Rubs chin thoughtfully
Discussion in 'UK Motorcycles' started by flash, Jun 10, 2005.
  1. flash
    flash Guest
    flash, Jun 10, 2005
  2. flash
    flash Guest
    flash, Jun 10, 2005
  3. flash
    Ben Blaney Guest
    Ben Blaney, Jun 10, 2005
  4. flash
    platypus, Jun 10, 2005
  5. flash
    Bear scribbled on the back of a napkin:
    AFAIK no, after all they were designed to run day in, day out...
    See the end of the galaxy over there ?
    Timo Geusch, Jun 10, 2005
  6. flash
    Travel from job to job, with a trailer/garage on the back and the name
    "Sanders" painted over the door.
    Shouldn't be - Routemasters were built to be maintained by chaps with grease
    guns and 18" Whitworth lump hammers.
    Total or per gallon? Probably terrifying in either case.
  7. alternatively http://www.thedoubledeckers.com/song.htm
    I doubt it - they are still running in everyday service and there is an
    immensely resourceful Routemaster Owners Association that can find
    almost anything to do with a Routemaster or tell you where to find
    someone who can help.
    http://www.routemaster.org.uk/
    Paul Corfield, Jun 10, 2005
  8. A lifelong buddy of mine was a bus driver in central london, and whilst
    I have to admit he's a pretty good driver when he put's his mind to it,
    he's not the sharpest of tools from the cabinet, and is/was also a
    complete dopehead.
    Ergo; they can't be that difficult to drive, albeit I'm sure they have
    their tricky moments - like some of the 90 degree bends in cobblesville
    areas of Preston - always impressed me when a bus driver got it spot on.
    Amused me when the fucked it up too <g>
    Doesnotcompute, Jun 11, 2005
  9. Not particularly. It's just a big van in essence - all the bits are
    fairly conventional, just bigger.
    Grimly Curmudgeon, Jun 11, 2005
  10. flash
    Grimly Curmudgeon scribbled on the back of a napkin:
    Don't forget heavier as in "a lot".
    Timo Geusch, Jun 11, 2005
  11. flash
    Gyp Guest
    You mean if it said "Bear's toy library play bus"?
    I'm sure that can be sorted.
    Just think, who else do you know that drives a play bus with sandpit and
    upstairs soft play area?
    Gyp, Jun 11, 2005
  12. flash
    Imagine, if you will, the passengers' reaction to the driver turning
    round and announcing his identity. Much like the b/w (Hammer?) film
    as the skeletal driver reveals his visage for the first (and last, of
    course) time.
    I've always fancied a big old bus like this, but a dim and distant
    memory surfaces, a faint chord is heard - about fuel consumption. I
    recall an article from the 80s reporting on the highly successful
    fitting of a water injection system to such a SOBus - among the
    advantages was the improvement in fuel consumption, improved by 50% -
    to three mpg. FFS.
    There again, I'm sure we could organise a whipround amongst certain
    posters of this parish, to buy the bus for the Bear ...
    .... providing he recreates the final scene from the Young Ones with
    it.
    Pip, Jun 11, 2005
  13. ISTR Routemasters are remarkably light (for a bus), actually, because
    all the bodywork is aluminium.
    The Older Gentleman, Jun 11, 2005
  14. The Older Gentleman, Jun 11, 2005
  15. flash
    With locks and handles only on the outside of the doors, I assume?
  16. flash
    The Older Gentleman scribbled on the back of a napkin:
    In that case, just chuck the brake drum in the back of the cage and get
    it down to that nice Mr Eaton so he can give it a skim, willya?
    Bus *bodywork* tends to be fairly light as you said.
    Bus *components* tend to be a bit on the lardy side...
  17. flash
Similar Threads
Loading...
