shortcut adjusting valve tappet clearance
Discussion in 'Motorbike Technical Discussion' started by Matt, May 26, 2005.
  1. Matt
    Matt Guest
    1976 CJ360T (two cylinder, single overhead cam)
    My owner's manual calls for a 0.05 mm (0.002 in) clearance, to be
    checked with a feeler gauge.
    The threads on the tappet adjusting screw are 1 mm apart. I am thinking
    I can tighten the screw until I feel resistance, then back off 1/20 of a
    turn and tighten the lock nut. That ought to be 0.05 mm. Would a good
    mechanic do it that way?
    Matt, May 26, 2005
  2. Matt
    Paul Cassel Guest
    Nope. First you have to determine 1/20 of a turn which is sort of tough.
    Then you need to allow for the nut tightening which increases the
    clearance AND also there is some slop in the system. A good wrench sets
    the gap so that there is resistance on the gauge when you pull it out.
    Some say you should not be able to re-insert the gauge, but I don't do
    it that tightly.
    Paul Cassel, May 26, 2005
  3. No. A good mechanic would use a feeler gauge. It's not like they're
    super-expensive and/or unobtainable, ffs.
    The Older Gentleman, May 26, 2005
  4. Matt
    Matt Guest
    I forgot to ask about the tolerance on this adjustment. My manual
    doesn't give a range, just a single number. I figure it can't be too
    critical, since an extra 1/20 of a turn doubles the value.
    Matt, May 26, 2005
  5. Matt
    Matt Guest
    I guess my question is about how critical the measurement is. Valve
    tappet adjustment has always been troublesome for me. It seems that
    either I can't get clearance for the smallest gauge (0.015 mm) or I can
    get clearance with a much bigger gauge (say 0.076 mm).
    Matt, May 26, 2005
  6. Oh, for heaven's sake. Let's say you haven't got a 2 thou blade, then.
    Right:- to get a clearance of 2 thou without a 2 thou blade.....
    1 Get a 4 thou blade.
    2 Set the clearance to zero.
    3 Set the clearance to 4 thou, counting how many turns of the adjuster
    it takes to do that. Let's say, for the sake of example, it takes four
    turns.
    4 (a) Back the adjuster off halfway (two turns) or:
    4 (b) Screw it back in again and open it out halfway (two turns).
    If you haven't got a 4 thou blade, but have a six thou blade - follow
    the above procedure, but this divide the number of turns the adjuster
    needs by three.
    If you only have an 8 thou blade.... but I'm sure you have got the
    picture by now.
    It really, really isn't rocket science.
    Correct valve clearances are critical for some bikes and not critical
    for others. Can't really be more specific than that, I'm afraid. Just
    set them to the recommended gap and you'll be OK.
  7. I use an inch-size feeler gauge, instead of a metric gauge.
    1.0mm = 0.0394 inch
    0.05mm = 0.00197 inch
    0.06mm = 0.002364 inch
    0.07mm = 0.002758 inch
    0.08mm = 0.003152 inch
    0.09mm = 0.003546 inch
    0.1mm = 0.003940 inch
    The difference between, a 0.05 mm feeler and a 0.06 mm feeler is
    0.000394 inches. That's less than four 10000ths of an inch (five
    10000th's is half a thousandth) and that's a finer adjustment than you
    really need to make.
    It's really hard to feel that difference in friction as you slide a
    feeler gauge between a shim and a tappet, and when you're working with
    screw type adjusters, tightening the lock nut is automatically going to
    change your
    valve clearances, so why fuss with the metric gauges that are ground so
    accurately?
    No, I've never heard of such a thing. I usually do a Go/No Go
    adjustment for clearance checking only, since I want the valves to stay
    looser than the minimum measurement, especially with an inverted bucket
    and shim valve adjusting set up. I'm happy when a feeler gauge of the
    right size or 1/1000th of an inch larger than nominal will go in, and I
    start to worry when I can't get the right size or 1/1000th of an inch
    smaller between the lobe and the bucket. That means the valve has sunk
    into its seat because it's burnt...
    You're wrong there. You're flirting with burning a valve with
    clearances like 0.05 mm on an air-cooled motor. The valve head gets
    hot, the valve stem grows longer, your clearnaces get smaller...
    Really tight valves not only burn, the cam lobe gets worn excessively
    from the sliding friction of the rocker or inverted bucket tappet...
    I'd be using about a 0.003 inch feeler or a 0.004 inch feeler to set
    the valves, and see if that sounds too noisy when the engine gets hot.
    The exhaust valve typically has to be a bit looser than the intake
    valve, as the exhaust valve runs hotter. If the valves are too noisy
    hot at 0.003 inch, I'd try 0.07mm to see what that sounds like when the
    engine is hot...
