Scooter Soldering Kit Battery
Discussion in 'Motorbike Technical Discussion' started by Bob, Feb 9, 2009.
  1. Bob
    Schiffner Guest
    Only on cold days...cold being UNDER 35F. Well that's my definition,
    what would I know I've installed AC compressor units when it was 25F.
    Getting the torch lit was the hardest part as the winds were a good
    bit over 25mph that day. 8^(
    Electric soldering irons shouldn't be bothered on windy days unless
    it's damn cold.
    Schiffner, Feb 22, 2009
  2. Bob
    ian field Guest
    it's damn cold.
    Temperature controlled soldering irons should cope unless its *BLOODY* cold,
    the cheaper ones with no thermostat are regulated (of sorts) by a positive
    temperature coefficient in the resistance wire the element is wound with. As
    the element heats up it's resistance increases so the current draw levels
    off, conversely if its cooled the resistance reduces increasing the current
    draw.
    ian field, Feb 22, 2009
  3. Bob
    paul c Guest
    ian field wrote:.
    I reckon butane would be better for warming my fingers, wrap some heat
    tape around them I guess (assuming the purpose is to repair the wire
    to handgrip heaters, ha ha).
    paul c, Feb 23, 2009
  4. Bob
    R. LaCasse Guest
    |>|>|>Bob wrote:
    ---------------------------snipped------------------
    |>|> That Garage door is an old system, but all the others are newer and
    |>|>don't affect me at all since the use more IR/Photo sensors....
    |> The only fix there usually is, is to raise the idle "ISC" speed,
    |>and the ECU/ECM doesn't do that, as a matter of fact unlike most things of
    |>the ECU concerns, the IDLE SPEED is the only thing that CAN'T be Changed...
    GOOGLE SEARCH
    Yamaha Majesty stalling ECU stall 400 yp400:
    (http://majestyusa.com/forums/viewtopic.php?t=758&postdays=0&postorder=asc&highlight=stall&start=15)
    (http://www.maxi-scoots.com/postnuke/index.php?name=PNphpBB2&file=viewtopic&p=67998)
    (http://majestyusa.com/forums/viewtopic.php?p=24682&sid=c0e70e3df7753fe0c0673f8a70e5fd57)
    (http://www.allworldauto.com/comments/yamaha_majesty_comments_and_complaints_109-35494-1.html)
    NOT so much this version of the Stalling problem:
    (http://justscoot.blogspot.com/2008/04/yamaha-safety-recalls-morphous-majesty.
    html)
    COPERNIC AGENT SEARCH RESULTS (no google)
    Search: ECU Yamaha Majesty 400 stalling stall (All the words)
    Found: 15 result(s) on The Web
    Date: 02/23/2009 1:41:15 AM
    1. Maxi-Scooters! :: View topic - Yamaha Majesty stalling problem
    Well, they ended up replacing the ECU and that fixed it perfectly.
    .... It's not going to stall again. I have an 06 model that never stalled.
    http://www.maxi-scoots.com/postnuke/index.php?name=PNphpBB2&file=viewtopic&t=5443
    87%
    2. MaxMoto - Message Board
    Mana now in main agent as the ecu has gone belly up keep hearing
    ...... Then, I started losing power at take off, stalling at slow speed, and
    rough idle. ...... I'm moving from a Yamaha Majesty scooter so the whole
    thing felt ...... had gilera 180/ suzuki 4
    http://www.maxmoto.co.uk/cgi-bin/maxmoto/msboard.pl?subject=Gilera_Ferro
    87%
    3. MaxMoto - Message Board
    terrible reports on poor aprillia replacement parts service,so watch this
    space. cheers jim ... Then, I started losing power at take off, stalling at
    slow speed, and rough idle. Mana is in th
    http://www.ask.com/bar?q=ECU+Yamaha...i-bin/maxmoto/msboard.pl?subject=Gilera_Ferro
    85%
    6. Discover the best world
    Yamaha carburetor jets yamaha majesty 400 top speed yamaha fazer
    stats yamaha ... Yamaha performance ecu. Yamaha mikuni carb identification.
