Rust Removal
Discussion in 'Classic Motorbikes' started by Jim Scullion, Apr 27, 2004.
  1. Jim Scullion
    Jim Scullion Guest
    Can anyone suggest an easy/cheap/effective way of dealing with surface
    rust on SOB chrome and wheel spokes?
  2. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Jim Scullion
    Brasso, if it's only surface rust.
    GS 850 x2 / SE 6a
    Get rid of your SOC/SOB here http://www.sparesorrepair.co.uk/
    Grimly Curmudgeon, Apr 27, 2004
  3. or solvol autosol.
    Austin Shackles, Apr 27, 2004
  4. Jim Scullion
    Geoff Berrow Guest
    Gosh, is that still available? I remember using that on the brightwork
    of my SS80 back in 1970. Occasionally...
    Geoff Berrow, Apr 27, 2004
  5. Jim Scullion
    Timo @ work Guest
    If Solvol isn't doing the job any more you're looking at either
    painting the rims silver (ewwww) or getting new ones, methinks.
    Timo @ work, Apr 27, 2004
  6. Jim Scullion
    Jim Scullion Guest
    ewwww indeed! I'll give the Solvol a go, before descending to the
    depths of Hammerite on my lovely SOB.
    Serves me right for using it during the Winter, I suppose.
  7. Jim Scullion
    Brian Price Guest
    Autosol a toothbrush and lots of elbow grease:) Easier if you take the
    wheels off, it saves the squatting.
    Brian
    Brian Price, Apr 27, 2004
  8. Do it whatever - rusty wheel spokes are an MoT failure. Seriously.
    The Older Gentleman, Apr 27, 2004
  9. It is indeed. Marvellous stuff.
  10. Jim Scullion
    The Older Gentleman says...
    You should be getting your bikes MOTd where I do then :) The CB is just
    a mass of ferrous oxide now.
    Lozzo, Apr 27, 2004
  11. Jim Scullion
    Brass wire brush - aggression level somewhere between solvol and angle
    grinder.
    platypus, Apr 27, 2004
  12. Jim Scullion
    Even Tescos sell it.
    sweller, Apr 27, 2004
  13. Jim Scullion
    Not just rusty but the book says "a spoke which is missing, cracked,
    excessively loose bent or corroded".
    The key word is "excessively". Problem here is the tester is allowed to
    use his own judgement ...
    I wire brushed and painted the spokes on Frankfurt MZ. No problem.
  14. Yup, I've done that as well. You can see the point - badly corroded
    spokes = wheel collapse. But cleaning them up and proofing thm with
    decent paint works.
  15. Jim Scullion
    Graham Gould Guest
    BUY A NEW PART!!!!!!!!
    Graham Gould, Apr 27, 2004
  16. Or a hearing aid.
  17. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Jim Scullion"
    Once you've Brassoed or Solvoled them, a coat of car wax will help keep
    the corrosion at bay for while. It fills in the pores of the chrome
    plating. Do it regular and you can banish the Brasso blues forever.
    GS 850 x2 / SE 6a
  18. It was somewhere around Barstow, on the edge of the desert, when the
    Thank you for that sound and helpful advice.
    The nurse will be along soon with your medication.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Apr 28, 2004
  19. Jim Scullion
    Jim Scullion Guest
    Please do the following:
    1. Stop shouting.
    2. Read the FAQ to learn how to post in this group
    http://www.unixconsult.co.uk/bike-ukrmcfaq.html.
    3. Learn something about classic bikes rather than just talking
    bollocks.
    Jim Scullion, Apr 28, 2004
  20. Jim Scullion
    Jim Scullion was seen penning the following ode to ... whatever:
    That would somehow reduce the number of people attending this
    newsgroup quite considerably, wouldn't it?
    Timo Geusch, Apr 28, 2004
