[QUOTE="Mash"] Should fit Tone's mum quite loosely. [/QUOTE] Shut you nasty mouth.
You have get it all wrong. You use a turbine to take it up the the speed then you switch on the scram jets to make go super-sonic. Scram jets are better than using an after-burner, turbines cannot work with super-sonic air-flow.
It was somewhere around Barstow, on the edge of the desert, when the The credibility gap can be filled with the two-stroke steam engine of S.Ts design. I'm sure he can Mach 5, no problem. -- Dave GS 850 x2 / SE 6a SbS#6 DIAABTCOD#16 APOSTLE#6 FUB#3 FUB KotL OSOS#12? UKRMMA#19 COSOC#10
Jet fighters seem to manage.[/QUOTE] And all gas-turbines, even static ones, have internal flows _much_ faster than the speed of sound.
They have clever computer controlled spikes and doodads that move around, so the supersonic air coming in can be slowed and compressed in the plenum chamber in font of the engine, I think...
Ace expressed the following: And all gas-turbines, even static ones, have internal flows _much_ faster than the speed of sound.[/QUOTE] There is a chance that the airflow will be supersonic on the suction side of the compressor blade aerofoils though this can give problems, not least of which is innefficiency. You have to bear in mind that as the air is compressed the speed of sound is increased, so allowing for higher speeds as you move down the compressor without breaking the speed of sound. If you look at intake nozzle systems on supersonic aircraft, they are designed to control the speed of the airflow into the jet.
