review and confession... (a bit long)
Discussion in 'UK Motorcycles' started by Andy Bonwick, Sep 2, 2007.
  1. Andy Bonwick
    gbzzl Guest
    Well if he gets that on ebay too, it'll be a lot lighter to post.
    gbzzl, Sep 2, 2007
  2. Andy Bonwick
    although the original design was found in some pictograms, on clay tablets
    found at Ashurbanipal
    wessie at tesco dot net
    BMW R1150GS
    "Wessie is a lovely man with many wonderful qualities" TM Blaney
    wessie, Sep 2, 2007
  3. Andy Bonwick
    Dave Emerson Guest
    Surely that was the boxer.
    Dave Emerson, Sep 2, 2007
  4. Andy Bonwick
    No, no. Bricks predate reciprocating mass technology.
    BMW R1150GS
    wessie, Sep 2, 2007
  5. Andy Bonwick
    wrote in 4ax.com:
    FFS, Steven, close that fucking stable door
    BMW R1150GS
    wessie, Sep 2, 2007
  6. Andy Bonwick
    They have the same Brembo F08 calipers as 70s Guzzis [1] and they can be
    made quite good. I think BMW used the larger piston F09 (48mm rather
    than 38mm) on some models but I reckon you have F08s.
    As has been said fresh fluid and braided hoses will go a long way. If
    they have dull grey pistons (the later coated type - which yours should
    be) they shouldn't need rebuilding, just the pins cleaning.
    The later ones also have a single 10mm bleed nipple which makes life
    easier as the 6mm two nipple type snap if you 'look at them in a funny
    way'.
    I use Brembo pads in the Guzzi [2] and they're very good. EBC non HH are
    dire and barely knock the rust off the discs. HH are marginally better
    but, IMO, not as good as Brembo's own. Although the friction coefficient
    is listed as higher - I suspect it's more marketing than anything else.
    [1] ....and Ducatis, Laverdas and - amazingly - early MZ ETZs
    [2] Mine has 4 pot Brembos now but I used them in the originals.
    sweller, Sep 3, 2007
  7. Andy Bonwick
    The Guzzi is supposed to use leaded but I just sling 95 RON U/L at it and
    it seems to go ok.
    Not snake oil (according to the Federation of British Historic Vehicle
    Clubs):
    http://www.fbhvc.co.uk/fuel/index.htm#adds
  8. Andy Bonwick
    It's not really an old bike though.
  9. Andy Bonwick
    deadmail Guest
    The sample of five K75/100s I've had all had ceramic pistons. Some of
    these still managed to get 'sticky' with 20 odd years of gunk between
    the hydraulic and dust seals.
    I think they only used the single bleed on the K. At least both of my B
    reg bikes (85?) had these.
    deadmail, Sep 3, 2007
  10. Andy Bonwick
    Ofnuts Guest
    For some value of "old". Still a 1984 model, which makes it 22-23 years
    old. Not technically an antique, granted, but still old enough to have
    rusted/cracked bits.
    Ofnuts, Sep 3, 2007
  11. Andy Bonwick
    Donald Guest
    snip
    Agreed, and fitting braided hoses isn't going to improve them to modern
    UJM standards either.
    snip
    What have you done with the real Andy ?
    I would leave the panniers on for the Elephant, if you do go sliding
    they'll stop too much damage.
    I generally only get 137 miles to a tank on my K75S
    snip
    You should have said, I would have let you have my K75S for free. It's
    got less than 40K miles on it too.
    Donald, Sep 3, 2007
  12. Andy Bonwick
    Whilst I appreciate the thrust of your argument, I do think that you
    meant "4 star petrol", not 2.
    Pip, Sep 3, 2007
  13. Andy Bonwick
    Why? They were all built to run on 2*, AFAICR.
    _______
    Ace, Sep 3, 2007
  14. Andy Bonwick
    2 star was only 87 octane - I thought BMWs needed 4 star (97 IIRC).
  15. Andy Bonwick
    That's what I was getting at - Loz was referring to the BMW, Ace to
    the UJM. 4*/2* respectively. I'm confused now.
    Pip, Sep 3, 2007
  16. Andy Bonwick
    Adrian Guest
    sweller () gurgled happily, sounding much like
    they were saying :
    2* was 92RON, 3* 94, 4* 97, 5* 100.
    87 is common in merkania, but they measure differently - their MON+RON/2
    makes their 87 "Regular" about equivalent to the Euro 91RON "Regular
    Unleaded" we don't get here.
    Adrian, Sep 3, 2007
  17. It's pretty cheap too - I've been using it all year in Avis's finest
    hire cars and at an average of $2.85 per US gallon, it's cheap motoring.
    The septics got a bit funny when the price fluctuated up to $3.10 a
    gallon, tight fuckers.
    doetnietcomputeren, Sep 3, 2007
  18. Andy Bonwick
    No trouble with the valves or faces?
    ogden, Sep 3, 2007
  19. Damn, beat me to it.
  20. Andy Bonwick
    speedyspic Guest
    I can see where you're coming from with this, but my statement was
    based upon the fact that almost every Japanese bike from 1971 onwards
    was designed to run on 2 star fuel or unleaded - very few required 4
    star, and those that did usually had highly tuned engines. Tbh I was
    ignorant of the fact that BMW bricks needed 4 start fuel, and again, I
    can't see why BMW decided to make an engine that required such a high
    octane fuel when cheaper lower octane fuel is more readily available
    worldwide, and in such a softly tuned engine too.
    speedyspic, Sep 3, 2007
