Rivet vs. Split master links
Discussion in 'Motorbike Technical Discussion' started by Masospaghetti, Apr 11, 2006.
  1. I don't have a riveting tool so I would much prefer a split link. How
    much better are the rivet links, for a 750cc bike?
    Thanks
    -Maso
  2. Masospaghetti
    Paul Cassel Guest
    How much stronger is stronger?
    Paul Cassel, Apr 12, 2006
  3. Masospaghetti
    FB Guest
    Just degrease the side plate with a little alcohol or gasoline,
    degrease the clip and put a drop of red Loctite on it and install it in
    the right direction. It will never come off until you want to take it
    off to replace the chain.
    FB, Apr 12, 2006
  4. Ok, great. Just didn't want my chain flying off at 80 mph because I went
    with a split clip.
    Thanks all!
    -Maso
    Masospaghetti, Apr 12, 2006
  5. Modern split link chains have tapered pins for the sideplate. You have
    to force the thing on with a G-clamp or similar before you can get the
    clip on.
    In my experience of the things, that link is secure. Very.
    The Older Gentleman, Apr 12, 2006
  6. In my experience of the things if your service shop puts the clip
    on the inside of the chain, so that you think you have a rivetted chain and
    (mis)treat it accordingly, very sparky things can happen at 80 mph on a
    German Autobahn on a Sunday night...
    Klipsen? Nein danke!
    Dr Ivan D. Reid, Apr 12, 2006
  7. That's naughty....
  8. ...and how!
    I only spotted it when I posted the pics to (uk?)rm. "Why didn't
    I realise it was a split link? ... Oh!"
  9. Masospaghetti
    Eric Johnson Guest
    And it might be *REAL* bad if it were to break when you weren't in 1st
    gear!!
    Eric Johnson, May 8, 2006
