Sealants and petrol
Discussion in 'UK Motorcycles' started by Ginge, May 30, 2004.
  1. Ginge
    Ginge Guest
    What kind of sealant can be used where petrol is involved?
    I guess silicone sealant isn't up to the job...
    Ginge, May 30, 2004
  2. Ginge
    tallbloke Guest
    Durko, or however it's spelt.
    tallbloke, May 30, 2004
  3. Ginge
    Dunno. What are you trying to seal?
    Dunno. Might be - or do you have empirical evidence that we ought to
    know about?
    Pip, May 30, 2004
  4. Ginge
    Ginge Guest
    I just want to put a blob of it round the petrol tap on the SZR, since I
    took it off and put it back on, it's got a very slight leak.. almost
    none.
    well I put some on (it was clear bathroom silicone sealant) and it sort
    of went a gooey brown, so I've assumed it's no good for the job.
    Off to Halfords now anyway to see what's on the shelves.
    Ginge, May 30, 2004
  5. Ginge
    Pal Guest
    You guess wrong.
    When cured, Silicon Sealant is fuel proof.
    Pal, May 30, 2004
  6. Ginge
    Ginge Guest
    Got some proper gasket stuff now, so I'll have the tap off tomorrow
    after emptying the tank, remake the gasket, and it'll be spiffy.
    What I now need to figure out is how whenever I go somewhere like
    Halfords, or a toolshop, I always buy more things than I need.
    Ginge, May 30, 2004
  7. Ginge
    David Thomas Guest
    Because you are the victim of a capitalist society?
    D
    David Thomas, May 30, 2004
  8. Ginge
    You post wrong(ly).
    In uk.r.m., please put your reponses below the text to which you are
    replying. Have a google for the FAQ.
    Pip, May 30, 2004
  9. Ginge
    tallbloke Guest
    Lol.
    Ginge could sell IT to the Indians.
  10. Ginge
    Ginge Guest
    semi-serious moment..[1]
    I ain't no shteeeening sales-weasel, nor will I ever be, unless I'm
    backed into a corner with no other means of escape.
    ....No, I'm the guy that trained the Indians to do the crap jobs nobody
    else wanted to do. And they love it, because they earn more than most
    people do out there... and it hasn't affected anyone's job here either.
    Sure, I'm part of a big capitalist nightmare, but personally I have my
    own set of lines which I will not cross.
    [1] Unusual for a Sunday afternoon, I know, but I'm tired and a bit
    grouchy after being called out at 3AM last night and not actually
    falling back to sleep until maybe 5... then waking up at 8, 9, 10, etc..
    Ginge, May 30, 2004
  11. It was somewhere around Barstow, on the edge of the desert, when the
    Silicone, as you may have found, tends to disintegrate on contact with
    petrol. What are you sealing - a gasket, flange, edge contact, pipe
    fitting?
    Whatever; you'll find better sealants on the shelf of your local motor
    factors. Hylomar is pretty good for gasket sealing on carbs; if you go
    down to a plumbing trade counter and ask for 'stuff for sealing fuel
    pipes' they'll give you a little-tub-wiv=a-brush-in which is rated for
    diesel and kerosene but also works quite well with petrol (this would be
    for threaded fittings).
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 30, 2004
  12. It was somewhere around Barstow, on the edge of the desert, when the
    Is it bollocks.
    GS 850 x2 / SE 6a
  13. Ginge
    Pal Guest
    Ok sorry.
    Pal, May 30, 2004
  14. Ginge
    Pal Guest
    Oh but it is, when cured.
    Pal, May 30, 2004
  15. Ginge
    Pip, May 30, 2004
  16. Ginge
    Pal Guest
    Oh, I've just read the FAQ and I am very sorry.
    I just can't apologise enough. Again, I am very, very sorry.
    Pal, May 30, 2004
  17. Ginge
    Porl Guest
    LOL, a troll is for life, not just Christmas.
    Have fun, Pip.
    Porl, May 30, 2004
  18. Wotcha.
    Bloody silicone !
    Guess who had to extract a "Silcone Slug" from out of his fuel line
    yesterday ?
    Well that'll be the cause of my mystery fuel starvation problem then.
    ^..^ Lone Wolf, May 30, 2004
  19. It was somewhere around Barstow, on the edge of the desert, when the
    You carry on believing that.
    Idgaf.
    Btw, if you're going to leap in with your ill-informed nonsense, please
    have the good grace to post at the bottom.
    GS 850 x2 / SE 6a
  20. Ginge
    Pal Guest
    That must be impossible according to the amazing Crimly Cuurmudgeon as
    silicon disintegrates on contact with petrol!
    Pal, May 30, 2004
