After Christmas, I possibly only let the starter motor run a second or two, to rotate the newly fitted belts. So, it most likely didn't run by itself since around mid-November. Is it then normal to expect it to be a bugger to start now? After a couple of rounds of / starting attempt / plugs out / drying & heating plugs / plugs in / I seem to conclude that the way to go is max choke, no throttle, keep the starter spinning whilst praying to the Ducati God that it eventually will catch, before the (newish) battery goes flat. Or - ?
