RO instead of distilled water?
Discussion in 'UK Motorcycles' started by T i m, Mar 9, 2008.
  1. T i m
    T i m Guest
    Hi All,
    I am about to give the old motor from our AEG washing machine a final
    'go' in an effort to remove the 18k resistance between the stator and
    ground.
    It was suggested I use distilled water but a mate of mine has a new RO
    system for his fish tanks and it produces gallons of the stuff quickly
    and easily.
    For the purposes of 'cleaning' this motor (however unlikely a positive
    outcome might be) would RO work as well as distilled please?
    All the best ..
    T i m
    T i m, Mar 9, 2008
  2. T i m
    T i m Guest
    Ooops, I didn't mean to post this here but as I believe I did get some
    replies on this subject (as an aside) here previously it might still
    be relevant (and could still be vaguely on topic [1] if only many of
    our motorcycle batteries weren't 'sealed' these days).
    All the best ..
    T i m
    [1] Not that seems to be a requirement here ;-)
    T i m, Mar 9, 2008
  3. T i m
    T i m Guest
    Yeah, I'd not seen it (but not been looking for it either) for a while
    now. I believe I can get as much RO water off my mate as I want so no
    having to buy several 'top up' containers of distilled etc.
    Weird eh, I guess most people would think water was water?
    Brilliant, thanks Gazz and as you say even if it isn't 'perfect' for
    my intended application it's not likely to make anything worse or blow
    up! ;-)
    All the best ..
    T i m
    T i m, Mar 10, 2008
  4. T i m
    Dave Emerson Guest
    Do you have a dehumidifier?
    I've often wondered if the water that collects in the tank, which by
    definition is distilled, could be used for batteries etc.
    The only problem I foresee is the dust, though mine in filtered, and
    anything that could occur as the water condenses on the aluminium coils.
    Dave Emerson, Mar 10, 2008
  5. T i m
    T i m Guest
    I do (somewhere) ;-)
    Hmm, good thought.
    Indeed, but I guess it might be cleaner than rainwater and even
    contain less 'additives' than tap water?
    All the best ..
    T i m
    T i m, Mar 10, 2008
  6. T i m
    Jérémy Guest
    How about a condensing tumble drier? We produce gallons of what I assume
    must be distilled water.
    Jérémy, Mar 11, 2008
  7. Both, if filtered, should be better than chalky tap water anyway.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Mar 12, 2008
  8. T i m
    T i m Guest
    We don't have a condensing tumble dryer so that's out I'm afraid.
    We have one of those split air con units but that pumps out it's
    condensed water to evaporate at the external heat exchanger.
    I'll give this RO water a go. My mate is about to start producing it
    ready for a partial water change in his fish tank so he said he'd do
    me a couple of gallons.
    All the best ..
    T i m
    T i m, Mar 14, 2008
