Rucksack recommendations ?
Discussion in 'UK Motorcycles' started by TW, Mar 14, 2005.
  1. TW
    TW Guest
    My 5 y/o Frank Thomas rucksack is starting to disintegrate at an
    exponential rate, so I need a replacement quickly (amazing it lasted
    that long I suppose, given the usual comments about Frank's
    workmanship).
    I'm usually only carrying a laptop, phone, wallet etc., so I don't want
    anything too big so the contents will just rattle around. But I
    occasionally use it for overnight trips when it needs to hold a bit more
    stuff. One nice feature of my current one is that it's got a zip that
    you undo to let the thing expand when you need more capacity.
    Anyone have any recommendations ?
    Thanks
    TW, Mar 14, 2005
  2. TW
    'Hog Guest
    Millets
    Lowe Alpine
    Cheap and, errm, carries stuff just fine.
    'Hog, Mar 14, 2005
  3. TW
    TimP Guest
    What you want is a Crumpler rucksack:
    http://www.crumpler.com.au/home.php
    Mine is a Base Toucher ('kin stupid name) & is the best laptop case
    I've seen - they do a larger model if you need more space. Also doesn't
    look like a computer bag so you're less obviously carrying round
    £1000s worth of stuff.
    It's been fairly waterproof, though I'd not like to risk it in a
    downpour. Quite pricey though - I think it was £90 from Micro Anvika.
    TimP
    TimP, Mar 14, 2005
  4. TW
    Sorby Guest
    Yeah, use Google (or Google Groups)
    There are over 300 references to rucksacks in uk.rec.motorcycles alone!
    p.s. DaKine rucksacks are my preferred choice.
    Sorby, Mar 14, 2005
  5. TW
    Catman Guest
    Smaller Kriega IMO
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (Badly bent) 155 TS
    www.cuore-sportivo.co.uk
    Catman, Mar 14, 2005
  6. TW wrote
    Odd this one is because I have a pair of their boots which would qualify
    in their own right to race vintage and a mate of mine has a pair of
    their gloves that are as old as some of Lozzo daughters.
    Tank bag. Once you get one you will be a convert for ever.
    steve auvache, Mar 14, 2005
  7. TW
    Ben Guest
    Aye, I've got a Berghaus Nitro which is a cycling specific one. It's
    designed so the weight sit low on your back so when you're on a bike
    it doesn't rest on your shoulders. Perfect for a motorbike.
    It's was commuted in all weathers with a laptop in for 6 years and
    barring dirt is still in perfect nick.
    Ben, Mar 14, 2005
  8. TW
    Mo Childs Guest
    I think he wants a recommendation - not a list.
    Mo Childs, Mar 14, 2005
  9. TW
    simonk Guest
    I've got one of them - though it's the bigger one. Either way, they rock.
    The big ones can be shrunk to keep the contents steady - mine rarely has more
    than a laptop and some printed documents in it
    simonk, Mar 14, 2005
  10. TW
    steve auvache says...
    My daughter is younger than your eldest, you senile old twat.
    Lozzo, Mar 14, 2005
  11. TW
    TW Guest
    said...
    Thanks for the reco., but
    Jesus christ, that must be the most annoying website I've ever visited !
    TW, Mar 14, 2005
  12. TW
    TW Guest
    said...
    One of these looks like it'll do the job nicely.
    Ta.
    TW, Mar 14, 2005
  13. TW
    Ovenpaa Guest
    Sometime around Mon, 14 Mar 2005 16:43:43 +0000, TW babbled on about:
    I think I still have a proper padded laptop rucksack that I have never
    used since day one, mail me if you want it.
    Ovenpaa, Mar 14, 2005
  14. TW
    'Hog Guest
    Its really really stoopid that they don't just make the fucking things
    waterproof though. All this bollocks with shower caps is a royal PITA.
    OMG they do a pet carrier!
    'Hog, Mar 14, 2005
  15. TW
    Eddie Guest
    What he said.
    Just be careful if you have to do a forward aerial dismount. DAMHIK,IJK,OK?
    Eddie, Mar 15, 2005
  16. TW
    I've spent hours in the pouring rain (sans cover) without mine letting
    any water through - all you need to do is keep moving forward.
    Ace, Mar 15, 2005
  17. TW
    'Hog Guest
    Mine leaks like a sieve, did even behind the K1100 fairing. I think I
    spot a shopping opportunity!
    'Hog
    'Hog, Mar 15, 2005
  18. TW
    It's official! Gixxer thou keeps rain off better than K1100!
    Ace, Mar 15, 2005
  19. Millets
    Outdoors
    Blacks
    Cheap and will last a f**king sight longer than 5 years.
    Waterproofness might be an issue, though.
    danny_deever2000, Mar 15, 2005
  20. Lozzo wrote
    I was making the point that your daughters are well out of nappies now.
    No need to get personal, even if it is true.
    steve auvache, Mar 15, 2005
