Scratches on Stainless Steel muffler
Discussion in 'Australian Motorcycles' started by Phil S, Mar 17, 2007.
  1. Phil S
    Phil S Guest
    Has anyone got a method for removing minor to moderate scratches from a
    stainless steel muffler. A previous owner dropped the bike, and I would
    like to repair the damage if possible. Area about 5 x 5 cm at the start
    of one of the mufflers.
    Thanks Phil
  2. Phil S
    Biggus..... Guest
    - the moderate? dunno?
    Might make it worse trying to clean it up.. :(
    Biggus....., Mar 17, 2007
  3. Phil S
    atec 77 Guest
    Have it professionally buffed , anything you can do without the correct
    tools will end up as worse.
    atec 77, Mar 17, 2007
  4. Phil S
    Hugh Guest
    If you have a drill go to Bunnings tool dept and get a Jonsa polishing wheel
    set[$30].Has a medium & fine wheel,use medium for heavy scratches be careful
    with this wheel as it may create more scratches,use fine to polish scratches
    out,i use the fine wheel all the time to get rid of marks on my Staintunes
    made by my misuses boots.Finish with Autosol.Just remember it does take a
    while,Hugh
    Hugh, Mar 19, 2007
  5. Phil S
    Theo Bekkers Guest
    Does your missus hate your bike so much she has to kick it?
    Theo
    Theo Bekkers, Mar 19, 2007
  6. Phil S
    Phil S Guest
    Thank you. I will give it a go.
    Phil S, Mar 20, 2007
  7. Phil S
    Hugh Guest
    Well it is a Ducati :}
    Hugh, Mar 20, 2007