    Yamaha motorcross helmet. ...
    http://hhlivefreemedia.com/11/0.html
    49%
    7. Maxi-Scooters! :: View topic - Yamaha Majesty stalling problem
    http://www.maxi-scoots.com/postnuke/index.php?name=PNphpBB2&file=viewtopic&p=68186
    49%
    9. MajestyUSA: Yamaha Majesty Enthusiasts :: View topic - Backfiring
    Probably somewhat related to the stalling/ECU issue. ... 2006
    Burgman 400 Type S "Ceruleus Angelus" 2005 Yamaha Majesty- Galaxy Blue "His
    Majesty" ...
    http://majestyusa.com/forums/viewtopic.php?p=16492
    48%
    10. ScootDawg Scooter Forum - Took Delivery of my 2005 Majesty!!
    I have scheduled to take it to the dealer for the recall, including
    the ECU, this Friday. ... What I mean by stalling is actually dying. I come
    to a stop light ...
    http://scootdawg.proboards59.com/index.cgi?board=200cc&action=display&thread=16336&page=2
    42%
    12. Maxi-Scooters! :: View topic - Tell me the negative points.
    I have never had a Yamaha sport bike with carbs stall on me, ever.
    .... 2005 Yamaha Majesty 400. dandrewk - Oct 02, 2006 - 10:11 AM. Post
    subject: ...
    http://www.maxi-scoots.com/postnuke/index.php?name=PNphpBB2&file=printview&t=104&start=45
    36%
    13. www.BurgmanUSA.com • View topic - Burgman 400 Review (Aussie-spec
    model)
    ... Control Unit which caused very occasional stalling, but this
    was fixed by a recall. ... What about the Yamaha Majesty 400? ...
    http://burgmanusa.com/forums/viewtopic.php?t=23404
    33%
    14. 1991 CHEVROLET BERETTA User Comment / Complaint
    2005 yamaha majesty flutters, stall and turns itself off
    periodically with no warning. ... the scooter used and the stalling
    occurred the second week i had ...
    http://www.allworldauto.com/comments/1991_chevrolet_beretta_comments_and_complaints_5783.html
    29%
    15. Soccerphile Football | Soccer Blog: June 2008
    skip to main | skip to sidebar ... Monday, June 30, 2008 ... All
    hail the reign of the beautiful Spain...
    http://www.ask.com/bar?q=ECU+Yamaha...cerphile.blogspot.com/2008_06_01_archive.html
    23%
    R. LaCasse, Feb 23, 2009
  5. Bob
    Schiffner Guest
    SNIP
    <innocent look> wot are those and who needs 'em. Use Hippo hands r bar
    end covers of somebrand or other. Good for all day at 70+ @ 22F...not
    that I'd do such a thing on the plains of Montana.
    Schiffner, Feb 24, 2009
  6. Bob
    ian field Guest
    PHucker has a hot air problem!
    ian field, Feb 25, 2009
  7. You are talking utter rubbish. Take your grudge match elsewhere because
    nobody's interested here.
    The Older Gentleman, Mar 15, 2009
  8. If this illiterate diatribe is the sort of thing you sent to Yamaha, no
    wonder they ignored you.
    I bet you wrote in purple crayon, as well.
    As for ng dictator - what has that got to do with you telling the world
    that all singles won't tick over at less than 1600rpm? That was, and
    remains, rubbish.
  9. Bob
    Schiffner Guest
    yeah and he's full of it about single cyl idle rpm. Utter crap aamof.
    Schiffner, Mar 16, 2009
  10. Bob
    Schiffner Guest
    So? He's right and you are full of shit mostly. I've two thumpres that
    idle at less than 1,300rpm. Ergo your full of it. For that matter I'm
    sure there are single 4stroks of UNDER 25cc that Idle around 1,100rpm.
    Naturally you'll say it is a lie...wont you francis.
  11. Bob
    Schiffner Guest
    SNIP
    Utterly untrue adn it's a load of fetid dingos kidneys also.
  12. Bob
    Mac Guest
    Except you. Your life's work is following endless inane threads.
    Mac, Mar 16, 2009
  13. Bob
    Mac Guest
    Too late, Piggy seized power in this NG ten years ago and defends it
    with a sharp-tongued wit.
