Ring a bloody ding
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Nov 11, 2009.
  1. So the Mighty Scooter's been sitting doing nothing for a year now.
    I finally decided that Something Must Be Done about its carburetion
    problems which were tracked down to a hole in the float bowl. WIth
    that fixed and the needle raise a notch as it was a bit rich low down
    it went Ring A Bloody Ding satisfactorily.
    Still had problems though... the motor is attached to the rest of it
    by an arrangement involving 2 tubes running inside 2 other tubes, with
    nylon bushes keeping the inside tube from grinding on the outside
    tube.
    Said bushes can wear. Split even. And when they do, the motor
    tends to move in rather disturbing ways when you do the cornering
    thing. Worse hinge than an H1!
    It was rideable but it definitely felt Odd going round anythingn
    resembling a curve.
    Luckily fixit kits are easy enough to find and not too bad to install
    once you
    - remove all that bodywork
    - remove all the things connected to the engine including the cooling
    hoses which means coolant everywhere unless you have a very
    peculiarly shaped catchment pan that can wrap around the centrestand,
    and the 2 stroke line from the pump which has a small clamp that is
    straining to fly and be free
    - remove the rusted on and unwilling tube things as above
    Reassembly is the reverse of disassembly (yes I was using a Haynes,
    why do you ask?) and while coolant was reasonably easy to insert the 2
    stroke line was not due to a reluctant and very slippery clamp.
    But once done... wahooo!
    This thing is way way way too much fun. I mean there is going to be a
    difference in the daily traffic battle between 240kg and 1200cc of
    fairinged tourer and 110kg (wringing wet) 180cc scooter, but what a
    difference!
    The Mighty Scooter is slower to take off, but when it gets into its
    stride it gets moving pretty bloody quickly. Quickly enough to
    surprise GSXR pilots anyway.
    It's narrow and light and lanesplits as though the gap between a bus
    and a 4WD was an entire lane. It makes a loud anti-social noise and
    wisps of smoke wreathe it at lights. It trickles along slowly when
    the traffic is inching without the complaints of the big bike riding
    the clutch, then takes off and howls when there's a bit of room.
    It's bright flouro orange.
    What's not to love?
    As someone said... Life's too short to spend all your time with four
    strokes.
    Zebee
  2. Zebee Johnstone
    CrazyCam Guest
    Geez, Zebee, you can be a right bitch at times.
    Here I am, fighting the addiction, day by day.
    It's over a year now since I had a two-stroke, and it's not getting any
    easier.
    I still have the craving.
    Every now and again, I'll even fire up the whipper snipper, just for the
    sake of the smell of burning oil.
    A couple of days ago, I even found myself test riding a scooter.
    It wasn't flouro orange, just orange, but it did have an Italian name on
    the front....Aprilia.
    It went pretty well, had great brakes, turned quite nicely, all in all,
    a nice wee 200 cc scoot, but, it sounded like a sewing machine, and
    didn't emit blue smoke... <sob>
    Help!
    regards,
    CrazyCam
    CrazyCam, Nov 11, 2009
  3. Zebee Johnstone
    Andrew Price Guest
    The daily commute, the weekly shopping trip, the just popping out to look
    at/collect some thing is just so much better on a scoot if you live in a
    crappy urban environment like Sydney.
    Aprilia are not good with carbys - the hole in the bowl thing could be
    called a design feature. Still, love the style and the sound though.
    For $6 a week in fuel, relatively cheap rego and insurance, stuff all
    maintenance [excluding Italian carbys] and the ability to lose a porsche
    getting away from the lights (using all the 250cc Piaggio gave it) it gives
    you a lot of smiles.
    Still need a real bike[1], but the scoot absolutely rules in hand to hand
    traffic combat.
    Wife now asks for a lift to work on the back - I tell you these things are
    addictive.
    There is a reason the Vespa (and derivatives) is one of the most successful
    bits of mechanical design ever made, alongside somewhat more troublingly the
    Colt A1911 in the simple but effective .45 ACP calibre.
    Best, Andrew
    [1] er, maybe more than just the one
    Andrew Price, Nov 11, 2009
  4. In aus.motorcycles on Thu, 12 Nov 2009 07:37:53 +1100
    Well if you rode bikes on weekends like normal people instead of
    mucking about in boats you could have a go on the Mighty Scooter.
    Flouro orange is pretty close to hot pink after all.
    Zebee
    Zebee Johnstone, Nov 12, 2009
