370[1] miles is seemingly (and as advertised) quite doable. It didn't even rain till the last 50 miles or so! It took around 8 hours, but was a pretty good ride. A bluetooth headset and a couple of gigabytes of music were a definite assistance in the boredom stakes though. However I have continued my remarkable trend of riding up to my destination driveway, turning off the bike and being unable to fucking well start it again. Last time it was a fried reg/rec[4] but this time I was on a hill, so I bump started it[2] and revved the tits off[3]. The headlight does NOT glow crimson and explode, the rev counter still works quite happily and the bike idles along for 20 mins or so, till boredom kicks in and I turn it off. Symptomatically, it makes a sad clicking noise as the starter solenoid flaps (it doesn't STAY clicked, it opens and shuts rapidly) and it doesn't make any attempt to turn the engine over. After the bump and 20 min run it did TRY and turn the starter but really not much, then more clicking. Headlight is bright with the engine off (makes heat on the palm of the hand) and the indicators flash with expected rhythm. Things I did: I filled up 40 miles from the end of the ride so it started fine at that point. I did use heated grips for the end of the ride and they were in use when the reg/rec failed. I've checked fuses in the starty system and tried to clean up the slightly scabby (green) solenoid connector. I intend to hand it over to a man with a spanner on Monday (any one local to the Lizard in Cornwall?) since I can bump it and ride it to one, but I thought I'd throw it over to the debate here too..... [1] I moved house since the last post. [2] ER5 [3] The bike, not me [4] It did make the battery ill and I'm still using that battery, but an Optimate gave it a green light after a day or so considering the matter.