    Mac, Mar 16, 2009
  14. Bob
    Mac Guest
    Mac, Mar 16, 2009
  15. Bob
    Bob Guest
    On Sun, 15 Mar 2009 18:08:13 -0700 (PDT), Schiffner
    Yamaha yp400ts only idle at 1300/1500rpms and that can get iffy in
    4stroke single..
    Let's say a Vino 125cc needs 1500cc and 1650ccs when broken in, look
    it up it's on google somewhere just like all the stuff I said and you
    denied...
    Bob, Mar 16, 2009
  16. Bob
    Bob Guest
    On Sun, 15 Mar 2009 18:09:18 -0700 (PDT), Schiffner
    |>>         I swear any Single Cylinder 4 Stroke, needs a good 1600rpms to IDLE
    |>> properly and reliably.......some need even more.
    Ya got a real mouth for a keyboard......limy!
    Bob, Mar 16, 2009
  17. Bob
    Bob Guest
    |>> On Sun, 15 Mar 2009 12:06:25 +0000, (Piggy) wrote: (snip)
    |>>         Don't appoint yourself as a usenet NG dictator till you pay your
    |>> bills to the fuhrer of lloyds of london....which at last glance were well
    |>> over 400 trillion pounds below BEP....
    I was here 10 years before that.......so what....this is not about
    fanning your tail feathers, this is a bout getting the facts right about
    scooters....
    If you don't remember, I been driving them for 30 years, I do my own
    work when I have the room!
    Bob, Mar 16, 2009
  18. Bob
    Bob Guest
    On Sun, 15 Mar 2009 18:05:55 -0700 (PDT), Schiffner
    |>On Mar 15, 6:06 am, (The Older
    So you still denying ALL of this like Piggy....fine:
    GOOGLE SEARCH
    Yamaha Majesty ECU 400 yp400** stalling:
    html
    COPERNIC AGENT SEARCH RESULTS no google
    Search: ECU Yamaha Majesty 400 stalling stall All the words
    Found: 15 results on The Web
    problem
    perfectly.
    87%
    hearing
    and
    87%
    hearing
    at
    http://www.ask.com/bar?q=ECU+Yamaha+Majesty+400+stalling+stall&page=1&qsrc=0&zoom=What+Does+
    <KW>ECU</KW>+Stand+for|<KW>ECU</KW>+Repair|<KW>ECU</KW>+Chips&ab=0&u=http://www.maxmoto.co.uk/cgi-bin/maxmoto/msboard.pl?subject=Gilera_Ferro
    85%
    yamaha fazer
    identification.
    49%
    problem
    perfectly.
    49%
    Backfiring
    2006
    "His
    Majesty" ...
    48%
    Majesty!!
    including
    come
    to a stop light ...
    42%
    points.
    me, ever.
    subject: ...
    36%
    13. www.BurgmanUSA.com * View topic - Burgman 400 Review
    Aussie-spec
    model
    but this
    33%
    29%
    .... All
    http://www.ask.com/bar?q=ECU+Yamaha+Majesty+400+stalling+stall&page=2&qsrc=0&zoom=What+Does+
    <KW>ECU</KW>+Stand+for|<KW>ECU</KW>+Repair|<KW>ECU</KW>+Chips&ab=9&u=http://soccerphile.blogspot.com/2008_06_01_archive.html
    23%
    Bob, Mar 16, 2009
  19. Bob
    Bob Guest
    Thumper majesty 400 less than 1,300rpm, it's not in the quartz timed
    ECU...or the tach reading is wrong......try again...
    I'm talking about reliably....infalibly under ALL RF interferences,
    mine seems to have the same problem as most when it was resolved 2 years
    ago...
    Bob, Mar 16, 2009
  20. Bob
    Bob Guest
    It ain't...
    No......just B&W recycled electrons....
    |>remains, rubbish.
    Well I was referring to the Yamaha Majesty, my Honda Elite ch250
    likes it best like that too, especially in hot dusty or rainy summer
    days....somtimes the -10C with -20c dewpoint affects it too....
    I mean reliable as in infallible, it still stalls at the garage door
    RF beam crossing, then the guillotine door comes down....
    Is this a concern, it is if you just jump started a 10 volt battery
    and aren;t too sure if it's gonna start on 5 minutes of idling....it usually
    does, but it chokes on unshielded HOT RF places only.....
    Bob, Mar 16, 2009
