Reserve Fuel Tanks
Discussion in 'Australian Motorcycles' started by Sandgroper, Oct 14, 2003.
  1. Sandgroper
    Sandgroper Guest
    How does a reserve fuel tank actually work ?
    When you fill up your tank , does the new fuel mix with the fuel in the
    reserve tank or is the reserve tank completely separate from the main
    tank and the fuel that's in the reserve stays there and gets old.
    Would it be a good idea to occasionally run on the reserve tank on the
    way to the petrol station just to use up the old fuel in the reserve?
    Thanks.
  2. Sandgroper
    Biggus Guest
    One tank with 2 pickups at different heights.
    Biggus, Oct 14, 2003
  3. Sandgroper
    FuTAnT Guest
    There's no such thing as a 'reserve' tank, it's just a different pick up
    point in the main tank. When you have to switch over to reserve it takes
    the fuel from a lower point in the fuel tank, so the difference between the
    normal pick up point, and the low point, is your 'reserve'.
    Cam
    '00 ZX6R
    FuTAnT, Oct 14, 2003
  4. Sandgroper
    RM Guest
    well when u run out of fuel you turn on the reserve...then you go to the
    petrol station and fill up...then next time you run out you go to turn on
    the reserve, only to realise that when you filled up after last time you
    did'nt put it back on main...so you push it to a petrol station, fill up and
    select main tank, vowing never to forget again...then next time you run
    out...
    so a reserve tank is a cyclic thing...sometimes it is, sometimes it isn't
    RM, Oct 14, 2003
  5. Sandgroper
    Jorgen Guest
    Hehe, how true :) Especially so on say a CBR250RR. Dealer said I should be
    able to get 200-220 ks out of each tank... Well, I got some exercise and
    eventually learned to refill about 100ks short of that. Typically fillerup
    with 6-6.5 liters into my 10l tank at 110 or so Ks so I guess I could push
    it to 170ks on a tank. But >200 in the city?? Get real. Or be prepared to
    take off like a 50cc scooter [never going above 7k rpms].
    j
    Jorgen, Oct 14, 2003
  6. Sandgroper
    Sandgroper Guest
    Oh , I see , said the blind man.
    So that how it works , I though the reserve tank might have been a
    separate tank within the main tank itself , and once the reserve fills
    up , it overflows into the main tank , and when you go to fill up the
    main tank , it sort of like just tops up the reserve tank which still
    has the old petrol inside it.
    So from what you are saying , it is just one tank that has two pickup
    points at different levels in the tank and that when you go to fill up
    the tank , the old fuel in the bottom mixes with the new stuff.
    Thanks.
  7. Sandgroper
    Sandgroper Guest
    Thanks , that's good , it's just one tank for both reserve and main , I
    was wondering about whether the old fuel in the "reserve" mixes with the
    new fuel that's put in regularly.
  8. Sandgroper
    Sandgroper Guest
    isn't
    I have never had to use the reserve , I usually just go by the trip
    meter and fill the tank up after riding a certain amount of Kms ,
    usually about 250 Km ( 9.5 litres of a 15 litre tank ) , which is about
    once a week and costs around $10.
  9. Sandgroper
    Gary Woodman Guest
    My bikes redline at around 7000.
    Gary Woodman, Oct 14, 2003
  10. Sandgroper
    Jorgen Guest
    Add 12k to that and you have mine :)
    j
  11. Sandgroper
    Nev.. Guest
    The mistake you made was not letting the tank run out of petrol, it was
    believing something a salesman said while he was trying to convince you to
    hand over your cash.
    Nev..
    '02 CBR1100XX #2 lives on !! no ZX12R yet...
    Nev.., Oct 14, 2003
  12. Sandgroper
    Nev.. Guest
    More and more bikes only have a theoretical reserve capacity nowadays. They
    have no separate fuel pickup, tap or switch, just a flashing light or similar
    on the dash. The manufacturers still quote a reserve capacity in their specs,
    but if you run dry, you're walking.
    Nev..
    Nev.., Oct 14, 2003
  13. Sandgroper
    Boxer Guest
    I have a 30 litre reserve tank that is isolated from the main tank and fills
    it on demand by a separate low pressure fuel pump via a line with a non
    return valve.
    Boxer
    Boxer, Oct 14, 2003
  14. Sandgroper
    sharkey Guest
    That's exactly right. The reserve tank, which is open at the top,
    is below the main tank, which is open at the bottom :)
    Yep. The 'two different levels' is often done with a little
    snorkel in the tap. The 'main pickup' is through the top of the
    snorkel, the 'reserve pickup' is straight into the tap body.
    The problem is that water, which is heavier than petrol, generally
    settles to the bottom of the tank, and if there's enough of it
    down there it gets sucked in when you switch to reserve. Ick.
    -----sharks
    sharkey, Oct 14, 2003
  15. Sandgroper
    sharkey Guest
    Let me guess ... Suzuki Across. Was I right, was I, was I?
    -----sharks (read a lot of books about tanks ...)
    sharkey, Oct 15, 2003
  16. Sandgroper
    Jorgen Guest
    So it's worth switching to reserve every once in a while just to smoothen
    things out?
    j
    Jorgen, Oct 15, 2003
  17. Sandgroper
    lemmiwinks Guest
    Ditto (with a couple of two stroke exceptions)
    Cheers,
    Ash
    lemmiwinks, Oct 15, 2003
  18. Sandgroper
    Theo Bekkers Guest
    "Jorgen" wrote
    Fug'nell. Your 250 uses more fuel than my 1100.
    Theo
    Stunned.
    Theo Bekkers, Oct 15, 2003
  19. Sandgroper
    vinyl Guest
    You're a genius, sharkey :)
    vinyl, Oct 15, 2003
  20. Sandgroper
    Jorgen Guest
    Probably means that I'm ready for a bigger bike. Once warm I like to rev the
    tits out of it, that's where the "power" is. :)
    j
