Set Phasers to "Slightly Annoying"
Discussion in 'UK Motorcycles' started by sweller, Mar 25, 2008.
  1. sweller
    I've just discovered why Kawasaki have a high beam light. Simply, it's
    so you know when you're on high beam as you'd never tell otherwise.
    With the MZs and Guzzi it's fairly obvious - as is the road, hedges,
    armco etc. To avoid doubt, they have excellent headlamps.
    In contrast the headlamp on the GT750 is fucking rubbish. So, what's the
    favoured non-maxpower bulb replacement.
    Whilst on GT750 news what sort of MPG would /I/ expect on a 100 mile
    round trip from Hove to Portsmouth and back?
    It's gone from full tank to one bar on the fuel gauge. I've yet to fill
    it up to get an accurate measure but I'd expect a good 40mpg (what the
    Guzzi would return on the same trip) but it seems to have guzzled the
    best part of 4 gallons.
    Or are the fuel gauges rubbish too?
  2. I generally averaged about 47mpg on it.
    They are. They stick at full for ages, and then drop like a stone.
    Then the flashing red light comes on and that will flash for bloody ages
    before it finally runs onto reserve.
    The Older Gentleman, Mar 25, 2008
  3. sweller
    Just by the sound of the tank its used more than two gallons.
    It didn't stick on full for ages (30 miles ish) but it did drop like a
    stone once it started.
    Hasn't started flashing yet - would I get 90 miles from one bar to move
    the tap reserve?
  4. sweller
    Eddie Guest
    Can't remember what I used to get, but it was pretty good.
    If you're thrashing it everywhere, expect worse.
    Something like this:
    http://groups.google.com/group/uk.rec.motorcycles/msg/37bd442b2fea789c
    Eddie, Mar 25, 2008
  5. sweller
    I definitely got mid-40s or more on mine, two up with luggage across
    France, at entertaining speeds.
    Not quite as bad as the one on the turbo, but still 'indicative' only.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 25, 2008
  6. I don't know how similar it is to my ZR-7 but I don't even bother
    looking at my fuel gauge. At some point it stopped ever reaching full
    and one can drive for many miles after the needle shows empty. I
    usually get to between 160 and 180 before putting it onto reserve, I
    usually refuel before it hits 200.
    I get about 50 mpg doing a mixture of mechanical sympathy and
    enjoyable riding. According to one site I saw, a GT750 is capable of
    60 mpg (user figure, not official).
    the man with no idea, Mar 25, 2008
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, the man with no
    That reminds me. I'm *fairly* sure the GTR's fuel gauge lies. It starts
    bleating "LOW FUEL! YOU'RE GONNA DIE!" too early, I think.
    I really must do the strap-a-can-to-me-and-see-when-I-run-out thing
    before we go to France.
    Wicked Uncle Nigel, Mar 25, 2008
  8. Check all the connections, and the state of the wiring for green crap
    inside the insulation, for the GT headlamp wasn't all that bad when
    newer. There's probably a drop of a couple of volts at the bulb. I'd
    rewire the h/l circuit via a relay using decent cable.
    For bulbs, the current crop of extra light 60W ones are quite good -
    Osram and Philips do ones that put out almost as much as a conventional
    100W.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Mar 26, 2008
  9. I'd have a good read of the owner's manual before you do. Don't some of
    these FI bikes require a certain procedure to be followed if you run
    them totally dry?
    Actually, I suppose not, otherwise they'd never get them off the
    showroom floor.....
    I was thinking of the early Z1000H FI bike, which needed a full 30-40
    seconds on the starter motor to pressurise the system.
    The Older Gentleman, Mar 26, 2008
  10. Capable, sure, if you drive it everywhere at a steady 70mph.
  11. sweller
    Diesels have to be bled and the pumps don't like running without
    lubrication but there isn't a special procedure on the Turbo or my Saab.
    The Turbo - which would, I imagine, use the same or similar system as teh
    Z1000 just pressurises itself when it 'boots'. No relation to to the
    starter motor.
    sweller, Mar 26, 2008
  12. sweller
    Any particular models or ones to avoid?
  13. sweller
    Eddie Guest
    Not on the ones I've owned.
    It's not something to be done on a regular basis, because it's not good
    for the injectors, but a one-off experiment shouldn't hurt.
    Eddie, Mar 26, 2008
  14. I'm using Osram Silverstar 60Watters on two vehicles - xenon filled and
    they certainly do what they claim, which is 50% greater light output
    from the same wattage, so approximating 100Watters. I know this to be
    true because I had 100W bulbs in but was a bit worried about
    cabling/switchgear [1]; when I put the Silverstars in there was a slight
    light reduction from before. After a few hours use the light output rose
    noticeably to at least equal the 100s.
    [1] You wouldn't believe how skinny the headlamp wiring is on modern
    Fords; cheapskate bastards.
    GS850x2 XS650 SE6a
  15. sweller
    no idea man Guest
    Am I missing something here? Surely when WUN does his test he'll keep
    going till it splutters (as you do before switching to reserve) and
    then pull over and fill up - as opposed to just keep riding till it
    falls over due to being bone dry.
    no idea man, Mar 26, 2008
  16. sweller
    I'll endorse the Silverstars too. I put them in everything, now.
    Ditto Suzuki. An 80/100W bulb in the RF headlight melted the wiring
    and had a good go at the plug, too.
    Pip, Mar 26, 2008
  17. sweller
    JB Guest
    Until very recently, the Silverstars were the vest of the retrofit crop of
    high lumen output lamps and I also use these on all of my vehicles. Osram
    have now launched the "Nightbreaker". Typically >90% more lumens than a
    standard lamp.
    Oh yes I would. A friend has an ST220 which ate the loom under the sircon
    unti recently. This is an 'interesting' location to access too.
    I think he needs a gynacologist rather than an auto electrician.
    A very common result when twice the current is stuffed through wiring of
    marginal cross sectional area.
    JB
    JB, Mar 26, 2008
  18. sweller
    Oh twould be a fun push to the petrol station too
    Hog, Mar 26, 2008
  19. That'll be what I was missing, among other things.
    the man with no idea, Mar 27, 2008
  20. sweller
    It seems to be doing 35 mpg at motorway speeds (90 ish).
    sweller, Mar 28, 2008
