Safest way to get chain lube off plastics and frame?
Discussion in 'Australian Motorcycles' started by DoinitSideways, Nov 29, 2003.
  1. Does anyone know whats the best thing to use??...
    I once used Kero but im not sure on how safe it would be on the plactics?
    Josh - ZX9R
  2. In aus.motorcycles on Sat, 29 Nov 2003 10:10:48 +1000
    Mr Sheen, the biker's friend.
    Zebee
    Zebee Johnstone, Nov 29, 2003
  3. DoinitSideways
    Nev.. Guest
    Mr Sheen.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 29, 2003
  4. DoinitSideways
    Nev.. Guest
    Yeah I know Zebee said that... I should refresh more often
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 29, 2003
  5. DoinitSideways
    Duncan Guest
    I've always used kero. Never had a problem but I don't clean my bike that
    often.
    Duncan, Nov 29, 2003
  6. DoinitSideways
    Mark Hammond Guest
    I've grown to love "De-Solve-it", a citrus based cleaner. The bottle
    says it is non-toxic, and I believe them - it seems very mild - but very
    effective. If you let it soak for a couple of minutes, it even removes
    that baked-on tar which is almost impossible to remove (kero, degreaser
    etc all give up in disgust). Seems fine on the paint and plastic - but
    the bottle warns against using it on rubber.
    Mark.
    Mark Hammond, Nov 29, 2003
  7. DoinitSideways
    alx Guest
    Go to a large Shell servo, look for Teepol, now called DOBATEX. (No other Shell carwash products will do).
    It's a washing detergent and is more gentle than CT18 truckwash type stuff.
    In a squirt bottle and diluted to say, 25-50% it's a brilliant degreaser.
    Teepol has had a reputation around aus.moto for years so I finally got some and can vouch for it.
    Otherwise, yes, kero is fine.
    Another cleaner AND lube is lanolin-based liquids.
    www.lanotec.com.au
    This leaves a dry- greased feel to chains and is very good for rubber orings as not petroleum based.
    Bunnings usually have it in the paint section, try the squirt bottle or 1 litre container. But the squirt's good value and a good
    dispenser.
    It's now the only chain lube I pack for weekend trips. And it doesnt pick up dirt.
    alx, Nov 29, 2003
  8. Thanks Zebee and Nev...worked tops. Just wondering, it wont affect the ninja
    stickers which are on the ducktail?
    Josh - ZX9R
    Zebee
  9. DoinitSideways
    Nev.. Guest
    It might make them cleaner.
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Nov 29, 2003
