Restoring A Tank - Sticker Removal?
Discussion in 'Motorbike Technical Discussion' started by rkandrlover, Oct 17, 2007.
  1. rkandrlover
    Beryl Guest
    You never indicated that you thought about anything except the overall
    temperature of the fuel inside the tank as you heated it /only/ to the
    extent that you can touch the metal briefly without burning yourself.
    Great thinking there, Einstein, wouldn't want to burn your fingers.
    So why make a statement such as "There are not enough gas fumes on the
    outside of a closed tank to concentrate..."? They already ARE
    concentrated, right when they exit the vent. Where's the vent? How big a
    vapor cloud should the OP let buildup before he sucks it into the hairdryer?
    Beryl, Oct 22, 2007
  2. You're making yourself look like a bigger fuckwit with every posting on
    the subject.
    The Older Gentleman, Oct 22, 2007
  3. rkandrlover
    Beryl Guest
    Nah. Where's the vent on rkandrlover's tank, MOldy? Where's he going to
    be holding the hairdryer? Think he should heat it as much as LJ did?
    Beryl, Oct 22, 2007
