have another attempt at establishing
    the correct line.
    Riders may not realize that their problem is front/rear ride height or
    a problem with tire profiles and they may insist that they have their
    front/rear sag set up correctly and won't want to change it.
    That type of rider may also be unwilling to slide the fork stanchion
    tubes up and down in the yokes.
    So he continues to have to make mid-corner changes in his lines.
    That's a safety problem on the street, and is annoying to racers who
    are trying to pass him on the track.
    There was an engineer at Michelin who came up with a set of formulae
    for tire profiles and diameters and coning angles and how everything
    related to rack and trail and wheelbase.
    I found his name on the interweb once but have never run across his
    formulae.
    That's still a fair bit larger than the tire diameter I had envisioned
    when you first mentioned that you wanted motorcycle forks on a
    scooter.
    I suggest that you go to some of the tire manufacturer's web pages and
    see what they have available in that size.
    A quick way to get a list of the tire manufacturer's pages is to go to
    www.mawonline.com and click on "tires".
    This will take you to a list of tire manufacturers and there is an URL
    leading to each manufacturer.
    With a smaller diameter tire, the suspension is going to have to work
    harder.
    A soft rubber compound on the front tire will help the suspension to
    deal with the
    surface roughness by absorbing the smallest bumps.
    #52
  13. <snip>
    As you've never actually ridden a scooter, let alone on (for you) the
    'wrong' side of the road, where does this advice come from?
    #53
  14. Are you aware that all the manufacturers have been building very light
    sportbikes
    since the mid-1990's?
    A 1993 Honda CBR900RR weighs about 350 pounds without fluids and a
    battery.
    The Yamaha YZF-1000R1 that came out around 2000 also weighs about
    350~375 dry weight.
    What annoys me about the lightweight sportbikes is that they typically
    have a
    33-inch seat height.
    I'm riding around on a 550-pound FZR1000 with a plywood seat so my
    feet will reach the ground and keep me from falling over if I get
    experience vertigo while stopped for a traffic light.
    Go to alt.motorcycle.sportbike and start a thread titled "Ping Bob
    Nixon".
    He has no right leg and still rides a Suzuki SV650. Ask him how he
    copes, and he will tell you.
    Some of the riders on alt.motorcycle.sportbike would like to hear
    about your association with John Britten, too.
    #54
  15. Greg.Procter
    paul c Guest
    Okay, you're closer to it than I am. I just assumed that using
    non-leading forks would move the wheel rearward so the rake would have
    to change. Photos seemed to suggest same, but my eyes aren't too hot,
    so maybe I was wrong to think about rake.
    paul c, Oct 25, 2009
    #55
  16. Greg.Procter
    Greg.Procter Guest
    Still???
    You yanks still drive on the wrong side, don't you?
    Hmmm, seems I always rode the wrong sorts of bikes - toss your weight the
    way you want to go and the bike goes that way.
    The technique probably requires that the rider has his feet under his/her
    centre of gravity. It always worked for me!
    Silly design for motorbikes!
    That's why I'm interested in the particular model - plus there's only
    a partial dip between steering head and seat rather than the usual "U"
    spring frame design that comes from a flat floor.
    It's a very rigid scooter. (one might say overengineered)
    Greg.Procter, Oct 26, 2009
    #56
  17. Greg.Procter
    Greg.Procter Guest
    The "driving side of the road" doesn't make much difference to the
    handling,
    other than when one goes against the flow, when it makes a considerable
    difference!
    As to road surfaces, it's hard to make absolute comparisons because not
    all US roads are the same and not all NZ roads are the same :)
    However, we have half the population density of the US and the country
    is generally lumpy.
    Where I live is geographically near a sub-join between the Pacific and
    Australian techtonic plates with the two crunching upwards.
    In addition the region is made up of recent volcanic activity so the soil
    is very unstable - the roads are always moving. (slowly) Result paved but
    uneven surfaces, hills and valleys and regular 45-50mph bends on 60mph
    roads.
    #57
  18. Greg.Procter
    Greg.Procter Guest
    Rake seems adequate. Triple clamps are easy to mill to set the trail.
    (advantages of having CNC mill in workshop)
    In fact, the axle and head would have (exactly) the same relationship
    whether leading link or telescopic were used. The leading link design
    appears to have been used by the designers so they could use "parts-
    bin" rear suspension units rather than making new telescopic forks.
    As my motor design will have vastly more power and stopping distances
    have become more critical in the 50 odd years since the original design,
    I think the forks strength might be suspect.
    Greg.P.
    #58
  19. North Island or South Island? BrianNZ is always ranting and raving
    about drinking in the pubs and hooning around near New Plymouth over
    on rec.motorcycles.
    little man upon the stair, Oct 26, 2009
    #59
  20. Greg.Procter
    Greg.Procter Guest
    I'm in the far North (AKA Northland) All dairying and pot-growing.
    New Plymouth is waaay south of here on the sides and base of a volcano
    that is the spitting image of Mt.Fujiama. (ie much flatter)
    #60
