Shims, camchains and things
Discussion in 'UK Motorcycles' started by gazzafield, Oct 31, 2004.
  1. gazzafield
    gazzafield Guest
    I have now had my XJ600 since April and it has done 5,000miles in my
    incompetant hands. It has never had it's shims looked at in this time and
    god knows when they were done before I got it. I am a great believer in the
    "if it aint broke, don't fix it" school of thought.
    There will come a time in the impending winter when it will have to come off
    the road and be fettled with. I would like to do the shims then. Is this
    as fiddly as it looks? I have never done shims always having owned good old
    two strokes or shite old four strokes with screw and locknut tappets. (ah,
    them were the days).
    My understanding is that shims gaps don't get looser but tighten up and the
    valve can recede into the head. Is this right or just total bollocks? I'm
    also looking to do the camchain as the mileage is at 41,000 and rising and
    who knows if that's ever been looked at. I'm also of the better safe than
    sorry scholl of mechanics.
    I intend to fit a soft link camchain for minmal dismantling. Would this be
    a good time to get the shims done?
  2. gazzafield
    John Higgins Guest
    On Sun, 31 Oct 2004 13:05:35 -0000, "gazzafield"
    If the shoe fits...
    John Higgins, Oct 31, 2004
  3. Colonel Tupperware, Oct 31, 2004
  4. gazzafield
    gazzafield Guest
    Colonel Tupperware continued the witiicism with:
    I can see I'm going to get far with this post. I don't know, one poxy typo.
    At least it's all formatted correctly. Isn't it, Pip?
  5. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "gazzafield"
    Mostly right, but some engines don't go out of adjustment much. Slight
    valve recession and valve stem stretch, slight wear compensation on the
    bucket,shim and cam lobe (not too much, you'd hope) and if the engine
    isn't getting the nuts revved off of it on a regular basis all combine
    to negate the need for much adjustment. After the first shim adjustment,
    many engines hardly need looking at, depending on the treatment they
    get, which gives rise to the shoddy workshops not even bothering to
    check them.
    Too right, 41Kmiles is a long time for a camchain of unknown age.
    Certainly would.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Oct 31, 2004
  6. gazzafield
    Sean Guest
    Actually an easy enough job, providing you have a tame Yamaha dealer or bike
    shop to exchange the shims with.
    Recommend getting the bucket holding tool over the 'jamming the fucker down
    wiv a screwdriver' method. Won't cost you much.
    Measure each valves clearance, then remove, measure and replace each shim to
    get an idea of what ( if any ) replacements you require. Then go buy shims.
    Oh, get a rocker cover gasket while you are at it too. The one currently
    fitted will tear if you don't. If you buy a new one, the one currently
    fitted will be perfectly reusable.
    As you will have written down what each valve shim measures, when it comes
    to valve time again, you just measure the clearance and can select a shim.
    Thats right.
    Measure the link length as layed down in the HBoL. If its OK, just leave it
    alone. Camchains run in near perfect conditions. Of more concern is the
    tensioner mechanism. Make sure it works.
    If you really want to change the camchain, then yes.
    Sean, Oct 31, 2004
  7. gazzafield
    Well, sad to say it isn't really. It is very clear and
    understandable, just not laid out in the conventioanl style. You've
    made yourself a hell of a lot of work to achieve no more than the
    standard layout would manage. Not only that, but you have made it
    impossible to read conventioanlly, by erasing the indent marks against
    the names of the posters.
    Why don't you leave the attributions line(s) at the top and intact,
    letting your software do the work for you, then as much quoted text as
    is required to make sense of the thing, snip out what you don't want
    to refer to and leave it at that? There's lots of useful stuff on how
    to do it here: http://www.i-hate-computers.demon.co.uk/quote.html
    which is a link from the FAQ.
    Pip, Nov 1, 2004
