Shortening front forks.
Discussion in 'Motorbike Technical Discussion' started by Greg.Procter, Oct 11, 2009.
  1. Greg.Procter
    Greg.Procter Guest
    Hi all,
    returning to motorcycles after several decades of not motorcycling.
    My present project is restoring an old motorscooter.
    (make probably not relevant as it was a New Zealand product)
    Step #2 is upgrading the motor so that I can keep up with modern traffic.
    Step #3 has to be fitting modern disc brakes.
    Step #4 then has to be upgrading the front suspension, which is where I
    will run into big problems. The headstock is rigid enough and can be
    further braced, but the forks are an inverted "Y" folded back slightly
    with leading arms and short spring/damper units (parts bin engineering
    from the manufacturer's motorcycle rear suspension)
    My current thought is to make a more conventional motorcycle front end
    with two triple plates only with much shorter sliding tube forks.
    Has anyone got experience with front forks (say 250cc-350cc size) and
    the possibilities of shortening them?
    Regards,
    Greg.P.
    NZ
  2. If you can find some forks that will fit the yokes, you don't have to
    shorten them in order to make the motorcycle 'sit' correctly.
    Just lift the forks through the yokes so you have an inch or two (or
    whatever) protruding above the top yoke.
    The Older Gentleman, Oct 11, 2009
  3. Greg.Procter
    M.Badger Guest
    Intrigued now. Any chance of some pictures?
    Your wallet, but is it viable?
    A well setup drum brake, and very good forward planning ;-)
    Have a scout round a breakers and see if anything vaguely modern could be
    adapted to fit. Once you have a stem/bearing set that fits, look very
    carefully at the yoke offset needed from the stem.
    M.Badger, Oct 11, 2009
  4. Greg.Procter
    1949 Whizzer Guest
    Step #1: SELL the old motorscooter to somebody who likes that
    particular brand.
    Those people are definitely OUT THERE, in more ways than one.
    Step #2: Buy an old motorcycle that you can afford, preferably one
    that was mass produced in Japan and imported by the millions into NZ.
    Step #3: Fix it up, using aftermarket repair parts that you can easily
    order from the interweb.
    Step #4: Next time you have such a creative thought, JUST LET IT GO.
    Sure. You could install shorter stanchion tubes, shorter springs and
    maybe even shorten the damper rods.
    But it wouldn't be worth your time if you have the money to buy a real
    motorcycle that does what you want.
    And, if you don't have any money, the project will be just an exercise
    in futility if some engine part or rear drive part gives you trouble.
    Then you'd be back in here asking about motorcycle engines that you
    could easily adapt to motor scooter style rear drive, or how to adapt
    a motorcycle swing arm and a motorcycle engine to an old scooter.
    1949 Whizzer, Oct 12, 2009
  5. Greg.Procter
    Schiffner Guest
    Typical bad advice from a fake.
    Schiffner, Oct 12, 2009
  6. Or you could do what I suggest, which is raise them through the yokes.
    As long as you don't mind maybe a couple of inches of stanchion poking
    up.
    The Older Gentleman, Oct 12, 2009
  7. Greg.Procter
    1949 Whizzer Guest
    I don't feel like instructing Greg about the importance of matching
    the front spring rate(s) to the rear spring rates and why that's
    important to the overall ride comforts as well as traction balance.
    And, if he found a set of forks for a more modern motorcycle which
    used a 17-inch front wheel, he would still have a handling problem
    because the rear wheel is probably a 12 or 14-incher.
    The rider of a two wheeled vehicle with such a wheel/tire diameter
    mismatch feels like the bike doesn't "want" to turn into a corner and
    then it feels like the rear end is falling out from under him is the
    turn.
  8. Who said he would?
  9. Greg.Procter
    Schiffner Guest
    Boy are you stupid. It's a motor-scooter NOT a 125cc street bike you
    stupid git.
    Schiffner, Oct 13, 2009
  10. Greg.Procter
    Schiffner Guest
    uh, dude your senility is creeping in methinks...he's talking about a
    motor-scooter.
