Rowing machines
Discussion in 'UK Motorcycles' started by flash, Oct 3, 2005.
  1. flash
    flash Guest
    Anyone recommed one?
    Anyone got one gathering dust somewhere?
    flash, Oct 3, 2005
  2. flash
    Cane Guest
    Simonk is a wet bob although he's more into real boats. He's the bloke
    I'd ask.
    Cane, Oct 3, 2005
  3. flash
    If you want cheap but not shit, hit ebay for a Delta Airmaster.
    You should be able to find a local one on there for between 60 and
    80 quid, and if you don't use it, punt it back out for the same.
    ogden, Oct 3, 2005
  4. flash
    zymurgy Guest
    There's one in Belfast I know of. Quite a good one.
    Email me if anyone wants it.
    Cheers
    Paul.
    zymurgy, Oct 3, 2005
  5. flash
    simonk Guest
    Indeed.
    Concept II - YKIMS
    You can pick up the Model B ones relatively cheaply now - those are the ones
    with the fan in a wire cage. They're quite noisy, but really solidly built.
    While the later ones are quieter and have a slightly different feel, the
    calibrations are more or less the same across each series so you can compare
    scores with your mates/people down the gym/whatever
    They hold their value very well, so even if they seem pricey on eBay, when
    you inevitably get fed up you'll get your money back
    simonk, Oct 3, 2005
  6. flash
    Eddie Guest
    I thought you'd probably say that, but have you seen those "Water Rower"
    machines? What's the opinion of them from our resident rowing expert?
    Eddie, Oct 3, 2005
  7. I'm far from an expert on rowing machines, but we have these at the gym
    and they seem much good indeed to me. Very well built, quality
    machines.
    Mr. Fantastic, Oct 3, 2005
  8. flash
    simonk Guest
    Not great. Claims to feel more like rowing a boat, but it doesn't. The
    performance monitor used to be dodgy - wouldn't give you more "credit" for
    pulling harder, just gave you a higher score the more strokes you did. I've
    seen some of them after a few months' heavy use and they don't stand up as
    well as the C2, although they're probably fine for domestic use, and they're
    certainly quieter and better looking
    simonk, Oct 3, 2005
  9. flash
    Eiron Guest
    Get a kayak. YKIMS.
    Mine's big and pink and made by Gaybo.
    Eiron, Oct 3, 2005
  10. flash
    Eddie Guest
    No thanks; as much as I enjoy kayaking, I've got more than enough
    expensive, time-consuming hobbies as it is.
    But what about your kayak?
    Eddie, Oct 3, 2005
  11. flash
    flash Guest
    Cheers,ta.
    flash, Oct 3, 2005
  12. flash
    flash Guest
    Hmm, looks like £500 for a second hand one on ebay...
    flash, Oct 3, 2005
  13. flash
    I use a C2 down the gym, but I've got a Tunturi R610 at home which,
    whilst not close to the Concept in build-quality etc. is a perfectly
    acceptible and considerably cheaper home use alternative.
    But then, I'm no expert.
    darsy, Oct 3, 2005
  14. flash
    elyob Guest
    How about one of these?
    http://www.foilkayak.com/
    elyob, Oct 3, 2005
