Rusty back brake
Discussion in 'UK Motorcycles' started by Charders, Feb 2, 2004.
  1. Charders
    Charders Guest
    Uncovering Quack today (after being laid up for 4 weeks) I've found
    that his back brake is *really* rusty.
    Is there anything I can get it off with or will it just come off as
    soon as I start riding him/braking?
    Thanks xxxxx
  2. Charders
    Robbo Guest
    Others may offer different advise, but I would clean it off with wet & dry
    and then go for a light bimble trying out the brakes at lower speeds to see
    if they feel OK.
    It may be that after 4 weeks the callipers are a little sticky too, so watch
    out.
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Feb 2, 2004
  3. Robbo wrote
    Bollocks.
    If it is only 4 weeks standing surface tarnishing then everything will
    come clean the first time the brakes are used are used.
    steve auvache, Feb 2, 2004
  4. Charders
    Charders Guest
    Ah, never thought about the calipers! Thanks Robbo xxx
  5. Charders
    Oil. In quite large quantities. Used engine oil is good, as the
    added sulphur compounds really attack the corrosion, converting rust
    back into shiny steel. Don't worry about splashing it about a bit, as
    any excess will burn off as soon as you brake. The best way to clean
    it off, therefore, is to soak the rear brake in loads of old engine
    oil, then ride off smartly.
    Don't worry about riding any differently yo normal, apart from you
    might want to get a good old head of steam up, to allow the de-rusting
    effects to develop fully under extended braking. Then just brake
    normally - although you may want to leave it a little later than
    usual, then squeeze really hard, to enhance the de-rusting effects.
    Why not do the front at the same time? Half the effort, then.
    Alternatively, don't worry about it. It's only cosmetic.
    Pip, Feb 2, 2004
  6. Charders
    Crikey. If you had a Guzzi you'd have to have shares in wet and dry.
    Just ride it, apply the brakes to clean the discs. Preferably before you
    need them IYSWIM.
    sweller, Feb 2, 2004
  7. You mean the disk, yes?
    Ride it. It'll come off.
    William Grainger, Feb 2, 2004
  8. Charders
    Salad Dodger Guest
    <dog with a bone mode>
    You'd have thought this sort of thing would be second nature to an
    "advanced motorcyclist", wouldn't you?
    </dwabm>
    Salad Dodger, Feb 2, 2004
  9. Charders
    Get down, Shep.
    Pip, Feb 2, 2004
  10. Salad Dodger wrote
    <reeves & mortimer>
    You just won't let it lie will you?
    </ram>
  11. Charders
    Anne Jackson Guest
    The message <>
    That was a petty, snide remark, and unworthy of _you_ Nick.
    Anne Jackson, Feb 2, 2004
  12. Charders
    dwb Guest
    And yet, strangely true...
    dwb, Feb 2, 2004
  13. Charders
    Not to mention pant-wettingly funny. But as Anne has a similar sense
    of humour to a wizened pickled walnut, you couldn't expect her to
    appreciate that.
    Pip, Feb 2, 2004
  14. Charders
    Anne Jackson Guest
    I've never found anything that was _meant_ to be hurtful, to be
    particularly funny.
    I _was_ wondering why Donna had stopped posting here....now I know!
  15. Charders
    Ginge Guest
    Maybe she was expecting some hugs or something.
    Ginge, Feb 2, 2004
  16. Charders
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Anne Jackson
    "If you can't take a joke..."
    Nigel Eaton, Feb 2, 2004
  17. Charders
    Ginge Guest
    Well go on then, explain it, for thos of us who can't fathom your logic.
    Ginge, Feb 2, 2004
  18. Charders
    Anne Jackson said...
    And here was me thinking she'd gone and got a life. Oh well, you live
    and learn.
    Lozzo, Feb 2, 2004
  19. Charders
    I wish I'd said that.
    Pip, Feb 2, 2004
  20. Charders
    I don't think that SD has a hurtful bone in his body, Anne. If you
    knew him, then you would share the same opinion.
    In any case, there is a fine tradition, especially round here, of
    laughing at the misfortune of others. If you do it enough, the victim
    laughs too - that is the definition of robust humour, afaic.
    I wasn't aware that she had - although now you mention it, there has
    been a lack of xxxx and {{{hugs}}} round here lately. Perhaps there
    should be more.
    Pip, Feb 2, 2004
