Satnav speed accuracy
Discussion in 'UK Motorcycles' started by Danny, Jul 28, 2008.
  1. Danny
    Danny Guest
    I've read here that Sat nav actual speed displayed is very accurate,
    so I was surprised to see a large difference in displayed speed to
    that of my speedo. I was given a Garmin Zumo 550, which I've only
    stuck in the car at present. It's a nice bit of kit, well made, but I
    really hope you can get other voices...
    It consistently shows an over-read on the car speedo of 4mph at lower
    speeds and 6mph at higher speeds. At 70 indicated this means I'm
    actually only travelling at 64. I would have thought that this would
    have put me at odds with other motorway users, but my speed always
    seemed comparable to theirs. Similarly, when I go through those
    flashing speed signs in villages etc I find that doing 42 in a 40 gets
    the sign flashing (which would be 35 on the Garmin), and 39 doesn't,
    which seems odd if my car speedo is that far out.
    As soon as I can work out a good mount on the Blackbird I'll compare
    it on that, but is the Garmin always accurate?
    Danny, Jul 28, 2008
  2. Danny
    On Mon, 28 Jul 2008 10:15:06 +0100, Danny
    Sounds about right.
    That's because all speedos are designed to over-read, usually by
    around 10%, which is what you're seeing.
    Those type of 'display-your-speed' signs aren't neccessarily properly
    calibrated.
    I'd tend to think so.
    _______
    Ace, Jul 28, 2008
  3. Danny
    Danny Guest
    Thanks, so I can drive at an indicated 76 at least without getting
    nicked :) Bad news, though, since it makes my Isuzu Bighorn even
    slower than I thought it was.
    Just got to tackle the Blackbird mount, which is actually the only
    reason I got the Garmin. I can navigate to Paris (and the hotel by
    the Eiffel Tower) easily, but I cannot get to somewhere like Montmatre
    and back in darkness without getting royally lost.
    Danny, Jul 28, 2008
  4. Danny
    Domènec Guest
    I'd give a try to comparation with milestones. On a highway limited to
    120km/h I did that speed according to the GPS and ¡ding! "kilometer"stones
    [1] appeared exactly every 30 seconds.
    Domènec, Jul 28, 2008
  5. Danny
    Danny Guest
    They're the ones I'm thinking off - round Meon Valley way. The one in
    particular was at Bedhampton, as I happened to have the GPS on at the
    time.
    Danny, Jul 28, 2008
  6. We've got quite a special one on the A1020 in a 40mph zone that
    flashes your speed at you at any speed over 30mph. It's nice and
    bright, and if you're the first vehicle to arrive at it in a while,
    people seem to be surprised by it lighting up and flashing.
    I'm still waiting for it to cause a wreck because I often see people
    brake from 40 down to 30 real suddenly and the driver behind them
    doesn't expect it because, hey, it's a 40 zone.
    Still, they'll probably use the wreck that their poxy 'safety' sign
    causes as the excuse to lower the limit from 40 to 30 down there.
    anonymouslemming, Jul 28, 2008
  7. Eat loads of space cakes and smoke loads of crack.
    Whinging Courier, Jul 28, 2008
  8. Danny
    Cane Guest
    This ^
    Cane, Jul 28, 2008
  9. Danny
    Andy Hewitt Guest
    A recent court case for speeding went in favour of the GPS accuracy, and
    the driver was let off the penalty.
    Andy Hewitt, Jul 28, 2008
  10. Danny
    Indeed. Although I've never been able to see the difference between my
    old 3-D garmin and the later car-biased 2-D sat-navs. I used to have
    them side-by-side when doing a lot of mountain driving, as it's
    sometimes really useful to have the altitude displayed too.
    Confidence Interval. Is that the term you're avoiding using?
    _______
    Ace, Jul 28, 2008
  11. Stupid question on this one ... Is it just the speedo that overreads?
    Or does this impact the mileage recorded as well?
    Anonymouslemming, Jul 28, 2008
  12. Danny
    Kim Bolton Guest
    The lowest speed I've ever set one off in a 30 was at 22mph.
    There's a 'Slow Down'one that I occasionally pass, just before a blind
    bend on a bridge. It flashes even when the traffic queue is doing 2
    mph....
    Kim Bolton, Jul 28, 2008
  13. Danny
    Domènec Guest
    My shite olde Audi has an over-reading speedo and accurated mileage
    recorder. And calculates near exact fuel economy (0.2 litres per 100km
    error)
  14. Danny
    It's cos the mechanism (at least in older vehicles) for odo and speedo
    are quite different.
    For the odo, the wheel turns a cable that turns a device that clicks
    over the miles. It's a direct mechanical linkage.
    For the speedo, the wheel turns the same cable, that turns a magnetic
    disk. This spinning disk induces a <checks web for correct
    terminology> eddy current in an aluminium disc attached to the speedo
    needle, which, interacting with the rotating magnetic field, induces a
    small torque in the disc, and hence speedo needle. This torque is
    resisted by a spring.
    Hopefully, you can see that getting the speedo mechanism to be
    accurate is a fair bit more complicated than getting the odo mechanism
    to be accurate.
    Of course, everything's digital nowadays, so gawd knowa how it works.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Jul 28, 2008
  15. Danny
    Beav Guest
    And it's my guess that the number of "high" readings are being recorded. Not
    a problem from a prosecution POV, but get enough "overs" and you can bet a
    proper speed cam will be implanted in place of the warning tool.
    It's happend on two roads I use regularly and both roads used to be 40
    limits, but were dropped to 30 and had these "warning" tools. Both now have
    rear facing cams.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 28, 2008
  16. Danny
    I am certainly not.
    But is seems you are.
    Champ
    Champ, Jul 28, 2008
  17. Danny
    Mo Guest
    AIUI GPS doesn't average your speed over a distance. It uses the
    doppler shift of the GPS signal
    http://gpsinformation.net/main/gpsspeed.htm
    Mo, Jul 28, 2008
  18. Danny
    Not quite.
    "The Road Vehicles (Construction and Use) Regulations 1986, as amended,
    allows the use of speedometers that meet the requirements of EC
    Community Directive 75/443(97/39) or ECE Regulation 39. Both the EC
    Directive and the ECE Regulation lay down accuracy requirements to be
    applied at the time of vehicle approval for speedometers. These
    requirements are that the indicated speed must not be more than 10 per
    cent of the true speed plus 4 km/h. In production, however, a slightly
    different tolerance of 5 per cent plus 10 km/h is applied. The
    requirements are also that the indicated speed must never be less than
    the true speed."
    http://www.theyworkforyou.com/wrans/?id=2001-03-12a.59.3
    The wording's a bit ropey, but he clearly means "the indicated speed
    must not differ from the true speed by more than 10% of the true speed
    plus 4km/h."
    The ACPO guidelines are extra-generous, as if you're exceeding a 70mph
    speed limit by more than 10%+2, you're likely to have an indicated speed
    closer to 90.
    ogden, Jul 28, 2008
  19. Danny
    Tosspot Guest
    Rope wrote:
    Can't think why as they work on doppler. Try driving around a
    roundabout a few times and report back :)
    Tosspot, Jul 28, 2008
  20. Danny
    AndrewR Guest
    Pixies. Tiny, digital ones.
    AndrewR, D.Bot (Celeritas)
    Aprilia RSV-1000R, Honda VFR750F-L, Kawasaki ZX-6R, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Jul 28, 2008
