Rough Souper project begins.
Discussion in 'Classic Motorbikes' started by tallbloke, Oct 17, 2004.
  1. tallbloke
    tallbloke Guest
  2. It was somewhere around Barstow, on the edge of the desert, when the
    Missing a couple of bits, though. Any idea what it was for, or in?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Oct 17, 2004
  3. tallbloke
    tallbloke Guest
    Railcar. 1300cc sidevalver. The cases are in excellent nick. All the
    threads are good.
  4. tallbloke
    Ovenpaa Guest
    Nope, but I have an M4 of similar ilk that runs the 996 MAG V-twin, and a
    few handy contacts for most things old and unusual, JAP's were
    interesting cos they were slotted into just about everything at some
    point, what is it about 770cc early 30's? (the nice castings and bearing
    look post 20's) apic of the timing side would be good as well.
    You could make a very nice period racer with that.
    Ovenpaa, Oct 17, 2004
  5. tallbloke
    Gorgeous. CIHAGM when it's built?
    platypus, Oct 17, 2004
  6. tallbloke
    tallbloke Guest
    Of course. Help build it. :)
  7. tallbloke
    JAP engins went into stuff like Morgans and Brufsups.
  8. tallbloke
    tallbloke Guest
    They're DTZ 1300 cases.
    Timing side:
    http://www.tallbloke.net/jap2.jpg
  9. tallbloke
    Ovenpaa Guest
    That explains the massive webbing then, mid 30's then, at least spares are
    relatively easy to find, you should be able to find a Sturmey Archer 3
    speed HD box on it, and get away with a MK6 carb, the mag will be
    expensive though, did you get a crank with it, and if so did it still have
    iron pistons?
  10. tallbloke
    tallbloke Guest
    @text.news.blueyonder.co.uk:
    Hence the thread title :)
  11. tallbloke
    Fit it across the frame with a BMW drivetrain, and stick Morgan badges on
    the tank...
  12. tallbloke
    tallbloke Guest
    I've already got 2 guzzis ta. :eek:)
  13. tallbloke
    tallbloke Guest
    The vageries of 70 years of history I guess. Maybe someone needed a couple
    of studs one day and thought
    "I know where there are a couple about the right length, where's me
    angl^H^H^H^H hacksaw"
  14. tallbloke
    I don't think the /whole/ stud is missing...
  15. tallbloke
    tallbloke Guest
    Heh. The hole is Whole TVM
  16. tallbloke
    Virga intacta...
  17. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "platypus"
    Aye, but I was hoping it might have been an exotic factory special of
    some sort, and the rest of the bits are residing, wrapped in oiled brown
    paper, in some old giffer's shed somewhere. I must admit the railcar
    application hadn't occured to me.
    GS 850 x2 / SE 6a
  18. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember tallbloke <>
    saying something like:
    Would you be able to source internals, barrels, heads, etc, for that?
    Pistons, I suppose, wouldn't be a great problem; there's always
    something that's very close indeed in the piston makers' cats.
    GS 850 x2 / SE 6a
  19. tallbloke
    Salad Dodger Guest
    Like this one?
    http://home.earthlink.net/~redmorganracing/dale.htm
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Oct 17, 2004
  20. It was somewhere around Barstow, on the edge of the desert, when the
    Sure that's not where the tea urn was bolted on?
    GS 850 x2 / SE 6a
