Riding a CG125 using "the force" alone.
Discussion in 'UK Motorcycles' started by Andy, Dec 1, 2003.
  1. Andy
    Andy Guest
    OK the clocks have changed and I'm now travelling to/from work in the dark -
    it is now at this point that I have fully appreciated how crap the headlight
    is on the CG125. As soon as the streetlighting goes so does any chance of
    seeing further ahead of me than I can reach with an out-stretched hand. I
    thought - why don't I get a halogen bulb - the Haynes says I need a 35/35W
    bulb, but no base type details - same for the Honda parts manual. The bulb
    itself proudly declares it's a 35/35W but nothing else. It's not a base
    type I recognise - does anyone reading this know what the bulb type is for a
    CG125 BR-S? Then I can try and get a couple by mail-order.
    Cheers
    _______________
    AndyD
    CG125
    _______________
    Andy, Dec 1, 2003
  2. Andy
    Perhaps someone hereabouts knows if it will push a 55/60 Halogen bulb along?
    If so a Cibie conversion would be good.
    Hog, Dec 1, 2003
  3. Andy
    dwb Guest
    Why not just buy a decent torch and strap it to the bars? :)
    Failing that, walk - it's about the same speed.
    dwb, Dec 1, 2003
  4. Andy
    I've not seen one but would guess it has a Bosch P45t base.
    Which is best described as a bulb (either a globe of or a halogen
    envelope) having three spade type terminals coming out the base of the
    bulb cap, looking like this from above |_| , and a large (45mm-ish)
    stepped flange with notches to locate the bulb in the correct position.
    Similar to these
    http://www.classicandvintagebulbs.com/page2.html
    these bulb diagrams may help
    http://www.norbsa02.freeuk.com/goffybulbdiagrams.htm
    This place lists an adapter to allow fitting of P43 bulbs to P45
    fittings, which may improve the availiable range.
    http://www.norbsa02.freeuk.com/goffybulbs.htm
    The more readily available P43 is similar but has three flat legs to
    locate the bulb instead of the stepped flange.
    A search on "6v P45t halogen bulb 35W" turns up quite a few specialist
    suppliers that may be able to help.
    sweller, Dec 1, 2003
  5. Andy
    K Olley Guest
    Thats the Brazil model, it needs a *3 lug pre-focus* type bulb 12v,
    there was a halogen bulb of this type but I have no idea if it is
    still available.
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    BOTAFOT#67 BOTAFOF#23
    OSOS#29
    K Olley, Dec 1, 2003
  6. Andy
    Andy was seen penning the following ode to ... whatever:
    AFAIK they're the standard automotive 35/35W bulb that Honda has been
    using since the earlier 70s, if not before. I'm think that Vehicle
    Wiring Services do sell a compatible Halogen bulb - have a Google for
    their website (their whole catalogue is available online) as I CBA to
    dig out their current catalogue from my heap of other catalogues.
    Timo Geusch, Dec 1, 2003
  7. Andy
    These may be what Timo means
    http://www.vehicle-wiring-products.co.uk/VWPweb2000/lights-1/lights-1.html
  8. Andy
  9. Andy
    sweller was seen penning the following ode to ... whatever: Not quite, although the OP might find a suitable insert
    there. Actually it appears from looking at their bulb section that I
    confused the 35/35W bulb with the P45t. You can get an H4 one for the
    latter, but not the former.
  10. In uk.rec.motorcycles, Andy said:
    http://www.ishop.co.uk/ishop/884/shopscr222.html
    The mutt's nuts. Halfords used to do them but can't find them on their
    site. I saw these in use on a Fazer and the difference was staggering.
    Whinging Courier, Dec 1, 2003
  11. Andy
    K Olley Guest
    They still do them, they are quite good, I have got the round version
    of that make now fitted on the Virago, useful for reminding oncoming
    cagers that they have left their main beam lights on:)
    But we are talking CG125 here, their is a slight problem with
    alternator power output, ie not enough power, I doubt if there is
    enough power for a standard 55/60w halogen unless you replaced most of
    the other lights with custom style LED's to conserve power.
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    OSOS#29
  12. Andy
    Hey you have the germ of a plan. LED bulb conversions consume 20% Vs the
    filament type, I think??
    I just checked the Demon Tweeks catalogue, Cibie still do conversions 5 3/4
    and 7 inch as well as an H4 in a spotlight type shall of 180mm.
    Hog, Dec 1, 2003
  13. Andy
    Hog said....
    Stick a 350LC pattern headlight on, far better beam and a H4 bulb. 25
    quid normally from most bike shops.
    Lozzo, Dec 1, 2003
  14. Andy
    You mean better than a Cibie or better than the standard CG?? The Cibie unit
    is about £25 but one would need clips or similar to mount it.
    The concave Cibie conversion was the best alteration I ever made to the
    RD250E.
    Something along the Cibie line will feature on the 2004 Gixxer-Reborn I
    expect
    <blocks PIAA site at firewall>
    Hella now do an HID Projector dual beam. £322 unfortunately.
    Hog, Dec 1, 2003
  15. Andy
    K Olley Guest
    Depends on how its done, cheap circuitry may use voltage dropping
    resistors which would consume greater power than a electronic option,
    if you changed the indicators as well to use the lowest power option
    an electronic control would have to be fitted instead of the standard
    indicator relay, and don't forget the front (side) light, speedo
    illumination light and main beam indicator could be done and would all
    save a few watts.
    Probably be cheaper to have the alternator rewound to a higher output
    if it is possible:)
    Plenty of custom and replacement headlights that could easily be made
    to fit, cheapest option would be a quick look down at the local bike
    breakers.
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    OSOS#29
  16. Andy
    K Olley Guest
    Before you make any decision it could be worth while checking out
    Highway Hawk, they are expanding their lighting ranges and not all of
    them are designed to fit on the standard cruiser.
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    OSOS#29
  17. Andy
    Andy Guest
    Thanks for the suggestions - I think I'll try led bulb conversions and a
    replacement reflector/bulb mount assembly. Are the led conversions bright
    enough though?
    _______________
    AndyD
    CG125
    _______________
    Andy, Dec 2, 2003
  18. Andy
    K Olley Guest
    Yes, the custom made brake/tail lights output about the same amount of
    visible light as a conventional light unit.
    The brake light also works faster than a filament light, the light is
    almost instantaneous where as a normal lightbulb takes about a fifth
    of a second for the filament to warm up enough for it to generate
    light, it might not sound a lot but it is a visual difference.
    Kevin - Basildon
    XV535
    GPZ305 (her's)
    OSOS#29
    K Olley, Dec 2, 2003
