Running in. Oil
Discussion in 'UK Motorcycles' started by Drew, Apr 24, 2005.
  1. Drew
    Drew Guest
    Right my bike has finally turned just over 500 miles and I want to change
    the oil and filter, but which oil?
    I presume, as this isn't a high performance sportsbike, standard 10w 40 car
    oil will do, I really can't see the justification for £30 specialised bike
    oil for a CB500, or is there?
    Drew, Apr 24, 2005
  2. Drew
    Ovenpaa Guest
    Sometime around Sun, 24 Apr 2005 22:31:51 +0100, Drew babbled on about:
    I like Putoline Super DX4 in just about everything (apart from the Rotax)
    seems OK and is under GBP4/litre
    Ovenpaa, Apr 24, 2005
  3. Drew
    Drew scribbled on the back of a napkin:
    You may want to shop around a bit - I've just bought a 4l can of
    bike-spec Silikolene (sp?) 10w40 dino juice for 12.50.
    Timo Geusch, Apr 25, 2005
  4. In uk.rec.motorcycles, Timo Geusch amazed us all with this pearl of
    wisdom:
    Where did you get that? I'm due a change soon.
    Whinging Courier, Apr 25, 2005
  5. Drew
    Whinging Courier scribbled on the back of a napkin:
    Stafford show - there's always a bloke there doing good prices on
    Silikolene oils.
    Alternatively the Halfrauds bike specific stuff isn't that expensive
    and pretty good IMHO.
  6. In uk.rec.motorcycles, Timo Geusch amazed us all with this pearl of
    wisdom:
    Might be worth a look. I put some v.cheap mineral oil in not so long ago
    with no bad effects.
  7. Drew
    It's a little better than running without oil. :)
    Muck, Apr 25, 2005
  8. What he said.
    The Older Gentleman, Apr 25, 2005
