Sedan run photos.
Discussion in 'UK Motorcycles' started by Salad Dodger, May 1, 2005.
  1. Salad Dodger
    Salad Dodger Guest
    Liberal[1] spray of Cillit Bang, quick go over with the brush on the
    hose, then a brisk jetwash, and it's good as new.
    I suppose I should have leathered it down, and polished it, but clean
    was deemed "good enough for now".
    [1] Bit of politics, very topical.
    | ___ Salad Dodger
    |_\_____/_| ..75073../..18420.../..3184./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, May 2, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Sticky little fuckers, those Froggie flies. I've got most of them off by
    use of the "damp cloth" method.
    I've also discovered that the poxy fucking bastard **** of a misbegotten
    fuel tank still has some loose crap floating around. Because it was
    blocking the fuel tap. Again.
    Arse.
    All cleaned out, new fuel filter fitted, the problem will now go away.
    *sob*
    and Ducati Race Engineer.
    Wicked Uncle Nigel, May 2, 2005
  3. I got them off with the paying Jennifer a fiver method. I must give
    her credit for trying for an hour to get it Adie standard clean. Every
    time she came in to get me to go and inspect it She exclaimed 'where
    did you find that' when I stuck my finger in somewhere to find muck
    [1]
    I went out when she had given up and washed the few places she'd
    missed. took me five mins as opposed to the couple of hours it would
    have done.
    [1] not that one.
    Adie
    Triumph 955iSS / GSF1200 bandit / CG125
    Adrienne M Bonwick, May 2, 2005
  4. Salad Dodger
    Salad Dodger Guest
    My "clonking" has come back again.
    Fairing off at the weekend, then.
    Together with the rear wheel, and drive shaft.
    Apart from that, a potentially notchy steering stem, and a completely
    fucked clutch[1], it's fine.
    I think I'll get one of those hydraulic lift thingies at MachineMart
    on Sunday. Save all that bending nonsense.
    **** it, I'll do the lot.
    <prepares "Breaking GL1500, all parts available" post>
    [1] It slipped more times on Saturday, than the last two years put
    together.
    | ___ Salad Dodger
  5. Salad Dodger
    Salad Dodger Guest
    Two.
    No.
    Too.
    The wheel needs swapping, cos of that fucking lumpy Avon.
    While it's off, I might as well swap the drive shaft over.
    The fairing and head stock will take minutes (I'm quite well practiced
    by now).
    The clutch has been on the work bench for over two years - if I don't
    fit it soon, I never will.
    It really got intolerable on Saturday - every time I hit a bump in the
    road, I lost drive. Not ideal when leading other bikes.
    If I get bored, I'll fit the air horns, spotlights, and get the Rings
    of Fire going.
    | ___ Salad Dodger
  6. Salad Dodger
    Salad Dodger Guest
    Well, strictly speaking, there should be no expense involved in this -
    except 4 litres of oil.
    | ___ Salad Dodger
  7. Salad Dodger
    Salad Dodger Guest
    <checks recent payslip>
    Three-quarters of ****-all per hour.
    It's not as if I was likely to be doing anything interesting instead.
    | ___ Salad Dodger
  8. Salad Dodger
    Salad Dodger Guest
  9. Salad Dodger
    Eh? What?
    The multi-coloured mess on the front of my bike is a hard-earned multi-
    coloured mess, and it's staying on there as a badge of honour.
    Between that and the gaffer tape, it's wearing its scars with pride.
    ogden, May 2, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    Yes. You don't have to look through your screen, do you?
    Pride? Have you talked to it about this?
    Fear is the word that would spring to mind. Or possibly resignation.
    Still, we shouldn't anthropomorphise motorbikes.
    They hate it when we do that.
  11. Salad Dodger
    Muck, May 2, 2005
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
  13. Salad Dodger
    *sigh*
    <fx: reviews big list of work to be done>
    Muck, May 2, 2005
  14. Salad Dodger
    Salad Dodger Guest
    I *couldn't*, by the time I got home.
    | ___ Salad Dodger
  15. Salad Dodger
    I tried a few times while on the return leg of the A26, but my neck
    doesn't seem to bend to that angle.
    Looks pretty though :)
    ogden, May 3, 2005
  16. Salad Dodger
    Have you crashed it?
    sweller, May 3, 2005
  17. Salad Dodger
    Rolled off its sidestand. Twice.
    The ****.
    ogden, May 3, 2005
  18. Salad Dodger
    It's a gixxer thing.
    Champ, May 3, 2005
  19. Salad Dodger
    Jesu Christos - how big was the cloth??!!
    Champ, May 3, 2005
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Don't know what you mean squire, I just used an old pair of my
    underpants.
    Wicked Uncle Nigel, May 3, 2005
