Right, sorted
Discussion in 'UK Motorcycles' started by The Older Gentleman, Mar 1, 2005.
  1. It was somewhere around Barstow, on the edge of the desert, when the
    That's the shitty pressed-in fuel pipe on the carb body; once it's
    pinned in place the problem goes away.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Mar 5, 2005
  2. It was somewhere around Barstow, on the edge of the desert, when the
    Rare, admittedly, but not unknown. Mind you, the worst one ever had to
    be a 1.8D non-turbo Escrote engine. Something along the lines of a
    modern 3L V6 2turbo diesel from BMW or someone like that would be just
    the job.
    GS 850 x2 / SE 6a
  3. Fair enough... I'll do some googling when I can be bothered.
    Simon Atkinson, Mar 5, 2005
  4. The Older Gentleman
    Lord Frag Guest
    Colin Wilson barfed:
    Listening for suggestions huh? Righteo :)
    Can't find a menu option for adding people to the Bozo Bin (I found the
    icon though)
    Can we have an easy way for marking all messages unread in a group?
    And for turning off/on threading in a group?
    And if I've got a batch thing set up to download new messages every 5
    minutes say, can it not reset the group view and loose the place where
    I was when it runs the batch?
    And when I ignore a thread, the next time I run XN it shows the thread
    again (I think, I use it on 3 machines so I may be imagining this one?)
    Can you write it in VC++ so I can play wiv the source? :)
    Lord Frag, Mar 5, 2005
  5. The Older Gentleman
    I assigned it to the hotkey 'K'. There were a few problems when the
    hotkey system threw a wobbler a few versions ago but Colin's now fixed it.
    sweller, Mar 5, 2005
  6. References header maybe, works OK where the one to be avoided their
    own newsserver. Not so hot for readers that generate random headers
    and/or servers that do the same.
    Boots Blakeley, Mar 5, 2005
  7. That's an interesting function....
    It still has the problem that you're possibly (indeed, probably) killing
    postings from people whose stuff you want to read, so in effect you're
    k/filing people by default.
    And the more prolific the k/filee, the more people you're adding to the
    killfile, but then I'm sure you figured that out too.
    The Older Gentleman, Mar 5, 2005
  8. So what you need is a "If <bozo> is in reply to my message"?
    Get a PC and use Gravity, man!
    Whinging Courier, Mar 5, 2005
  9. The Older Gentleman
    Colin Wilson Guest
    I don't want to try to turn this group into xananews.support - that's
    on the forums.talkto.net server. But...
    Yes - it should be on a menu too. I'll add it...
    The quickest way is Edit/Select All, followed by mark message as unread
    (CtrL+A, Ctrl+R)
    To temporarily switch between threaded/unthreaded click on the Flags
    column header. TO make it permanent select 'Newsgroup Properties',
    'Derived Settings', 'Sorting & Threading', Chronological.
    I'll check it out.
    I'll check it out.
    Heh. I've thought about writing a C# version too. But I'm hobbled by
    the lack of a free, excellent, multi column tree; and things like SSL
    support. Get yourself a copy of Delphi - YKIMS!
    Colin Wilson, Mar 5, 2005
  10. True enough. I mean, just killing all posts which say "Abuse report
    sent" would be a start.
    Yes, I agree. I just can't help feeling it would be a bit pointless, as
    well. Especially if you're simply k/fing someone because you don't like
    them, rather than because you don't think they post anything of worth -
    witness thread participation for proof of this.
    Now, if I look at my own k/file parameters <opens k/file and has a
    peek>, I see I've got two posters in there simply because I don't think
    they ever post anything at all worth reading, or if they do, it goes
    silly after one or two replies.
    The rest is all the usual troll-blocking stuff. Anyone posting from a
    cotse.com address, anyone using the word "Root" as a posting name,
    anyone x-posting to an alt. group (a damn good one that, and thanks to
    whoever suggested it) and anyone x-posting to a newsgroup containing the
    word "troll"
    Now that would be a damn good idea, yes. As I said elsewhere in this
    thread, I took dannydeever out of the bin because he started mmaking
    some interesting posts here & there.
    How does your newsreader treat read posts, then? MacSoup displays them n
    its graphical display, but removes them from the list of posts in the
    main window and stores them separately.
  11. The Older Gentleman
    Lord Frag Guest
    Ahh, doing a Ctrl H to show all messages, un thread them and sort by
    author name lets me find that post I just lost. Sorted :)
    Soooper! I knew the other way, just wondered if there was a temporary
    quick way, like this.
    Thanks mucho.
    Oh, one last thing, when I press N or M (or one of the other keys to go
    to the next post) can you make it so it automatically sets the focus to
    the article tree view?
    I keep on clicking in the groups window, pressing enter x2 to get new
    posts, press N or similar, press cursor up/down to get to the
    previous/next post and it changes group. (and then run round showing
    all posts, sort unthreaded by author to find what I just missed and
    wanted to reply to! :) (yes I know I should use N and P but keep on
    reverting to the cursor keys - OE throwback :)
    Is it free? I used to use Borland Pascal (for DOS) a lot.
    Decent tree control... a free one... <dons thinking hat>
  12. It was somewhere around Barstow, on the edge of the desert, when the
    It's no good; I've been Timo'd.
    GS 850 x2 / SE 6a
  13. The Older Gentleman
    Bear scribbled on the back of a napkin:
    Which one did you try? Did you ever try a turbocharged one?
    Timo Geusch, Mar 5, 2005
  14. The Older Gentleman
    Grimly Curmudgeon scribbled on the back of a napkin:
    Good man
  15. It was somewhere around Barstow, on the edge of the desert, when the
    This is just in the way of a trial - the rotary lump I'm putting in is
    just for fit and will be replaced later with either a reasonably tuned
    two rotor or a triple if I can lay hands on one.
    Oh, probably; mind you, there's a lovely V6 on ebay...
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9886&item=7958099241&rd=1
    Opening a Scim bonnet to reveal that would be a bit better than a skanky
    ol' Essex.
    GS 850 x2 / SE 6a
  16. The Older Gentleman
    Hmm. The MkII are rather lardy so unless you're talking Turbo or TII here,
    they're a bit on the glacial side for a sports car.
    Turbo IIs are deceptively quick, but don't necessarily feel that way. MkIIIs
    (the FD series) is *brutally* quick, and that's before people starting
    throwing goodies at them.
    Hmm. It may be that I like what you call "devoid of character" - the linear,
    completely vibration-free power delivery.
    Mind ewe, I'd really appreciate if they could do it such that you don't need
    your own oil well.
    Timo Geusch, Mar 6, 2005
  17. The Older Gentleman
    Eiron Guest
    Timo Geusch wrote:
    (About Mazda RX7s)
    How quick is *brutally*?
    The Mk3 is the sexiest thing since the Opel GT.
    Must resist temptation. :)
    Eiron, Mar 6, 2005
  18. The Older Gentleman
    Supercar/sports bike type quick.
    Don't :)
  19. The Older Gentleman
    Differing tastes, I'd say. I quite like engines that are this smooth.
    Yep...
  20. The Older Gentleman
    platypus, Mar 7, 2005
