Round 7, FOAK: 1982 Kawie KZ550 C3 LTD Restoration Options
Discussion in 'Motorbike Technical Discussion' started by Biker Dude, Nov 23, 2009.
  1. Biker Dude
    Biker Dude Guest
    I am about to replace the chain and sprockets on this noble beast and
    so begins the Quest for the Unknowable Right Answer:
    Should I change the gearing, or in this case, the sprocketing?
    It's a cute little in-town cruiser and bar hopper but it wasn't made
    for sustained
    highway riding. It's too rev-vy for that:
    It redlines at 20 mph in first gear, I rarely take it up to 70 mph. I
    know a few less revs at highway speed in 6th gear would be a bit more
    pleasant.
    Should I give it taller gears? Would I regret reducing the crusing
    revs by about 8 or 10 percent with a corresponding loss of low gear
    grunt?
    What say ye, oh Fount of All Knowledge? <ducking for cover>
    Biker Dude
  2. It's up to you. The only way most people are satisfied with the answer
    to the gearing question is experiencing what happens when they do it.
    You can install a front sprocket with one tooth more (if you can find
    one that fits in the space available, or install a rear sprocket with
    three teeth less, and you will
    usually achieve a gearing situation where sixth gear feels like it's
    halfway between
    sixth and an imaginary seventh gear.
    If you live in flat country and you don't have to fight head winds,
    you just might
    like such an arrangement.
    Oh, get real. I was talking to a guy at a motorcycle hangout and he
    said that he and his "partner" frequently rode to San Francisco and
    back together on his KZ550 (about 800 miles round trip) and the
    biggest issue was that there was no way to carry souvenirs or
    antiques ;-) home because the machine was so small.
    Believe it or not, the engineers at Kawasaki *knew what they were
    doing* when they selected the transmission gearing and the final drive
    ratios.
    A modern 4-stroke inline-four has a very short stroke in order to
    reduce piston ring flutter at high RPM. Kawasaki designed their engine
    in order to save wear and tear on the piston rings, so, if you're
    cruising along at 5500 to 6000 RPM in sixth gear, you're NOT hurting
    the engine.
    If you're out on the road on a long trip and you're riding close to
    the red zone on your tach for long periods, be sure to check your oil
    level every day.
    A 7.5% change in final drive ratio will generally put you right
    between 6th and 7th
    gears, in terms of cruising RPM.
    Like i said, it depends on whether you have hils to climb or have to
    battle head winds or carry a passenger. If you find that you have to
    downshift two gears instead of one gear to pass a truck on a hill,
    you've over-geared your final drive.
    âÍÁ Á³Õ »Ñ·àÁ ËØÁ, Nov 23, 2009
  3. Biker Dude
    Bob Scott Guest
    Sounds to me like someone has changed the gearing already.
    It's more than 20 years since I rode a 550 Ltd but back then I was happy
    to run it at a steady (indicated) 100mph. I've ridden a vanilla Z550 & a
    GPz550 since then & they were both happy enough around 100mph.
    I'd second that - check the gearing & if it's not standard I'd change to
    standard.
    Bob Scott, Nov 23, 2009
  4. Utter nonsense.
    The Older Gentleman, Nov 23, 2009
  5. If you want. I wouldn't.
    That's a 550 Kawasaki for you. They're all like that. I've owned a
    couple and ridden many more.
    I'd leave it stock. There isn't that much bottom end in those engines
    anyway. Not much mid-range either, come to that.
    And now, I will see what KrustyUS advocates. I'll expect a ream of
    superfluous info about gearing.
    <Checks>
    Yup, thought so. At least he tells you to retain the stock gearing, so
    that's three or four votes in favour and none against.
  6. Biker Dude
    Dave Emerson Guest
    Make that 5-0
    Dave Emerson, Nov 23, 2009
  7. Compared to a twin cylinder engine of equal displacement, inline-fours
    *do* have a very short stroke, so they can rev up to higher RPM than
    the twin, thus producing about 40% more power.
    A few KZ550 specs:
    Bore x Stroke: 58mm x 52.4mm
    Power: 53 @ 8500
    Torque: 35 @ 7000
    Top Speed: n/a
    RPM @ 60: 4902
    Piston speed (in feet per minute) = .166 X 2.06 inches X 8500 RPM =
    2913 fpm
    At 7000 RPM, the piston speed is 2399 feet per minute.
    At 60 mph, the engine is only turning 4902 RPM.
    Piston speed is only 1700 fpm at such a relaxed cruising speed.
    Now, compare what racing speed tuners say is a reasonable piston speed
    for production based engines.
    4500 feet per minute.
