Ride to BOSM from Oop North
Discussion in 'UK Motorcycles' started by Paul Hendrick, Apr 1, 2005.
  1. If anybody fancies joining us on the way down to the BOSM next Saturday,
    we'll be leaving Harrogate at about 1pm, and taking an interesting route via
    Silkstone (near Barnsley), Glossop, and Buxton.
    People are welcome to gather at ours during the morning, plus we could meet
    up with people at Woolley Edge services just south of Leeds, if it suits
    people who are less north than us.
    I'll be taking it fairly easy as my R1 is showing the first signs of a
    fucked up 2nd gear selector[1], so I'll be mostly avoiding beans in second
    until I strip it apart for repairs (eek).
    [1] Apparently quite common for 98-99 models :eek:(
  2. Paul Hendrick
    Colin Irvine Guest
    Put us down for a definite possible.
    So ok for beans in 3rd?
    Colin Irvine, Apr 1, 2005
  3. Paul Hendrick
    Bear says...
    Be fair, at least his R1 will stop properly
    Lozzo, Apr 1, 2005
  4. Paul Hendrick
    Bear says...
    My CG had better brakes than this bike. At least they were adequate for
    the top speed of the thing.
    You won't wind me up on this one, because mine don't have an air
    problem. Master cylinder rebuild kit being fitted tomorrow. If that
    doesn't do it then we're on for getting R1 calipers fitted and these
    piece of shit Tokicos are going on eBay..
    Lozzo, Apr 1, 2005
  5. Paul Hendrick
    Bear says...
    I've been busy looking at the Harris catalogue and in particular the
    Brembo, AP Racing and PVM pages. I need about 2 grand to put a decent
    set of brakes on my bike.
    Lozzo, Apr 1, 2005
  6. Paul Hendrick
    Monz Guest
    Wooley edge is 37 M1 isn't it... I may be tempted, do any of the mad manc
    mob want to come over this way before heading south?
    Monz, Apr 1, 2005
  7. Unfortunately it is just in second, and I had the cover off and checked the
    detent roller spring on Wednesday night... it's fine :eek:(
    I'm hoping it's just the selector dog, but won't know until it's in bits.
    I don't suppose anybody has a manual handy have they?
  8. Paul Hendrick
    Paul Hendrick says...
    More likely to be the engagement dogs on second gear, rather than the
    selector forks. Either way, it's not that big a job. I thought R1s had a
    cassette type gearbox that you could pull from the side without
    splitting the cases.
    Lozzo, Apr 1, 2005
  9. Paul Hendrick
    Bear says...
    Pair of good R1 calipers can be had for about 80 quid, then there's a
    master cylinder to go with it. Luckily I can use the resevoir from the
    Tokico set up and it'll look like a standard set up at the handlebar
    end. All I'd have to make is a pair of alloy plates to go between forks
    and calipers to allow for the difference in mounting points. Piece of
    piss, and I have the material in the garage to make them from too.
    Lozzo, Apr 1, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    That's what I call forward planning:
    "Ooh, Fuji-san, dis 'box honoulable rump of clap. We bettah make it easy
    to get out..."
    Wicked Uncle Nigel, Apr 1, 2005
  11. Paul Hendrick
    I thought the brakes on this one were a bit shit, though miles ahead
    of the bandit (which had the same braking distance as the Exxon Valdez)
    And then I pulled a rolling stoppie with the front wheel locked [1] [2]
    and realised maybe they're a bit better than I thought.
    [1] Accidentally
    [2] Sadly not into a roundabout, while wheelying.
    ogden, Apr 1, 2005
  12. Paul Hendrick
    ogden says...
    No, these are shite, in a "worse than my second ZZR1100 ones" way
    Lozzo, Apr 1, 2005
  13. Paul Hendrick
    I'd have thought that anything amiss with the calipers would have shown
    up with the strip Loz did. They can't be cracked or anything can they?
    or if they're 2 part calipers is there anything wrong with the joining
    surfaces?
    Muck, Apr 1, 2005
  14. Paul Hendrick
    How hard would it be to fit a complete 7R front-end?
    ogden, Apr 1, 2005
  15. Paul Hendrick
    Ginge Guest
    Ginge, Apr 1, 2005
  16. Paul Hendrick
    Champ says...
    I don't know, but I've almost given up trying to find out. Master
    cylinder is the last thing I'm prepared to rebuild in my quest for
    decent brakes. From then on it becomes a conversion to something known
    to be good i.e. R1 calipers and m/cyl.
    Lozzo, Apr 1, 2005
  17. Paul Hendrick
    ogden says...
    I wouldn't bother, the 9R forks feel fine now I've got the damping
    settings right and 7Rs have the same shite calipers. What's the point?
    Lozzo, Apr 1, 2005
  18. Paul Hendrick, Apr 1, 2005
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    My workshop is pretty much back up and running, if you need it.
  20. Oh yus!
    Unfortunately it doesn't pop the front end up in third unless your really
    trying hard (crests!)... and that might have something to do with why second
    is shafted!
    Be good to see you next week :eek:)
