Right angled grease gun?
Discussion in 'UK Motorcycles' started by Simon Wilson, Feb 20, 2010.
  1. Simon Wilson
    Simon Wilson Guest
    Did a bit of fettling today on the Gilera acquired from Mr. Fisher.
    Cambelt changed - no drama.
    Oil and filter changed - no drama.
    Minor wiring fault sorted[1] - no drama.
    Grease suspension linkages. Hmmmm.
    It's got several nipples none of which I can get any of my grease guns
    on. All the nipples are straight - if I had a right angled grease gun it
    would work.
    I googled but I couldn't find a simple right-angled grease gun or
    adapter in the uk. Found some grease gun adapter 'kits' on ebay, but 30
    quid's a bit steep. Found this
    http://www.thetoolwarehouse.net/p-7202-thexton-418.aspx but couldn't
    find a uk supplier. Anyone know where to find one? Alternatively I guess
    I could replace the nipples for angled ones which would make the job
    easier next time.
    [1] The starter motor operated even with the ignition key off.
  2. Simon Wilson
    Pete Fisher Guest
    Not as bad a job as it seems really.
    At least you can still get Renault 4/5 filters that will fit. Not sure
    if the one in the Voxan will be so easily obtained now that it appears
    they really are 'fini'.
    ISTR using a flexible hose adapter on some of them with success.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 20, 2010
  3. Simon Wilson
    Colin Irvine Guest
    Flexible hoses are good.
    Colin Irvine, Feb 20, 2010
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    You keep telling yourself that.
    http://40over40.com/
    Wicked Uncle Nigel, Feb 21, 2010
  5. Simon Wilson
    Colin Irvine Guest
    Heh. I'm a hand towel man, me.
    Colin Irvine, Feb 21, 2010
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    <glances casually down at M&S luxury extra-heavy bath towel>
    One day Glasshopper, you will be ready to leave the temple.
  7. Simon Wilson
    frag Guest
    <purile humour mode>
    "Dr Suks Minhaus" - hahahaha!
    </PHM>
    frag, Feb 21, 2010
  8. Simon Wilson
    Eiron Guest
    Tried clicking on that link but I couldn't get it up.
    Firefox 3.5.4 is crap.
    Eiron, Feb 21, 2010
  9. Simon Wilson
    Pete Fisher Guest
    Would this do the job?
    http://www.toolfastdirect.co.uk/acatalog/info_tb88c.html
    Pete Fisher, Feb 21, 2010
  10. Simon Wilson
    Simon Wilson Guest
    Simon Wilson, Feb 21, 2010
  11. Pah! Everyone knows that John Lewis towels are where it's at.
    Having said that, J-Cloths are bigger and more absorbant than most
    Dutch towels.
    doetnietcomputeren, Feb 21, 2010
  12. Simon Wilson
    sweller, Feb 21, 2010
  13. Simon Wilson
    Simon Wilson Guest
    Hmm not seen those type. But looking at the picture again it doesn't
    look like it would fit. Think i'll stick with the fitting a different
    nipple first.
  14. Simon Wilson
    Maybe one of those puffy, marshmallow-shaped ones? They're nice.
    platypus, Feb 21, 2010
  15. Simon Wilson
    You should have bought a Kawasaki instead, I've just the swinging arm
    out along with all the suspension linkages to grease them.
    I wouldn't have bothered if I hadn't been changing the swinging arm
    but while it was out it seemed a bit daft not to do the lot.
    I'm a bit pissed off because I haven't got a spare soft link for the
    chain because I'd have been out for a test ride later this afternoon
    if the chain wasn't held together with a cable tie. As it is I'll have
    to leave it for a week or so but at least that means I'll also have a
    chance to make a bracket for the front brake reservoir rather than
    using cable ties on that as well.
    Andy Bonwick, Feb 21, 2010
  16. Yep, the bigger ones commonly found on heavier kit.
    Grimly Curmudgeon, Feb 21, 2010
  17. Simon Wilson
    Beav Guest
    That's what I did with the Zed and it worked a treat.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 21, 2010
  18. Simon Wilson
    Beav Guest
    Use a little more lube.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 25, 2010
