Road Paint
Discussion in 'UK Motorcycles' started by Catman, Mar 15, 2005.
  1. Catman
    Catman Guest
    Interesting [1] situation in Harlow ATM. Near where we live, they are
    re-surfacing using those huge plen jobs that strip the surface off. With
    it, it takes all the road paint adn in this case, the mini roundabouts
    So, given that the sign for the roadnabout is still there, there are big
    warnings that there are no raod markings and we have no reason to think
    that the roundabout will not be replaced, how does one approach the juncion
    [2]. As a roundabout or a normal t-junction?
    [1] For certain values of interesting
    [2] Apart from 'carefully'
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS (Badly bent) 155 TS
    www.cuore-sportivo.co.uk
  2. Catman
    Stonge Guest
    Road markings are everything, in their absence you should probably treat it
    as a give way in all directions on all approaches as it's not clear [1] who
    has right of way.
    [1] to anyone
    Stonge, Mar 15, 2005
  3. Catman wrote
    Kin carefully.
    steve auvache, Mar 15, 2005
  4. Catman
    Catman Guest
    Pretty much what I have been doing
    Catman, Mar 16, 2005
  5. Catman
    Catman Guest
    Ho *yuss*
  6. Catman
    TimP Guest
    I've heard that "they" have plans afoot to remove road markings from
    some roads, as it makes drivers feel less secure and so drive slower.
    Sounds fucking scary to me though.
    TimP
    TimP, Mar 16, 2005
  7. Catman
    Worked in Holland. They also removed a lot of roadside furniture and
    warning signs at junctions, roundabouts etc. as they distracted the
    driver.
    sweller, Mar 16, 2005
  8. Catman
    dwb Guest
    The roads here were I've come across that seem to usually result in someone
    driving along in the middle of the road.
    Why this should be I don't know, but it's a bit alarming.
    dwb, Mar 16, 2005
  9. Catman
    Accidents (were injury occurred) actually fell. Apparently.
  10. Catman
    rb Guest
    They added traffic lights to junction 14 of the M5 a couple of months
    ago. Except they only switched them on once and that morning was
    bedlam. Whereas normally there were no real problems on that day there
    were queues right out onto the A38 and down the M5 slip roads.
    As far as I know they haven't switched them on again since. They have
    even painted the give way markings back in again now so I haven't got a
    scooby what they are up to.
    Do any of the Bristol/Dursley locals know what's going on here?
    rb, Mar 16, 2005
  11. Catman
    That would be very nice. Beds County Council, in their infinite
    wisdom, decided to do something about a "dangerous" road to the North
    of Bedford. They conceived the "B660 Route Safety Project" in
    response to a couple of bikes going through the hedge and complaints
    from roadside residents of noise and speeding bikes.
    It is now *much* "safer": more road signs(1) to crash into, for a
    start - but their piece de resistance was to paint huge areas of
    tarmac with the speed limit ... "30" and "40" extending from verge to
    centre line - just at the point where you want to turn in.
    "SLOW" in enormous capitals right across the braking areas for corners
    and massive red, white and black triangles on the apexes reminding you
    to think of the fucking children.
    Cunts.
    1. Substantial steel posts supporting metal signs bearing the legend
    "B660 Route Safety Project" on the outside of corners, for example.
    Pip, Mar 16, 2005
  12. Catman
    That used[1] to happen at the Target roundabout[2]. If the lights
    were out for any reason the queues were almost non-existent.
    [1] I don't use the route in rush hour anymore.
    [2] junction of the A40 & A312.
    CT, Mar 16, 2005
  13. Catman
    MattG Guest
    Pip says...
    Whilst working in Dorchester last week I decided to drive to
    Weymouth (**** all else to do). Not a bad little run, just before
    arriving in Weymouth there is a down hill 180 right hander - very
    nice. Problem being that there is a field entrance right on the
    bend, so there was a great "Keep Clear" marking across the road -
    just where you're likely to be cranked right over.
    Fuckers.
    MattG, Mar 16, 2005
  14. Catman
    Catman Guest
    IMO traffic lights at roundabouts was always a bloody silly idea.
  15. Catman
    This was aimed more at signage, bollards etc
  16. Catman
    Catman Guest
    Yes, I appear to have replied to the wrong post :(
  17. Catman
    rb Guest
    They have done the opposite at the Quedgeley roundabout by the Cross
    Hands. Huge signas have been added on the roundabout and on the central
    reservation. They are black and white chevron fences which block your
    view of the roundabout completely as you approach from a dual
    carriageway. This has the effect of slowing/stopping all traffic as you
    can't see if the roundabout is clear until you are right on top of it.
    rb, Mar 16, 2005
  18. Pip wrote
    Makes me kinda glad sometimes that Essex are a bunch of junket going,
    penny pinching, public service crushing, tight Tory bastards.
    steve auvache, Mar 16, 2005
  19. Catman
    Cab Guest
    Depends. In Paris, where drivers tend to err on the agressive side at
    roundabouts, I think it's a decent idea.
    DAMHIK,IJD,OK
    Cab, Mar 16, 2005
  20. Catman
    That was the morning that a red BX came up the slip from the northbound side
    and t-boned one of the traffic light posts IIRC.
    Are you familiar with the acronym "SNAFU"?
    http://www.highways.gov.uk/news/articles/3742590.htm
    http://www.highways.gov.uk/news/articles/7781474.htm
    http://www.highways.gov.uk/news/press_releases/m5/2005_02_11b.htm
    Might be worth emailing them: "Well?"
    platypus, Mar 16, 2005
