Ride Report: Bathurst - Ulladulla
Discussion in 'Australian Motorcycles' started by Damien, Dec 28, 2003.
  1. Damien
    Damien Guest
    Departed xmas eve, as planned, for the ride down to Ulladulla. The Bathurst-Lithgow stretch was as boring as hell, and
    nearly put me to sleep - despite having only just started! Once I got into the mountains, it was a bit better though -
    and if they'd just bypass all those annoying little fucking towns, it would be even better. Stopped at Blaxland for
    brekky, and discovered on departure that my battery had died, but luckily I was able to clutch start it and continue on
    my way.
    The boring stuff finally ended at Penrith when I turned off onto Mulgoa Road, and down through Silverdale/The
    Oaks/Thirlmere/Buxton to Mittagong. I haven't been that way before, and while it's not exactly the sort of road you'd go
    out of your way to ride, it sure as hell beats some of the alternative routes to the coast! Still a few nice corners,
    but mostly high-speed sweepers - hampered by the myriad driveways that mandated a somewhat lower speed than would have
    been required for maximum enjoyment, but a pleasant ride nonetheless. Stopped at The Oaks for petrol, where I discovered
    firstly that a clean air filter makes a HUGE difference to fuel economy - and that my battery was flat again. Clutch
    started it again, courtesy of a nice hill that was the servo driveway, and nervously continued on my way. Best part of
    all is that going this way you're only on the Hume for about 500m before you turn off for Mittagong.
    At Mittagong, the boys in blue pulled me over for an RBT, but it was a surprisingly pleasant experience. The coppers
    were very nice, and had me on my way as quick as possible because they didn't want me to get too hot sitting there (had
    the dri-riders on). I probably wouldn't be so pleased to see them if they were giving me a ticket, but otherwise they
    were a lot nicer than you'd expect.
    From there, it was down through Bowral, and then I took the turn for Kangaloon, which was probably one of the highlights
    of the trip. Next to no traffic, superb road surface, and corner after corner after corner. The only down side is that
    in places it is little more than a sealed goat track, and most of the corners are blind, so you have to take it easy in
    case there is any oncoming traffic. Still a fantastic road even so. That brought me out at Robertson, where I turned
    back towards Moss Vale for a bit, before taking the road to Fitzroy Falls. Managed to get past what traffic there was
    before the fun stuff started, and greatly enjoyed the descent into Kangaroo Valley - much better in the dry! Going back
    up the other side was even more fun again!
    Stopped at Nowra, where after a short break I discovered that my battery was flat AGAIN!!! The bloody thing wouldn't let
    me clutch start it this time, so I wheeled the bike up next to the Maccas building and plugged in my charger (good thing
    I packed everything!), and waited half an hour for it to charge. That did the trick and I was able to make it to
    Ulladulla without any problems. I did have one incident with some dickhead getting too close behind me, but after I made
    a point of looking back at him, before dropping down a couple of gears, he quickly dropped back. Other than that, the
    remainder of the journey was about as uneventful as you would expect.
    For the return trip, I went mostly the same way, with one slight variation. Given my loathing of lots of slow cages and
    little opportunity to pass them, I decided to go through to Richmond from Penrith, and take Bells Line of Road instead
    of the main highway. It doesn't add much at all to the length of the trip (maybe a few kays at most), and is a much
    better route as it turns out. Stuff all traffic on the Penrith-Richmond stretch, and nothing to hold you up through the
    mountains either. Less towns, higher speed limits, and more corners makes for a far more enjoyable trip as well. The
    weather wasn't the best this afternoon though, and there was a lot of fog through the mountains from Bilpin to about
    20km past Mount Tomah, and didn't clear up until the other side of Lithgow. Wasn't really much of an issue, just
    something I could have done without!
    I don't know what the deal is with that battery, but it didn't give me any trouble at all after Nowra. I checked it over
    the last few days, and it was sitting on around 13V, and then after a short ride yesterday was up to around 13.4V where
    it has stayed. I was all ready to put a brand new one in, and didn't only because the only place in Ulladulla that had
    any didn't have the right size. I'll have to keep a close eye on it, but it seems to be okay - for now at least!
    Overall, quite an enjoyable trip both ways. The biggest lesson I learned was that the seat on a CBR600 is fucking hard
    after 5 hours of riding, even if you do stop! I'll definitely have to do something about some extra padding for it next
    time I do a similar trip. It's fine for shorter trips (3 - 4 hours), but not so good for anything longer.
