Screw extractors - as crap as they seem?
Discussion in 'UK Motorcycles' started by Dave Jennings, Jan 21, 2006.
  1. HSS taps have a useful property when broken in a non-blind hole. You can
    gas axe them out quite successfully, leaving the thread untouched. I
    discovered this when the print shop next door brought a roller into the
    workshop and nothing else was going to remove it (spark erosion, yes,
    but this was a Saturday afternoon). I told them I'd burn it out and
    couldn't guarantee the end of the roller would be undamaged but they
    said to go ahead anyway, it was worth a try.
    I got the tap to start melting, turned off the acetylene and let the tap
    burn away with just an oxygen feed. Bugger me; it vanished as clean as a
    whistle and all that was needed was a quick touch on the threads with a
    couple of taps and it was hunky dory.
    Grimly Curmudgeon, Jan 29, 2006
  2. Dave Jennings
    We often gas axe broken taps, especially small ones, using the method
    you've described. I use the MMA and high amps method on big taps when
    I've been a bit hasty with pneumatic tapping heads and dropped myself
    in the shit. I've beaten a 7.5" tap into submission like this and in
    the end it fell into about 4 nice sized chunks.
    Andy Bonwick, Jan 29, 2006