  11. Greg.Procter
    paul c Guest
    Some scoots, such as a Honda CH250, could probably handle small bike
    forks if the right sized races could be found, the fairing and inner
    bodywork would probably have to go and then it would be a rat scoot.
    paul c, Oct 14, 2009
  12. My bad for not reading the post properly. That said, grafting a
    conventional front fork end on wouldn't be hard: just a waste of effort.
    The Older Gentleman, Oct 14, 2009
  13. Greg.Procter
    Greg.Procter Guest
    Hi Older Gentleman,
    the machine currently has an upside down "Y" made of welded tube - no
    triple yokes and motorscooter superstructure around the head.
    I'm a bit nervous of it's strength if I install better brakes and more
    horsepower. The superstructure can be braced easily inside so I can keep
    the external appearance.
    Apologies for delay, my provider seems only to download about weekliy!
    Greg.P.
    Greg.Procter, Oct 23, 2009
  14. Greg.Procter
    Greg.Procter Guest
    Google "NZeta". Way back when New Zealand had strict fanancial rules
    and most (90%) of our exports went to Britain. UK owed the US umpteen
    times it's total worth so the UK pounds could only be spent back to
    the UK or Commonwealth countries.
    Motor vehicles had huge duties and sales tax but the duties were dropped
    from NZ built vehicles. As we only had 2-3 million people the result was
    a few types of vehicles partly manufactured here, based on existing brands,
    eg Volkswagens; imported components 60%/NZ manufactured 40% - 40% of duty
    knocked off.
    Haven't bought it yet - have put in an auction bid though.
    Well, the motor concept came first - scooter from teenage memories.
    No wallet mostly used as moth repository, but have machine shop.
    My guess is I would have a 50/50 chance of survival WITH perfect brakes, 50
    minute survival with drums.
    (that might be a joke, might not)
    No problem machining up yokes as I have the gear - the only forks I've
    seen that might be near the length are childrens offroad bikes. They
    wouldn't
    take the weight.
  15. Greg.Procter
    Greg.Procter Guest
    I'm definitely "out THERE" ;-)
    I want a scooter because I lost right leg in a motorcycle accident ..
    years ago. no real circulation in the bit I have left so need shelter.
    So much family stress m/c out but apparently scooters are acceptable.
    (I'm going with the flow for now)
    No, can't find such a beast!
    I can make those.
    There's the basis of the idea - the particular scooter has a proper
    swing arm and a conventional unit construction motor.
    Almost anything not too tall in the way of engines could be slotted
    in - width about 350mm inside body.
  16. Greg.Procter
    Greg.Procter Guest
    Can't do it - the body/front skirt surrounds the head.
  17. Greg.Procter
    Greg.Procter Guest
    Let's put it this way - I started tuning bikes in the mid 60s,
    started building frames and engines in the late 1960s. Racing bikes
    1969. (eyesight not up to racing speeds so I retreated to building/tuning)
    End of 1970s m/c accident ended m/c career.
    1990s worked with John Britten on engine concepts.
    I can design a motor, I can design a frame.
    I don't know the current and recent motorcycles.
    I don't have deep pockets.
    Have lathes and mills, CNC and conventional.
    Regards,
    Greg.P.
  18. Greg.Procter
    Greg.Procter Guest
    Adapting "X" axle and wheel to "Y" forks is no problem.
    I could equally design completely new forks and machine them,
    but if existing forks could be shortened it would cut costs drastically.
  19. Greg.Procter
    Greg.Procter Guest
    I don't mind wasting effort - retired with more sense than money :)
  20. In that case, don't buy it, look for something that does what you want
    without
    having to make major modifications.
    Personally, I was thinking about buying a 3-wheeled bicycle and adding
    a 49cc moped motor to it if I ever deteriorate to the point where I
    can no longer balance a 2-wheeler...
    little man upon the stair, Oct 23, 2009
