Rusting Disc and engine paint
Discussion in 'Classic Motorbikes' started by The cookies, Jan 29, 2005.
  1. The cookies
    The cookies Guest
    Hi
    New to this group and new to bike restoration. Have just bought an old
    Suzuki X7 250 to restore as a fun project.
    Its stripped down now and one thing I have noticed is how badly rusted the
    front disc calliper is. The bike has been exposed to the elements for a few
    years. Its not at all worn or cracked or warped.
    Here comes the silly question...Is there any way to safely remove the rust
    or is it beyond repair?
    Also, the lacquer on the engine has bubbled and turned white and powdery.
    What is the process for re painting and what's best?
    Hope you can assist.
    Tim
  2. Are you sure the caliper is rusty? I mean, they're made from alloy. The
    bolts and the piston may be rusty. The bolts can be cleaned up. The
    piston should certainly be replaced.
    Use Nitromors to strip off all the old stuff. Polish the cases and
    either keep them naked alloy and re-polish regularly or use several
    coats of aluminium paint - that wheel paint is good.
    I prefer the naked alloy approach, myself.
    The Older Gentleman, Jan 29, 2005
  3. The cookies
    Tim Guest
    Sorry...I meant the actual disc rather than the caliper.
    SORRY!!
    Tim, Jan 29, 2005
  4. The cookies
    Klaatu Guest
    Dick Emery paper and water.
    Klaatu, Jan 30, 2005
  5. The cookies
    Tim was seen penning the following ode to ... whatever:
    No need to apologise...
    If it's just surfact corrosion, using the brakes should wear it
    off. If it's worse than that, you maybe able to get it removed by
    skimming the disk.
    Oh, and could you please have a look at the FAQ (link below) and
    following our usual posting convention as described in there? Thanks.
    Timo Geusch, Jan 30, 2005
  6. Old cast-iron discs used to go orange at the first rain shower. The
    first application of the brakes wiped off this tiny layer of surface
    corrosion.
    I'm surprised an X7 disc has rusted, as they're supposed to be stainless
    steel, but the same applies.
    Just clean up with fine wire wool, and rely on the pads to do the rest.
    Honest - don't worry about it.
    The Older Gentleman, Jan 30, 2005
