Scottoiler oil
Discussion in 'UK Motorcycles' started by Mike, Aug 23, 2004.
  1. Mike
    Mike Guest
    Having nearly used up my Scottoiler oil, being a naturally tight old git
    I had a quick Google and found various suggestions for alternatives
    including EP90, chainsaw oil and old engine oil.
    Ignoring the jollity of actually having deliberately added something to
    a Triumph to make it dribble oil, has anyone on the grope any words of
    wisdom or experience on using non-scott oils?
    I'll take the "stop being tight and buy the proper stuff" reply as done,
    to save time.
    Mike, Aug 23, 2004
  2. Mike
    Mike wrote in
    I'd avoid old engine oil. It contains a lot of nasties that can cause skin
    problems and it will be more difficult to clean off the excess.
    I've used both EP90 and chainsaw oil in the past. I've also used
    Agricastrol and multigrade car oil.
    Use anything available. Sunflower oil would probably work and is
    environmentally friendly. A multigrade oil will keep to a fairly consistent
    viscoscity meaning theat you will not have to adjust the flow as often.
    I prefer chainsaw oil as it is anti-fling by nature. It is also very cheap
    from Makro, B&Q, agricultural merchants etc.
    wessie, Aug 23, 2004
  3. Mike
    Nidge wrote:
    and onto the side of your rear tyre. :/
    As you say, keeps the chain nice and clean and the rear tyre from
    rusting. :)
    Muck, Aug 23, 2004
  4. It was somewhere around Barstow, on the edge of the desert, when the
    Chainsaw oil is what you want - a fraction of the price of Snottoil if
    you buy it a gallon at a time.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Aug 23, 2004
  5. Mike
    Mike Guest
    I think I'll go with the chainsaw oil then - I'm not confident of my
    ability to ride and keep two oiled brushes against the chain at the same
    time.
    Mike, Aug 23, 2004
  6. Mike
    Mike Guest
    Sounds like the team agrees (as well as can be expected anyway) on
    chainsaw oil then. I'll have a look in B&Q on my way home, or maybe
    scrounge some through my neighbour (a tree surgeon) at trade prices.
    Thanks to all
    Mike, Aug 23, 2004
  7. Mike wrote
    This may have something to do with the oft quoted rumour than snotoil is
    nothing more than yer actual genuine chain oil with a bit of red dye in
    it.
    *Not* B@Q. Farm/agricultural/hoticultural machinery suppliers is what
    you want. Amazing the everyday stuff they hold at cheap cheap prices,
    especially the farm suppliers.
    steve auvache, Aug 23, 2004
  8. Mike
    Grimly Curmudgeon says...
    This is exactly what I do
    Lozzo, Aug 23, 2004
  9. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember steve auvache
    <ding>
    It's surprising where farm suppliers are to be found. There's lots of
    them around once you look for them.
    GS 850 x2 / SE 6a
  10. Mike
    PDannyD Guest
    So chainsaw oil is the preferred choice then. <makes note>
    What about something to carry spare oil but can also be used to fill the
    unit?
    So far I've been squirting oil in through the breather hole with a fine
    nozzled oil can but it's too big to be carried under the seat and would leak
    anyway.
    PDannyD, Aug 23, 2004
  11. Mike
    When I got my snotoiler, I also got a half-litre bottle of oil, which had a
    tube with a pointy little nozzle for filling the reservoir. I use this
    bottle for the chainsaw oil, and it works just as well as with the original
    snotoil.
    platypus, Aug 23, 2004
  12. Mike
    Ginge Guest
    Use chainsaw oil and turn the scottoiler down so it hardly drips any..
    I reckon a full scottoiler is good for around 1500 miles.
    Ginge, Aug 23, 2004
  13. Mike
    platypus wrote in
    IIRC Scottoiler will send you an adapted bottle cap with the filler tube
    free of charge. When on a long journey I re-fitted the original bottle
    cap and packed the filler tube separately to prevent leakage.
  14. PDannyD wrote
    Eh?
  15. Mike
    dwb Guest
    Shampoo bottle and a straw.
    dwb, Aug 24, 2004
  16. I've used scotoiler oil, engine oil and vegtable oil. All worked fine.
    Haven't tried used engine oil but am sure it would be fine.
    Nice way to get rid of old engine oil as well. Might save a few trips to the tip.
    Toad of Toad Hall, Aug 24, 2004
  17. Mike
    dwb Guest
    Um... have you thought that one through?
    You have to take it to the tip because (as far as I understand) it has to be
    disposed of in a particular way.
    Flinging it round the countryside, whilst disposing of it, isn't really very
    enviromentally friendly.
    But I suppose the same could be said of the normal oil used.
    Possibly vegetable oil is the way forward in that regard - not quite sure
    how well Tesco's best Sunflower would work, but can't really see why it
    wouldn't considering it's mainly cleaning the chain, rather than absolutely
    lubricating it.
    dwb, Aug 24, 2004
  18. Mike
    Oldbloke Guest
    I know Scottoilers are generally well thought of around these parts, but I
    really did not get on at all well with the one on my CB500, so I left it on
    the bike when I sold it.
    It used to just piss oil all over the back tyre, no matter what setting it
    was on, or it would lose the small black injector tube and dump it's entire
    contents rapidly all over the back wheel..
    I am now using an aerosol of Fuchs chain lube and guess what, it flings
    itself all over the back tyre also. Just as well I can't GMKD.
    Dan L (Oldbloke)
    M'boy's current bike 1990 Suzuki TS50X (Heavily fortified)
    M'boys NEW bike 2003 Honda NSR125R
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Aug 25, 2004
  19. Mike
    Eddie Guest
    Try a 50:50 mix of LM grease and EP90 gear oil, applied with a small
    paint brush.
    Eddie, Aug 25, 2004
  20. Mike
    Statto Guest
    I had similar problems with the Snottoiler on the VFR - a couple of
    e-mails to the Scottoiler people and they came to the conclusion that
    the RMV was FUBARed and needed replacing. £24 and a bit of fiddling
    around and normal, 2 drops of oil per minute service was resumed.
    Statto, Aug 25, 2004
