RGV motor problems
Discussion in 'Australian Motorcycles' started by pandpp, Mar 7, 2004.
  1. pandpp
    pandpp Guest
    Hi there,
    I'm trying (again) to fix up a mates '89 RGV 250 (K model, I think
    This has been something of an ongoing project, that hasn't been
    touched for 18 months, possibly 2 years. Here is the history so far:
    One of the valves lost a stem, the valve dropped into the piston.
    Seizure! Said mate removed heads & barrels, left motor in the frame,
    under a car port that leaked. Here the bike stayed, for possibly up
    to 12 months.
    By the time I started work on the poor thing, the crank was rusted
    solid, none too surprising.
    I replaced the crank (2nd hand), piston, rings, barrel, valves, etc...
    I put the whole thing back together.
    What I found was that I had good compression, but could only manage to
    idle on 1 barrel, from memory the left (rear). When it was revved up,
    over 6 - 6500, the valves kicked in, at which point the right (front)
    barrel started firing. It almost appeared that the left barrel
    stopped firing at this point.
    I suspected the carbs, since, one was full of water for so long, the
    fuelways were corroded. I replaced the carb. No change. I swapped
    carbs. No change.
    Next I suspected electrics. I have replaced EVERY electrical
    component in the system. No change.
    It was lastly suggested that there should be a gas seal between both
    barrels. I tested this theory today. Poured some petrol into 1
    barrel, which just flooded out of the other barrel.
    I now have the engine back out, with the cases cracked. The crank has
    a seal between the 2 counter weights, only, I don't see that this
    could be a gas seal, since there is a SERIOUS amount of slop present.
    So, now for the questions:
    1) Should the middle seal on the crank be a tight fit?
    2) Should there be a gas seal between both barrels?
    3) Any new suggestions, because, I have exhausted all of my current
    ideas.
    All ideas appreciated.
    Thanks,
    Peter.
    pandpp, Mar 7, 2004
  2. pandpp
    Definitely a cam regrind required. (And a valve-lapping)
    Knobdoodle, Mar 7, 2004
  3. pandpp
    Johnnie5 Guest
    Johnnie5, Mar 7, 2004
