Scooter Soldering Kit Battery
Discussion in 'Motorbike Technical Discussion' started by Bob, Feb 9, 2009.
  1. Bob
    Bob Guest
    On Sun, 15 Mar 2009 18:08:13 -0700 (PDT), Schiffner
    |>So? He's right and you are full of shit mostly. I've two thumpres that
    |>idle at less than 1,300rpm. Ergo your full of it. For that matter I'm
    What year of yp400T? V? X?, mines a 2005, and idles as bad as the
    2003 skyliner 400, same bike same problem, but they said they counter
    weighted with a new crankshaft after the Yamy 2004 Twin generated strange
    error codes at the time...
    |>sure there are single 4stroks of UNDER 25cc that Idle around 1,100rpm.
    |>Naturally you'll say it is a lie...wont you francis.
    Single 4stroks of UNDER 25cc that Idle around 1,100rpm, SCOOTERS???.
    if the motor is used in an inverter for instance, then it can idle at
    800rpms, but a lawn mower will stall at 800rpms....
    Bob, Mar 16, 2009
  2. That's just *one* example. I've had four-stroke singles that idled quite
    happily at 1000rpm or thereabouts.
    What does this paragraph mean, exactly? Wtf is a Vino 1500cc when it's
    at home? Two bottles of red wine?
    The Older Gentleman, Mar 16, 2009
  3. But you said it was about four-stroke single engines?
    There weren't many four-stroke scooters around 30 years ago. Time for
    your meds, I think.
  4. Where has anyone denied that this one bike has a stalling problem? Feel
    free to point it out.
    It's just that some of us think you're an illiterate fuckwit with a
    Henry-like obsession.
  5. Bob
    Mac Guest
    Pot or kettle?
    Mac, Mar 16, 2009
  6. Bob
    Mac Guest
    Nah! Piggy's Clown is a psychologically disturbed Gulf War vet who
    *wishes* he was a Limey, or a Mongol, or a hobbit, or anything besides
    the emotional mess he really is.
    Mac, Mar 16, 2009
  7. Bob
    Mac Guest
    Yes, and they are *very* idle. They haven't run in years and are
    covered with spider webs in the garage.
    Mac, Mar 16, 2009
  8. Bob
    paul c Guest
    I believe lots of multi-cylinder bike engines are recommended to idle
    at 1400+rpm, such as a CB750 (not to mention lawn-mowers and
    chainsaws!). I had wondered if part of the reason had to do with
    carburetion, perhaps easier to adjust multiple jets on each carb. But
    I see that fuel-injected 400cc scoots like the Majesty and Burgman
    have similar idle speeds. If modern injected bikes have similar idle
    speeds then maybe my guess was bunk. For sure, most bike engines can
    be made to idle slower, but I can guess that when a CVT drive (no
    manual clutch) is involved, a higher idle speed will involve less
    start-up automatic clutch-lag. But I suppose similar reasons would
    apply to clutched bikes, the engines are usually much smaller than
    those in cars, don't have much torque below 2000 rpm so could stall
    more easily than a car when the clutch is engaged, so maybe it's all
    about rideability/safety.
    The only thing I know of that seems special about thumpers is that
    some of the larger ones need a decompression gizmo in order to start
    when cold.
    Interested to hear comments.
    paul c, Mar 16, 2009
  9. Bob
    paul c Guest
    It seems even a 400cc Suzuki Burgman has a 'decomp cam'.
  10. Bob
    ? Guest
    Idle speed sometimes depends upon cam timing and valve lift. Some hot-
    rodded I-4's need to idle as high as 1800 RPM to keep from stalling.
    RPM is an average, it's not consistent.
    Setting the idle up from the typical 1100~1200 RPM will quiet down the
    cam chain which is under considerable difficulty as the revolution
    speed of the individual stokes actually does vary.
    My KLR600 has an automatic exhaust valve lifter which will engage and
    stall the engine with a loud CLACK! if the idle RPM drops below about
    1300 RPM
    ?, Mar 16, 2009
  11. You believe wrong.
  12. Bob
    paul c Guest
    richard cortese wrote:
    Yes, I think my memory was bad, could have been something just over
    1000 rpm for an '82.
  13. Bob
    paul c Guest
    Thanks, those are much more obvious reasons than the ones I thought of.
  14. Bob
    ? Guest
    Typical Piggy troll...
    ?, Mar 16, 2009
  15. Bob
    paul c Guest
    From a haphazard scan of Clymer Motorcycle Data, years 1988-2000, it
    looks like there are only a few above 1200+/- 100 rpm, and fewer at
    1400, such as the California model of CBR600, a few 650 Suzukis, BMW
    650, so mostly thumpers and all carbureted. The FI models of the same
    bike have idles 100 or 200 rpm lower. (Ignoring the larger CVT scoots
    which are all 1400 or more.) Below 350cc there are many thumpers with
    high idle rpm's, some as much as 1900rpm, which agrees with the small
    flywheel reason, although I guess some people would call them sewing
    machines, not thumpers.
  16. Nope. Just fact. One of my fours has a recommended idle speed of 950rpm,
    as it happens.
  17. Thank you. Dear old Krusty can't get anything right.
  18. Bob
    paul c Guest
    paul c wrote:
    I guess another reason for higher idle speeds than cars could be to do
    with the relatively weaker charging systems on bikes, smallish
    alternators turning at crank speed usually.
    paul c, Mar 17, 2009
  19. Bob
    Schiffner Guest
    Actually you juvinile junkie...your fantasies and desire for man flesh
    isn't my problem. Not to mention your weak chickenhawk style was more
    appropriate in the late 60's.
    Schiffner, Mar 17, 2009
  20. Bob
    R. LaCasse Guest
    |>> Let's say a Vino 125cc needs 1500cc and 1650ccs when broken in, look
    |>> it up it's on google somewhere just like all the stuff I said and you
    |>> denied...
    Right, my *boob* I meant 1500rpms-->1650rpms after break-in.....
    R. LaCasse, Mar 17, 2009