    You would have to rev the KZ550 (or any engine with the same stroke)
    over 13,000 RPM to reach the theoretical piston speed where piston
    ring engineers started running into trouble with ring flutter. (1)
    Nowadays, racing engines (like Ducati Corsa engines) are routinely
    reaching piston speeds of 5000 feet per minute and consequently have
    very short useful lives due to piston ring flutter exacerbated by the
    low friction slipper pistons rocking in their bores.
    The Norton V-8 protype engines of a decade ago were reaching piston
    speeds of 5500 feet per minute...
    (1) Back in the mid-1980's, Suzuki was racing their prototype
    GSXR-750's in European endurance racing. They had to rev the engines
    up to 13,000 RPM to get the 130 horsepower they wanted.
    American roadracers drooled at the thought of getting their hands on
    an engine that revved up that high and produced so much horsepower.
    But the racing GSXR's had special Carillo I-beam connecting rods that
    cost $1000 a set.
    The production GSXR-750's that we got only had about 90 horsepower and
    were RPM-limited to only about 11000 RPM because they used cheap
    production connecting rods.
  8. Quite right. Never said they didn't.
    Short strokes equal higher revs, greater valve area, less tall engine,
    and lower piston speed. Rocking of pistons in bores is nothing to do
    with it.
    To say that ring flutter is the reason why people use short strokes is
    just daft.
    <snip a raft of the usual irrelevaqnt technical stuff designed to
    obscure your initial bollocks>
    The Older Gentleman, Nov 24, 2009
  9. Biker Dude
    M.Badger Guest
    Nope. Yup. Maybe.
    Kawasaki knew what they were doing when they came up with the gearing. It is
    your bike though, so do what you want. If it makes the bike better for you,
    if it makes you a happier rider, why not?
    Even after all these years of riding Japanese middleweight fours, I am still
    in awe of the engine speeds and reliability they obtain.
    If the low first gear is a pain, set off in second.
    You -may- regret it. OTOH, sprockets aren't vastly expensive.
    Providing it fits, try going up one tooth on the front. Ride around for a
    bit. Does the bike still pull without having to drop a gear?. Next, drop
    two teeth off the back.
    One thing to be aware of though is you may end up at, say, 4000RPM in 3rd,
    where previously you'd be at 3750RPM in 4th. Just an example, no need to
    hit me with maths...
    You won't kill the bike. You may make it better for you, you may make it
    worse. If you lose instant throttle response, or find yourself flicking
    twixt 5th + 6th at motorway/highway speeds, it is a minor task to restore
    the gearing.
    If the revs bother you, mask your rev counter :)
    M.Badger, Nov 24, 2009
  10. Biker Dude
    TOG@Toil Guest
    Looks that way.
    They're lovely little engines, those 550s. I lost my licence on a 1984
    GPz550, the first ZX model. "In excess of 118mph" it said on the
    summons. The police who nicked me observed that I was actually pulling
    away from them at the time, but the police car would go no faster, so
    118 was the figure. The bike was indicating just under 130 at the
    time.
    I also took a GT550 (the shaft-driven one: did you ever get that in
    the US) around France once. That had what was basically the engine
    from the first GPz550H1 in it, so very whizzy but not as peaky as the
    ZX. Still needed winding up, though. That would easily indicate 120mph
    solo. Comfy, too: they sold zillions of the things here to despatch
    riders.
    The LTD is a rare beast in the UK. Generally, we don't do the cruser
    thing, and those who do tend to buy ones designed as cruisers from the
    ground up, rather than the bastardised roadsters that predominated in
    the late 1970s/early 1980s.
    TOG@Toil, Nov 24, 2009
  11. If you don't know the *basics* of high performance ICE's, you should
    just STFU.
    The engineers at Honda became intimately aware of the problems of
    piston ring flutter back in the early 1960's when they developed 0.5
    millimeter thick piston rings for their GP racers. (1)
    And Ducati has stuck with their antiquated 90 degree V-twin because of
    its popularity amongst wealthy aficionados, despite the problem with
    piston ring flutter exacerbated by piston rocking.
    You just aren't a technically informed as you think you are. Do try
    and keep up,
    M'kay?
    (1) When Wiseco made pistons that could be fitted with those thin
    rings back in the mid-1960's, I installed a set of them in my Yamaha
    250cc cafe racer. However, street riding didn't require really high
    RPM performance, so thinner rings just didn't make any difference for
    my application.
    âÍÁ Á³Õ »Ñ·àÁ ËØÁ, Nov 24, 2009
  12. OTOH, the OP may just be noticing that his transmission has a rather
    "low" first gear, compared to the other five gears.
    โอม มณี ปัทเม หุม, Nov 24, 2009
  13. Biker Dude
    M.Badger Guest
    Yebbut the rear sprocket must be the size of a dinnerplate to drop it -that-
    much. I suspect the OP may just not be used to how much these little fours
    rev.
