Scary ride
Discussion in 'Australian Motorcycles' started by Alan Pennykid, May 17, 2004.
  1. Got out of work this evening at around 5:40, it was already dark. Keys into
    the sidecar and start her up, **** no lights. I checked all the fuses,
    fiddled with the key (it's been playing up), turned the light switch on and
    off and eventually got all my park lights and sidecar lights, but still no
    headlight. My flasher button works, so in desperation I decided to ride the
    42km home holding the high beam flasher, I adjusted the beam down first.
    1) It's bloody hard to use the clutch while holding the button down
    2) Even the flasher gave up just east of Penrith on the freeway, so here's
    me tailgating a truck at 100kmh with no headlight, at least the traffic
    behind can see me.
    3) Once I got off the freeway, I turned the hazards on for the last 5kms
    home, part of that is a 2km hill with 3 hairpins, the whole road unlit,
    4) my 'headlights'- the corolla in front of me pulled over to let me past,
    shit. No fun at all attacking uphill hairpins by the light of your hazard
    flashers, luckily it's a road I know well and could pick the approaching
    corners
    5) I seen more cops on that run home than I normally do in a month, luckily
    they were all otherwise involved
    6) Guess I'll just have to take the Jag to work tomorrow (R1100R needs a
    throttle cable and can't be trusted either)
    I've already sussed the problem, I think its worn contacts in the headlight
    switch itself. That's no big deal on a BMW as it's easy to pull apart,
    build up the contacts with solder and reassemble (with a clean working
    area). The flasher is probably the same thing, I'll find out later this
    week when I can look at it
  2. Alan Pennykid
    atec Guest
    What model Jag ?. (420G here)
    atec, May 17, 2004
  3. On 17/5/04 10:29 PM, in article
    Wanna buy a VTR?
    Hammo
    Hamish Alker-Jones, May 24, 2004
  4. Alan Pennykid
    Johnnie5 Guest
    nah worn out pieces of shit , cant give em away
    Johnnie5, May 24, 2004
  5. Mate, that old thing!
    It was the high beam low beam switch, currently hardwired to low beam (at
    least I've got lights).
    R1100R throttle cable will be sent in the mail when it arrives.
    Alan Pennykid, May 24, 2004
