Rev counter phenomena
Discussion in 'UK Motorcycles' started by Stefan, Jan 12, 2005.
  1. Stefan
    tallbloke Guest
    It's not my bike or my problem, I responded to the original poster. I'm
    intrigued by the fault finder though, does it give these indications at any
    time, or only when you start a special procedure?
    tallbloke, Jan 12, 2005
  2. Stefan
    tallbloke Guest
    No but it's a start ;-)
  3. Stefan
    Preston Kemp Guest
    Some Triumphs have a partial fault finding mode - if the tacho drops to
    zero quickly followed by the engine stopping, it means the ignition
    pick-up coils blown up :)
    Preston Kemp, Jan 12, 2005
  4. To be honest I can't remember. It only happened once and that was over two
    years ago.
    J Barry Galbraith, Jan 12, 2005
  5. "tallbloke" said
    <snip>
    On start-up... can't remember how long it or if it continued for any length
    of time.
  6. Stefan
    When you switch it on, and before you start the engine, it does a self
    test. Suzukis do it too. I've never seen one indicate an error
    condition, but I think it's along the lines of "if the needle points
    at 4000 rpm then the engine temp sensor has failed" or somesuch.
    Please add "imo" to above post.
    Champ
    GSX-R 1000, GPz 750 turbo, ZX7RR Endurance Racer x 2
    GYASB#0 BotToS#2 BOTAFO(T|F)#35 WG*#1 DFV#8
    Team UKRM Racing : www.team-ukrm.com
    Champ, Jan 12, 2005
  7. Stefan
    RealMart Guest
    You get them when there's a fault detected when you start the engine, and
    they seem to carry on going if you decide to ride away regardless.
    On the Fazer 1000, the needle flicks from zero to the fault indication rpm
    (ie. 7k is "exup valve seized"), then back to zero, then to the actual
    engine revs for a couple of seconds, then back to zero to begin the cycle
    again.
    Just looked it up, and 3k is for the throttle position sensor, 4k for the
    speed sensor, 7k for the exup valve, 9 k for the tip-over switch, and 12k
    for valve bounce.
    HTH, etc.
    RealMart, Jan 12, 2005
  8. Stefan
    OH- Guest
    On the Tedium it is supposed to do rather odd things if the throttle
    position sensor (TPS) is out of order. More amazing is that if you have
    to calibrate the TPS you can make the rev counter read degrees of
    throttle position by disconnecting and reconnecting things in a certain
    order. - "What revs were you at?" - "I have no idea but I had 76
    degrees throttle angle".
    OH-, Jan 12, 2005
  9. RTFM. On my Divvie, if you started it up and the rev counter needle went
    instantly to 5k and stayed there (irrespective of what revs the engine
    was actually doing) it meant the throttle position sensor needed
    adjusting.
    Lots of bikes use electronic tachos as fault-finders. Injected GSXRs,
    for a start.
    The Older Gentleman, Jan 12, 2005
  10. Stefan
    Greasing it may fix the problem.
    sweller, Jan 12, 2005
  11. Stefan
    The Older Gentleman says...
    Thunderaces too.
    Lozzo, Jan 12, 2005