    I rather liked the UniTrak GPz550. A good looking, sweet handling bike for
    the time. ISTR it thrived on revs. Really came alive in the upper 3rd of
    the rev range.
    Our works pool bike for despatching was a GT750. Wretched looking thing, but
    would run flat out on Motorways day in, day out, screaming the 'nads off it
    without complaint. As it was the pool bike, it was subjected to the sort of
    outright abuse that we wouldn't mete out to our own precious steeds.
    Thrashing them when they've warmed up doesn't kill them. Lack of oil
    changes and thrashing from cold probably would. No matter what we did, it
    steadfastly refused to die.
    We treated it to a can of beer when it reached 100,000 miles. Well, we
    poured a can of beer over it. It was 18 months old, so it was kind of its
    18th birthday too!
  14. Biker Dude
    M.Badger Guest
    Looking at that, a couple of things come to mind. Firstly, what a good
    looking bike it was, and still is.
    Secondly, it looks 'together', and finally, my ( rather crap ) arbiter. When
    I park a bike up and walk away from it, do I turn and look at it again?.
    My current Bandit?, yes, every time. My XJ650?, yes, every time ( ged, I
    miss that bike ). My SD900?, hell, I'll park that and just stare at it!. My
    old TransAlp?, sometimes. When I had an ER-5, or an XJ750 or the ZG1000
    Concours?. Can't say I ever did.
    That GPz would always get a second glance as I walked away.
  15. Biker Dude
    TOG@Toil Guest
    I do. You don't. Ring flutter is *not a problem* in anything but the
    most highly tuned engines. And a 550 Kawasaki LTD (maybe 50bhp) isn't
    that. Sure, ring flutter exists, but the reason for going to wider
    bores just isn't for ring flutter. It's a by-product advantage on
    super-tuned engines, I suppose, but hardly any road engines (until
    perhaps the last few years) have been able to get to the speed where
    it becomes a problem.
    For engines, the advantages are, as I've said: lower piston speed,
    yes, which just reduces wear on the bores and the rings too, I
    suppose. The ability to increase the valve area. It makes the engine
    shorter (less tall) although the trade-off is, I suppose, that makes
    it wider. It also allows the use of a shorter camchain which in theory
    reduces the inertial loads.
    Now, about Ducatis. I'm not wealthy and I have one, and it has covered
    30k miles without any ring flutter or rocking pistons that I'm aware
    of. In fact, it's the most reliable bike I've ever owned. If you're
    talking super-tuned bikes, see comments above.
    Finally, I have a bike whose engine is capable of piston speeds of
    around 5000fpm and it doesn't appear unreliable.
    <snip usual irrelevance about antique bikes>
  16. And how the phuque do you suppose that the engine evolved to such
    capability, you daft ****?
    It's not because there were a lot of ebayers trying to make a living
    off of selling
    NOS Honda side reflectors, yannow.
    It's because the engineers were aware of the various mechanical
    problems as they arose and they solved them so the racing department
    could race reliable motorcycles on Sunday and the sales department
    could sell a cheaper production version on Monday.
    The sequence of problems was high piston speed (actually high
    acceleration and deceleration causing ring flutter and valve train
    problems.)
    This was solved by thinner piston rings. Every high speed engine you
    look into is going to have 0.5 mm thick rings these days.
    As peak RPM increased, the engines ran into problems with connecting
    rod stress.
    This problem was solved by better quality rods.
    Nowadays the problem is with piston cracking around the wrist pin
    area.
    However, Ducati V-twins are still stuck with a design that is
    susceptible to piston ring flutter caused by excessively high piston
    speed/acceleration/deceleration in their efforts to make an antiquated
    engine competitive with I-4's...
    And all this crap between you and me evolves out of my attempt to tell
    some poor
    rider "don't worry, be happy."
    What is it about you that makes you think that your point of view is
    the last word on any given subject?
  17. And piston speeds on anything mother than full race-type bikes are
    nowhere *near* enough to cause flutter. It isn't an issue. And road
    engines couldn';t attain the sort of speeds where flutter was an issue
    *anyway*.
    And old Kawasai 550s don't need to worry about it either.
    Mine isn't.
  18. BullMurray!
    Just because you've never revved your Eurofag Duck up to 12,000 RPM
    doesn't mean the piston rings won't flutter when you do try it.
  19. Well, thanks for proving my point. It's an irrelevance.
    And how my Ducati 750SS (and you've *never* ridden one, nor indeed that
    many bikes) would reach 12k rpm when the redline is at 9k I shudder to
    think.
  20. Thank you. He reads techie stuff, you know, but doesn't understand it
    properly. And he simply hasn't the experience anyway. I remember him
    banging off a while back about how the Japanese didn't use roller
    bearings for their cams, a while back.
    The Older Gentleman, Nov 25, 2009