    I know about 0.07mm being too tight for an exhaust valve, because I
    thought I could save myself the hassle of readjusting the valves on my
    GS-1100 if I set them at the minimum clearance. I figured the cam lobes
    would wear and the clearance would get looser. I was wrong. The valve
    seats eroded and the
    clearance got smaller as the valves burned. Sixteen new valves at $15
    apiece later...
    With screw type adjusters, the sharp tip of an adjuster screw with too
    much clearance will hammer a crescent-shaped divot in the top of the
    valve stem, making it difficult, if not impossible to adjust with a
    feeler gauge.
    There you have the range of problems you can run into with valve
    adjustments. You could still use a dial indicator to adjust divoted
    valves, though...
    krusty kritter, May 26, 2005
  8. Bad day at work, dear? ;-))
  9. A 'firm sliding fit' is what I set to.
    No jokes, please.
  10. Matt
    fweddybear Guest
    A good mechanic would gap them the proper way.....period....otherwise he
    ain't a good mechanic...
    Fwed
    fweddybear, May 26, 2005
  11. Matt
    Matt Guest
    Some code name for 'dumbass', I suppose.
    Matt, May 26, 2005
  12. Matt
    Matt Guest
    Thanks for your help. I have a feeler gauge.
    Not to upset you, but I think you missed the point that one turn is one
    millimeter. So two thou is 1/20 of a turn. Now maybe you see why I
    feel like I am splitting hairs with the tappet adjustment. By the way,
    a half a hair's breadth IS in fact rather close to 0.05mm, the spec for
    the intake tappet clearance.
    Thanks to all who indicated the danger of burned valves and worn cam
    lobes. I will be sure to not get the rockers too tight.
    Matt, May 26, 2005
  13. Matt
    Matt Guest
    I have one, and it set me back $6 the other day.
    Closest possible match to FFS at acronymfinder.com was "fumble-finger
    syndrome".
    Matt, May 26, 2005
  14. I normally figure if a guage will fit and the next size up
    (.0025" or .003" in your case) won't fit, I've got it right.
    Wyncha put a .002" guage under the tappet then tighten it down
    until you feel resistance then check it ?
    Rob Kleinschmidt, May 27, 2005
  15. The usual advice here seems to be "it should feel about as tight as
    inserting the blade between the pages of a phone book".
    big
    Iain Chalmers, May 27, 2005
  16. Matt
    the fly Guest
    No matter the accuracy of the thread pitch, or your accuracy
    in rotating the screw, it's all out the window when you tighten the
    lock nut.
    Like others here have written, I've found it helps to use the
    "Go, No-Go" method. When you think you have it set, try a feeler
    gauge .001" thicker. (Actually, it probably WILL go through, but
    you'll know it's too tight if the adjustment is correct).
    You really can "feel" a thousandth of an inch.
    the fly, May 27, 2005
  17. *Nice*
    And true.
    The Older Gentleman, May 27, 2005
  18. Matt
    Matt Guest
    Hmmm ... the manual says, "NOTE: The checking or adjusting of the tappet
    clearance should be performed while the engine is cold. The clearance
    may tend to increase as the temperature rises."
    Matt, May 28, 2005
  19. That part is true.
    I think they are trying to say that if you set your valves when the
    engine is hot, you may notice that the valves are noisy when the engine
    is cold. You don't run your engine cold for very long...
    The manual for my Nissan pickup truck specifies adjusting valves when
    the engine is *hot*...
    You absolutely must have some valve clearance when the engine is hot,
    regardless of any temporary clatter when the engine is cold...
    Heat makes metal parts expand. The valve head gets hot, heat transfers
    to the valve stem, which gets longer, taking up what little clearance
    you have between the end of the valve stem and the threaded adjuster's
    tip...
    When the valve clearance is gone, the valves cannot seat, they cannot
    transfer heat to the valve seat, so they get even hotter. The valve
    head expands until it does touch the valve seat. But it is so hot from
    the lean mixture that results from valves that don't seat properly, it
    momentarily *spot welds* itself to the valve seat...
    When the valve is pushed open again by the cam and rocker, that tiny
    spot weld breaks loose, tiny bits of cherry red hot glowing steel fly
    out the exhaust part. When a mechanic inspects the valve, he notices
    that the seating margin (which should look smooth and shiny) looks like
    mice have been chewing on it...
    I have a Clymer manual here for the earlier 250cc to 305cc Honda twins
    that were built from about 1959 to 1968, when a new generation of twins
    was introduced. My Clymer manual specifies 0.10 mm for both intake and
    exhaust valve clearances...
    I find it very hard to believe that you could run an air cooled
    4-stroke with only 0.05 mm valve clearance without having the valves
    expand and take up that tiny amount of clearance and burn...
    krusty kritter, May 28, 2005
  20. Matt
    the fly Guest
    Early Yamaha XS-2 650s specified .002" clearnace, cold, for
    both inlet and exhaust. I know of several that ran reliably for quite
    a long time.
    the fly, May 28, 2005
