Shims
Discussion in 'Australian Motorcycles' started by Philip Las Gourgues, May 19, 2006.
  1. Hi Everyone,
    I'm going mad chasing some 13mm (or 1/2") I.D. x 0.5mm (or 1/64") shims.
    I need them to space some bearings so I'm not even too worried about the
    thickness. Anything less than 1mm and more than 0.1mm would be fine but
    around the 0.25-0.5mm would be perfect. If it works out 28mm (1-1/8")
    would be ideal for the O.D.
    Anyway I've chased every bearing shop, engineering shop and a few
    motorbike shops but can't find anything at all. During some searching on
    the web I found that suspension shims should be available in the right
    size but haven't had any luck yet.
    Does anyone have any ideas where I could get these from? If they're
    available in Brisbane that would be great but I'm so frustrated I'd get
    them ordered from Siberia at the moment. The only place that has even
    been able to help is a laser cutting place but I'm not paying $60 for 10
    washers that should be a few cents each.
    Any help would be much appreciated,
    Phil
  2. Philip Las Gourgues
    J5 Guest
    J5, May 19, 2006
  3. Philip Las Gourgues
    FuTAnT Guest
    FuTAnT, May 19, 2006
  4. Ring Chris at precision shims on
    03 97230199
    0438230199
    Email chris @precisionshims.com.au
    Anthony Horan, May 19, 2006
  5. Philip Las Gourgues
    T.J. Dunster Guest
    What about making them out of feeler gauges?
    T.J. Dunster, May 19, 2006
  6. Philip Las Gourgues
    Smiley Guest
    Hi ya Phil
    I can supply you with some disc springs. they are .4mm thick with a
    ..8 mm free height. they have a 14.3 mm hole and are about 23mm in
    diameter. If you wish to get different sizes give me a call. Phone number
    on web page
    Thanks.
    David
    Aussie Discs
    http://www.aussiediscs.com.au
    Smiley, May 19, 2006
  7. Spring washer shims!
    Do you offer an ausmoto discount off your advertised price for discs and if
    so how much, Smiley?
    Pisshead Pete, May 19, 2006
  8. Philip Las Gourgues
    Uncle Bully Guest
    I have to say, these shim things get a bit of a mention on this NG, but what
    the hell are they?
    I've never needed to what they are until now and I'm sure I could live my
    whole life happily without ever knowing, but curiosity is getting the better
    of me.
    Anyone? (I appreciate that I could google or wiki it, but I prefer the
    aus.moto explantion please)
    Uncle Bully, May 19, 2006
  9. Philip Las Gourgues
    Marty H Guest
    oh you want the aus.moto explantion?
    everyone on the the count of 3......
    1
    2
    3
    www.fuckinggoogleit.com
    hth
    MH
    (that will teach you for xposting)
    Marty H, May 19, 2006
  10. Philip Las Gourgues
    Pre-op transsexuals.
    It's an abbreviation of "she" and "him".
    Shim.
    Knobdoodle, May 19, 2006
  11. Philip Las Gourgues
    Smiley Guest
    Hi Pete
    Yes I do offer Discounts on the parts I sell. I offer upto
    20% off for ausmoto people.
    David
    Aussie Discs
  12. Philip Las Gourgues
    Kevin(Bluey) Guest
    Try Blackwoods industrial supply , you should be able to get sheet shim
    material in brass or steel .
    Kevin(Bluey), May 20, 2006
  13. Philip Las Gourgues
    GB Guest
    Do you do AS approved braided lines? 1996 YZF1000RJ, front
    and back?
    GB, not the Dart^H^H^H^H R1
    GB, May 20, 2006
  14. Philip Las Gourgues
    Smiley Guest
    I'll have to get back to you on this. I don't have them yet but I know
    where I can get them from. I have to look into it on Monday for you.
    Thanks.
    David
    Aussie Discs
    Smiley, May 20, 2006
  15. As said before, they're basically washers used for spacing. You can
    also get Shim that are "layered" (sort of lamenated), basically you
    peel the layers off until you have the desired width. There is an
    other type of Shim but you don't normally find them in hardware stores
    and they're no good for spacing. :)
    __
    Cheers
    The Happy Drunk
    Do not meddle in the affairs of dragons, for
    thou art crunchy, and go well with Tomato Sauce.
    The Happy Drunk, May 20, 2006
  16. Philip Las Gourgues
    Whoops; confusing you with JustAl.
    Knobdoodle, May 21, 2006
  17. Philip Las Gourgues
    smack Guest
    JustAL is confused enough
    smack, May 22, 2006
  18. Philip Las Gourgues
    Theo Bekkers Guest
    "Uncle Bully" wrote
    A Shim is like a Smee, but the other person.
    Theo
    Theo Bekkers, May 23, 2006
  19. Thanks everyone. Sorry about the slow reply, was having news reader
    issues. I'll chase up the suggestions and see how I go.
    Thanks again,
    Phil
    Philip Las Gourgues, May 23, 2006
  20. Yeah, I thought about making my own. I can even buy the shim plate from
    heaps of places but how do you cut a concentric washer? I thought a hole
    saw would be pretty like to make a mess of 0.5mm sheet and laser cutting
    is way too expensive for such a small run.
    Thanks,
    Phil
