Rust spots on Chrome
Discussion in 'Australian Motorcycles' started by Will S, Jan 7, 2005.
  1. Will S
    Will S Guest
    To be specific my headlight . Any recommendations for getting rid of these ?
    And yes, today I cleaned the bike and hated every moment of it
    Will
    Will S, Jan 7, 2005
  2. Will S
    MickK Guest
    Hello, Will!
    You wrote on Fri, 7 Jan 2005 13:10:20 +1100:
    WS> To be specific my headlight . Any recommendations for getting rid of
    WS> these ?
    WS> And yes, today I cleaned the bike and hated every moment of it
    Depending on how deep the rust goes, try a scourer pad (one of those green dishwashing thingy's). Failing that, take it to a metal polisher (cost you about $5-10) and he'll do a good job.
    MickK, Jan 7, 2005
  3. Will S
    Boxer Guest
    Try Solvol Autosol metal polish.
    Boxer
    Boxer, Jan 7, 2005
  4. Will S
    sharkey Guest
    Homebrand matte black spraypaint. Mask off at least some of the
    headlight lens first. Or don't, hey, it's your bike.
    -----sharks
    sharkey, Jan 7, 2005
  5. Will S
    John Littler Guest
    Shit Mick would you really do that to your bike ? A scourer is going to
    leave shitloads of little scratches and scrub half the metal away
    Will, get a tube of autosol, if that doesn't work then consider taking
    it to a professional, but elbow grease and autosol can just about
    anything shiny
    JL
    John Littler, Jan 7, 2005
  6. Will S
    MickK Guest
    Hello, John!
    You wrote on Fri, 07 Jan 2005 13:57:10 +1100:
    JL> MickK wrote:
    JL> Shit Mick would you really do that to your bike ? A scourer is going to
    JL> leave shitloads of little scratches and scrub half the metal away
    lol, that's alot of scrubbing. The plastic green ones to which I was referring don't (plastic doesn't scratch metal). They are also excellent at removing grease from rims (with a little kero added). They will however, scratch your plastics (perspex/fairing) so I wouldn't recommend using them in that area. The scourer you may have been thinking of was probably the rolled up metal type used to scrub pans etc. They would scratch and take half the metal away.
    JL> Will, get a tube of autosol, if that doesn't work then consider taking
    JL> it to a professional, but elbow grease and autosol can just about
    JL> anything shiny
    A metal polisher is going to use an abrasive material as well although if he/she is any good, they will only remove the pitted surface material.
    MickK, Jan 7, 2005
  7. Will S
    SmeeR11S Guest
    To get rid of the headlight there are some bolts you have to undo.
    When they are undone and you have unplugged the wiring then you have
    gotten rid of the headlight.
    SmeeR11S, Jan 7, 2005
  8. Will S
    zarz Guest
    zarz, Jan 7, 2005
  9. Will S
    Will S Guest
    thx to all
    John also suggests autosol so will go and get some now
    Will S, Jan 7, 2005
  10. Will S
    John Littler Guest
    Green scotchbrite, yes it'll scratch chrome, chrome scratches quite
    easily imnsho
    Of course it does, but there's abrasive and there's abrasive - that's
    why they put numbers on sandpaper...
    JL
