Short-arse seat mod in Melb
Discussion in 'Australian Motorcycles' started by Rod Bacon, Sep 30, 2005.
  1. Rod Bacon
    Rod Bacon Guest
    Believe it or not, I need to get a seat "thinned" on my 4-year-old's
    PeeWee 50 clone. He has inherited his mother's legs, and as a result,
    can't reach the ground.
    Can someone recommend someone in Melbourne who may be able to help, or
    alternately is it a hard job to do myself (I assume I just need to
    remove the cover and replace foam with a higher-density, thinner piece,
    then re-cover it?)
    Thanks in advance.
  2. Rod Bacon
    John Guest
    Rod,
    If the cover is glued on, just remove the cover and replace
    the foam - then glue cove back on - if stapled, remove staples - then
    glue the cover back on.
    Johno
    John, Oct 1, 2005
  3. Rod Bacon
    justAL Guest
    You could just shave some of the foam out from what's already there and
    anyway, aren't you being hard on the kid?
    He should have another 12 years of growth left in him.
    justAL
    justAL, Oct 1, 2005
  4. Rod Bacon
    Toosmoky Guest
    Tried platform shoes?...
    Toosmoky, Oct 1, 2005
  5. Rod Bacon
    Mad-Biker Guest
    I know a Chinese bloke who can lengthen the legs?
    Mad-Biker, Oct 1, 2005
  6. Rod Bacon
    Rod Bacon Guest
    I keep telling him to wait... but he's killing me! He wants to ride it
    NOW!
    I just found that I can buy a new seat for $47, so I'll go pick one up
    and start butchering.
    Rod Bacon, Oct 3, 2005
  7. Rod Bacon
    justAL Guest
    The other option is to get him some training wheels but they're $150. The
    wheels are held down by springs so he can still attempt cornering but not
    lose his balance.
    justAL
    justAL, Oct 3, 2005
  8. Rod Bacon
    Rod Bacon Guest
    I'll give that a miss...
    I bought a new seat today, for $47. This seat actually has harder foam
    in it. Looks like the extruded yellow stuff, rather than the softer
    "sponge" that the original has.
    This new seat should be more "toolable", so I'm going to try just
    re-shaping the original foam, rather than replacing.
    Other than a sharp knife, does anyone have any suggestions on what I
    could use to shave some of the foam away?
    Rod Bacon, Oct 4, 2005
  9. Rod Bacon
    J5 Guest
    hmm ,
    Jigsaw ?
    blowtorch ;)
    J5, Oct 4, 2005
  10. Rod Bacon
    sharkey Guest
    Sarcasm.
    Or try a hot wire cutter ... you can make one out of a bit of resistance
    wire and some bits of wood as a frame. Google for it.
    -----sharks
    sharkey, Oct 4, 2005
  11. Sneak into the kitchen and swipe the electric carving knife - works a
    treat on foam (just don't let the missus catch you...)
    big
    Iain Chalmers, Oct 4, 2005
  12. Rod Bacon
    Seconded!
    Knobdoodle, Oct 4, 2005
  13. Rod Bacon
    They're a ripper for cutting polystyrene...
  14. Rod Bacon
    GB Guest
    Thirded. So much so that it's a running joke in my immediate
    family. If the electric knife ain't working to par, someone
    musta been carving mattresses with it.
    GB
    GB, Oct 4, 2005
  15. Rod Bacon
    Rod Bacon Guest
    Great! Thanks for that. I've since found a website that shows similar
    work being done, and they used a hacksaw and then a grinding wheel in a
    dremel to finish the shaping.
    I think I'll try the 'leccy knife instead of the hacksaw, and go the
    larger grinding wheel in the cordless drill.
