Resurection, need a little help
Discussion in 'Classic Motorbikes' started by sweller, Sep 29, 2003.
  1. sweller
    Today I have been mostly stripping a sidecar (Watsonian Mitze) and offering
    it up to the lucky recepient machine. I've had the chair for about 5 years
    and always meant to sort it but never got round to it. Well I am now.
    BUT, the chair was built for an MZ TS 250/1 and was modified (badly) to fit
    an MZ ETZ 250. I now want to fit it to a TS 250/1. I have the brackets,
    well a load of rusty blocks of metal, and a friendly engineering type.
    What I would like is some help...[1]
    Can anyone supply pictures or a written description of the mounting bracket
    arrangements for both TS and ETZ combos? There must be some MZ outfit
    pervs out there.
    {1] Asked Watsonian, they no longer have diagrams or instructions for their
    older chairs. Burwins 'don't do sidecars'.
  2. sweller
    WorkTOG Guest
    I'm trying to think of something more uncontrollable than an MZ with a
    chair attached and all the geometry wrong. There are all these arcane
    terms like "sidecar wheel lead" and "toe-in". Do a google search about
    how to set up a chair (must be some info out there) and make up new
    brackets?
    WorkTOG, Sep 30, 2003
  3. sweller
    flashgorman Guest
    KH750 triple running on original suspension and carrying a fat pillion.
    flashgorman, Sep 30, 2003
  4. sweller
    I've got the geometry angle (!) already covered [1], the problem is the
    TS/ETZ frame. As you know, are spine types with the engine suspended on
    rubber mounts. But the frames are different; the TS being twin tubes and
    the ETZ a single box section.
    Either way there is nowhere to attach the front chair mount and to allow
    it to be adjusted with regards to toe in.
    I have an MZ clamp that runs up through the centre of the fork yoke and
    has provision for movement in the steering plane. It also has a fixed
    clamp to attach to the front mounting 'strut' of the chair. But it is
    pretty rusty and has a Chinese puzzle, or Heath Robinson depending on
    your viewpoint, air about it.
    To compound the problem the front mounting strut has been modified.
    Hacked about would be a better description.
    I'd really like some pictures or accurate descriptions of the components
    and methods for both models.
    It'll make a cracking support vehicle...
    [1] For those who *must* know...
    Sidecar wheel lead
    The distance straight forward from the rear axle of the bike to the
    sidecar wheel spindle is known as the lead
    Motorcycle lean-out
    When fully laden it is important that the bike should not lean towards
    the sidecar.
    Sidecar wheel toe-in
    Toe-in is defined as the amount by which the track width at the front
    wheel is narrower than at the rear
    sweller, Sep 30, 2003
  5. sweller
    Sean Guest
    Yup, the front is a single mount that goes through the headstock. From
    memory ( which may be flaky as I've only seen one and fixed it at the side
    of the road for the owner ), the rear upper goes to the rear suspension
    mount upper. The rear lower to the rearmost engine mount?
    Try Pleasley Motorcycles, Pleasley, Mansfield. Small family run firm, MZ
    enthusiasts.
    Sean, Sep 30, 2003
  6. sweller
    Gyp Guest
    After lots of investigation and trial and error, I finally set the
    K75/ST2 up such that the bike was leaning slightly towards the chair.
    Felt far safer than the when it was slightly leaning out
    Gyp, Sep 30, 2003
  7. sweller
    The complete quote:
    Motorcycle lean-out
    the sidecar; if it does the steering will be heavy particularly when
    turning away from the side-car. The amount of lean-out is measured at the
    steering head of the unladen motorcycle and is usually less than 3cm.
    Outfits with car tyres, particularly wide, low pro-file ones, should be
    set up with zero lean-out.
  8. sweller
    Gyp Guest
    The bit you missed out:
    Motorcycles with lean out are as scary as **** when turning towards the
    sidecar.
    Gyp, Sep 30, 2003
  9. sweller
    Well yes, that's the short and to the point version.
  10. sweller
    Gyp Guest
    And different to yours!
    Gyp, Sep 30, 2003
  11. sweller
    Hmm, bloody good point. So vertical is the way forward.
