Rev counter phenomena
Discussion in 'UK Motorcycles' started by Stefan, Jan 12, 2005.
  1. Stefan
    Stefan Guest
    Can anyone explain this?
    On my 97 speed triple, the rev counter needle tends to dart around
    wildly, even when the revs are constant. I cant work out why it is
    doing this, and its not a serious problem because I rarely look at it
    anyway, just may be a problem when I want to sell. Anyone got any
    suggestions on how to fix it?
  2. What's the other problem?
    Whinging Courier, Jan 12, 2005
  3. buy a new cable.
    Adie
    Triumph 955iSS / GSF1200 bandit / CG125
    Adrienne M Bonwick, Jan 12, 2005
  4. Stefan
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Adrienne M
    Is the rev counter mechanical on them?
    Nigel Eaton, Jan 12, 2005
  5. havent got a clue. I'll check when I get home though I'm hoping SWrK
    will be along shortly. I only suggested it cos when mine have been
    about to break in the past its done strange things as the original
    post.
    Adie
  6. Stefan
    Nigel Eaton Guest
    Oh, OK, must be then.
  7. may not be. it wasnt a trumpet it happened on.
    Adie
  8. Stefan
    tallbloke Guest
    (Stefan) wrote in @posting.google.com:
    If it's electronic, check the earths. If it's mechanical lube all but the top
    2" of the cable inner sparingly with hmp grey grease.
    tallbloke, Jan 12, 2005
  9. Stefan
    Preston Kemp Guest
    Check the connectors on the #2 coil next time you're in the area.
    Preston Kemp, Jan 12, 2005
  10. will it also do fault finding on top posting? go away and read the
    FFAQ.
    Adie
  11. On my bike (Yamaha Fazer) the rev counter doubles up as a fault finder. The
    variations on the needle tel me about a possible fault on the bike.
    May not be the same on yours but definately worth a look in the manual I
    owuls have thought.
    J Barry Galbraith, Jan 12, 2005
  12. Stefan
    flash Guest
    So how does that work then? Is it when going along or just on start up?
    flash, Jan 12, 2005
  13. J Barry Galbraith wrote
    Excellent.
    As you raised the subject mentioned manuals and the usefulness of
    reading them, please let me be one of those to bring to your attention
    the one for ukrm. It is call the ffaq by some and the faq by others.
    In addition there is a cbt (our little joke). Both are really well
    worth reading if you wish to have a hassle free start to your stay here.
    steve auvache, Jan 12, 2005
  14. <snip>
    The FFAQ (why 2 F's though?) say:
    The charter can be seen in full at
    http://www.usenet.org.uk/uk.rec.motorcycles.html but there are really only
    two essential points to observe which are:
    Commercial advertising is forbidden
    Adverts are allowed but only from individuals selling privately.
    Binaries are not permitted
    but you can post binaries to a binary group
    or (even better) on a web page and post the URL to ukrm. "
    Thanks for the welcome by the way.
  15. J Barry Galbraith wrote
    This is ukrm, expletives are obligatory.
  16. cos its enough to make most of us swear
    ho you think I'm being nasty. you're in for a shock.
    go away and read section 1.8, posting style
    http://www.ukrm.net/faq/The_Newsgroup/Posting_Style.html
    and then come back, post at the bottom, learn to snip and remove sigs.
    Adie
  17. Stefan
    tallbloke Guest
    When it points to 11 it means the throttles jammed open.
  18. Stefan
    tallbloke Guest
    Errr Adie, he did post vat the bottom in his reply to you, and did snip most
    of your .sig too...
  19. Stefan
    flash Guest
    Any chance of you making something exciting up?
    flash, Jan 12, 2005
  20. ah but most isnt all is it?
    Adie