    The new tyres (Metzeler Z4's) were absolutely fantastic, and I would recommend them very highly now that I've seen what
    they can do. They stick very well through all corners, and are very confidence-inspiring, although I wasn't really
    pushing it that hard anyway. There was only one time where I had to brake hard to avoid an idiot in a cage, and the
    tyres held the road like it was nothing out of the ordinary - the old ones might not actually have let go in the same
    situation, but there would certainly have been a bit of sliding! This trip pretty much covered the full range of riding
    conditions, and the Z4's did a great job in all of them. Well worth the money.
    For those of you who actually read anything, that's all I have to say! Hope it was at least mildly interesting for you.
    Damien
    GPX250 (stolen) -> CBR600
  2. Damien
    Eddie Guest
    Hey Damien, you should have taken the O'connell road and thru Sodwalls and
    Tarana for the Bathurst -Lithgow stretch, much , much more fun.
    Eddie
    Eddie, Dec 28, 2003
  3. Damien
    John Littler Guest
    You'd better find out why the battery isn't holding a charge after , what, an
    hours riding ?
    Either
    a) you're not generating a charge
    b) you've a shortcircuit or other drain
    or
    c) the battery is stoofed
    JL
    John Littler, Dec 28, 2003
  4. Damien
    Damien Guest
    I would have bought a new battery in Ulladulla if I had been able to find one, as I also thought the battery was
    stuffed. But since Nowra, it has been fine, so I really don't know what the problem might have been. It's certainly been
    holding a charge well enough since then, and when I checked it on the weekend it was charging okay as well. Maybe it is
    actually just a case of a last minute rally before dying once and for all, but it seems okay for now. I'll be keeping a
    close eye on it though!
    Damien
  5. Damien
    Johnnie5 Guest
    keep a very close eye on it as this is when regulators pack it in
    from having to work too hard
    Johnnie5, Dec 28, 2003
  6. Damien
    sharkey Guest
    And to think I only ever read the first line of Damien posts ...
    Since it's an intermittent fault, check all the connectors
    between gen and battery, and the battery ground at both ends too ...
    sometimes these things shake in and out of contact.
    -----sharks
    sharkey, Dec 29, 2003
  7. Damien
    Damien Guest
    Sometimes you just can't help yourself, can you? :)
    Thanks for the advice. Definitely something strange going on, hopefully that's all it is - much cheaper than a new
    battery!
    Damien
    Damien, Dec 29, 2003
  8. Damien
    You're not just occasionally turning the key one click too far and leaving
    the park-lights on are you?
    Clem
    Knobdoodle, Dec 29, 2003
  9. No need to go that far. He's got an alarm, and I'm pretty sure his battery
    is something BT rescued from the tip...
    Intact Kneeslider, Dec 30, 2003
  10. Damien
    X-No-archive: yes
    Intact Kneeslider wrote;
    It sounds worse.... it sounds like
    [takes a deep breath and turns the incredibility-dial to 11]
    ....something BT would dump at the tip!!
    Clem
    Knobdoodle, Dec 30, 2003
  11. Damien
    Damien Guest
    The alarm is currently disconnected after it killed the battery a couple of months ago - Bathurst is too small to let
    the battery recharge after using the alarm for an extended period. And yes, it was indeed a BT tip-find, but apart from
    that one episode on the way to Ulladulla, has been pretty good overall.
    Damien
    Damien, Dec 30, 2003
  12. Damien
    X-No-archive: yes
    Damien wrote;
    Oh shit; you mean it literally was "something BT rescued from the tip"?!!?
    I thought IK was just being euphemistic!
    [puts dunces cap on head]
    Clem
  13. Why? People throw away all sorts of stuff despite the fact that it's in
    perfect working order... BT, wisely, recognises this.
  14. Damien
    Damien Guest
    And yet he still claims that I'm the tight one!
    (hmm, perhaps that could have been worded a bit better? meh, cbf) :)
    Damien
  15. Damien
    Nev.. Guest
    eh what ?? is the road to Mudgee broken or something ???
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Dec 30, 2003
  16. Damien
    Damien Guest
    No, I'm just too busy to get out on many rides, that's all. But as busy as I am, everything in Bathurst is 5 minutes or
    less from everything else, so even the busiest of schedules for me is still barely enough to get the engine warm!
    Damien
  17. Damien
    Go for a walk you lazy bastard! ;-)
    BT Humble, Dec 31, 2003
