Shoei Pinlock visor insert dangers
Discussion in 'UK Motorcycles' started by Neillw001, Mar 6, 2006.
  1. Neillw001
    Neillw001 Guest
    Has anybody else had a problem with these things? I've been using one
    since just before Christmas as have now removed it as I can't see a
    thing at times in low morning sun. Pity, it really works well.
    The end came the other day when I nearly ran into the back of a w****
    v** that had stopped for no reason in the middle of a 40mph main road.
    I couldn't see it quiclkly enough as I was totally blinded by the low
    sun reflecting off the insert. I was wearing sunglasses as well. I
    didn't see any brake lights, but it is resonable to assume the lump of
    mobile scrap didn't have any. Luckily I had plenty of space and was
    nowhere near exceeding the speed limit, but the ABS still cut in.
    If you look at the pinlock instructions it says don't use them at
    night, something I've never had a problem actually, but have now
    removed the as I believe they are dangerous to use in daylight. In fact
    I've cut it into two pieces and thrown it away in case I'm ever tempted
    again.
    Neill
  2. Neillw001
    BGN Guest
    I've never suffered from any of the problems you have mentioned and
    have used it throught the night and from dusk until dawn.
    To qualify this I should say that I travel to work into the East (into
    the sunrise) and travel back home West (into the sunset) as well as
    during daylight hours and at night.
    Were you wearing Polarized sunglasses? I must admit that with my
    Polarized Oakley Monster Dogs
    <http://mi.oakley.com/site/media/cache/43a1aa4c1ef07.png_0_0_0.jpg>
    they do show up rainbow patterns on my Shoei fog shield (and one often
    has difficulty looking through most plastic LCD displays and anything
    else that is polarized) which can be distracting but I can't say that
    I've ever felt blinded by the pinlock.
    BGN, Mar 6, 2006
  3. Neillw001
    Eiron Guest
    Having given this much thought, I have come to the conclusion that
    Neill is a wanker and should join the IAM immediately.
    Eiron, Mar 6, 2006
  4. Neillw001
    Neillw001 Guest
    They are polarixed and I also used to get the rainbow effect when I
    used a Fogshield a few years back. Someone once told me the pinlocks
    can produced a flashing effect when there is low sun coming through
    trees or similar at the side of the road. I've noticed the blinding
    effect before but not until this happened did it seem a problem. I'm
    not sure whether is attributable to the constuction of the object, or
    the fact that it is merely a piece of translucent plastic.
    Neill
  5. Neillw001
    BGN Guest
    I personally feel that while polarized lenses are a fantastic
    invention, they're not good with the Shoei Pinlock fogshield. Even
    without the shield I found that they produced the same rainbow effect
    in my old standard HJC visor.
    I can't say that I've encountered that problem before or even heard of
    it, but I suppose it's down to the exact road, angle of the sun and
    weather conditions.
    The only other odd occurrence I've noticed happens on the edges of my
    Shoei Pinlock when I head in the dark of night towards Rye. There are
    trees down both sides of this long, straight, very fast and normally
    empty road with a few miles of fields either side but with lights from
    a village in the far distance which line up with the periphery of the
    Pinlock system edge on the right of the visor and produce the illusion
    of a kind of explosion or light show going on. It was distracting for
    the first couple of trips but after that I've come to expect it.
    Out of interest, have you taken your Pinlock off before? I had mine
    fitted by the salesman in Bikes of Brighton in the middle of last year
    when I bought my Shoei X-Spirit
    (<http://www.customlids.co.uk/helmets/shoei/x-spirit/SHAKEY.jpg> but
    in Black) and have never had cause to wish to remove it no matter what
    the weather which means that the seal on it is still very good. It's
    even left on when I clean the visor (cloth). I imagine that if one
    kept removing and reattaching it plenty of dust would get sealed in
    which would give an opaque area for the sunlight to illuminate causing
    what you've described?
    I've heard only positive things about the Shoei Pinlock system apart
    from Mr. Auvache who had a problem with soot or dust or some other
    stuff leaking through the seal (IIRC) but YMMV. I notice from your
    timezone that you're GMT -8. I don't know if the Merkin Shoei Pinlock
    system is any different to the European.
    BGN, Mar 6, 2006
  6. Neillw001 wrote
    Not in the way you describe.
    I have used pin lock in the past and found it fine. My only real
    criticism of it was very fine scratches that accumulate around the very
    edge of the insert over *time*[1]. A fine product if you like that sort
    of thing.
    [1] Not the pathetically tiny mileages that the dry miles only crowd
    think is riding.
    steve auvache, Mar 6, 2006
  7. BGN wrote
    Polaroid filers will do that to most visors.
    I suspect it was ordinary road dust of the type that drips on the floor
    and forms a nice red/brown film underneath where you hang your leathers
    when they are wet.
  8. In uk.rec.motorcycles, Neillw001 belched forth and ejected the
    following:
    Are you sure it's the visor and not your eyesight?
    Whinging Courier, Mar 6, 2006
  9. Neillw001
    dwb Guest
    Neillw001 wrote:
    I've had a Fogcity (similar sort of thing) for ages. I've had the
    problems at night - reflection, but can't say I've ever had the issue
    you had in sunlight.
    Maybe you just had a freak moment involving the angle, the light and
    some other things?
    You could argue your mirrors are dangerous because they could blind you
    too - would you cut those off?
    dwb, Mar 6, 2006
